    690 Posts 77 Posters 2.9m Views 70 Watching
      Mykle1 Project Sponsor Module Developer @jeffreyking
      @jeffreyking
      imperial = F
      metric = C
        jeffreyking
        Thanks got that I am getting the wrong temp tell me 65 when it should be 27
          @jeffreyking
          NOAA3?
          It works for me. I just tried it. Went right to C when I changed to metric. Have you changed anything in any of the module files?
            jeffreyking
            No the default weather module works fine I am using yahoo as provider.
              @jeffreyking
              Well, if you haven’t changed any of the NOAA3 files then you’ll have to wait for the author to take a look at it for you.
              • cowboysdudeC Offline
                cowboysdude Module Developer @jeffreyking
                @jeffreyking said in MMM-NOAA - Another Weather Module:
                Hello every one I like this module and it works great, but I would like to know how to change the temp from F to C thank you keep up the good work.
                The temp will change depending on your setting in your config.js
                Example = Imperial shows F
                Metric shows C
                  jeffreyking
                  Got it up and running it was yahoo weather that was the problem. thank you
                    Smotx
                      Smotx
                      Where to set the town/country ?
                      Thx.
                        cowboysdude Module Developer @Smotx
                        @smotx You don’t. It’s automatically set to read your location.
                        I am working on allowing users to input their own lat and lon… seems that the geolocation isn’t as accurate as I and other would like it to be…
                        • 47
                        • 48
                        • 49
                        • 50
                        • 51
                        • 68
                        • 69
                        • 49 / 69
