    • cowboysdudeC Offline
      cowboysdude Module Developer @jeffreyking
      @jeffreyking said in MMM-NOAA - Another Weather Module:
      Hello every one I like this module and it works great, but I would like to know how to change the temp from F to C thank you keep up the good work.
      The temp will change depending on your setting in your config.js
      Example = Imperial shows F
      Metric shows C
        jeffreyking
        Got it up and running it was yahoo weather that was the problem. thank you
          Smotx
            Smotx
            Where to set the town/country ?
            Thx.
              cowboysdude Module Developer @Smotx
              @smotx You don’t. It’s automatically set to read your location.
              I am working on allowing users to input their own lat and lon… seems that the geolocation isn’t as accurate as I and other would like it to be…
                Smotx @cowboysdude
                @cowboysdude Ok but how it read my location,
                actually, it’s not my town (and I dontt know which city it is… 60° Celcius ?)
                  @smotx I am working on allowing users to input their own lat and lon…
                    Smotx
                    Ok. i’m waiting about.
                      If you’re using DarkSky as your api good news… That one is done…users can now input their own lat and lon to override the geolocation in the provider.
                      Example config:
                          module: 'MMM-NOAA3',
                         position: 'top_left',
                                provider: "darksky", // From list above
                                apiKey: "YOUR API KEY",        // From one of the providers listed above
                                airKey: "YOUR API KEY",
                                css: "NOAA3"                   // THIS MUST CONTAIN A CSS STYLE NAME
                                userlat: "42.071420",  //overrides the default geolocation with a more precise lat and lon
                                userlon: "-76.799440" //ONLY works with the Darksky api at this time!!
                        Smotx
                        Cool, so i think now it’s my town^^.
                          @cowboysdude said in MMM-NOAA - Another Weather Module:
                          YES! Nice work, you ole sum beach. :-)
                            Description:
                            NEW you must now provide your latitude and longitude… [after fighting with geolocation services it’s just not accurate enough]. SEE the readme on Github!
                            NOW works with all providers!
                            To update to a ‘git pull’ in the MagicMirror/modules/MMM-NOAA3 directory
                            example config:
                                         provider: "must be in quotes",
                                         css: "NOAA3"
                                         userlat: "xxxx",
                                         userlon: "xxxx"
                            Current weather
                            current condition
                            current temp
                            UV Index [using the UV Index color codes]
                            Humidity [if above certain % changes number color]
                            Wind and direction
                            Barometer [Shows number plus if rising, falling or steady]
                            Sunrise/Sunset times
                            Forecast
                            Rotates through 10 day forecast [including today]
                            Expected condition
                            with high/low temps
                            expected humidity
                            Please follow Readme on Github!
                            Screenshots:
                            NONE – See Github
                            Version 3.1.1
                            Download:
                            [card:cowboysdude/MMM-NOAA]
                              JRCelis
                              Does not run after updated and modified the config file.
                              0|mm       | WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
                              0|mm       | TypeError: Cannot read property 'data' of undefined
                              0|mm       |     at Object.parseResponse (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ds.js:61:43)
                              0|mm       |     at Request._callback (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ds.js:52:28)
                              0|mm       |     at Request.self.callback (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:185:22)
                              0|mm       |     at emitTwo (events.js:126:13)
                              0|mm       |     at Request.emit (events.js:214:7)
                              0|mm       |     at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1161:10)
                              0|mm       |     at emitOne (events.js:116:13)
                              0|mm       |     at Request.emit (events.js:211:7)
                              0|mm       |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1083:12)
                              0|mm       |     at Object.onceWrapper (events.js:313:30)
                              My config.js
                              			position: 'top_right',
                                     			apiKey: "xxxxxx",        // From one of the providers listed above
                                     			airKey: "xxxxxx",
                              			userlat: "43.02xxxx",
                                           		userlon: "-81.32xxxx"
                              tbbearT cowboysdudeC 2 Replies Last reply Reply Quote 0
                              • tbbearT Offline
                                tbbear Module Developer @JRCelis
                                @jrcelis after your css: … their is no comma
                                Robert the Bear
                                cowboysdudeC J Mykle1M 3 Replies Last reply Reply Quote 1
                                  cowboysdude Module Developer @tbbear
                                  @tbbear Nice catch!! Thanks!!
                                    cowboysdude Module Developer @JRCelis
                                    @jrcelis said in MMM-NOAA - Another Weather Module:
                                    PS please edit your post and remove your api key… :)
                                      JRCelis @tbbear
                                      @tbbear Thanks!!!
                                        Mykle1 Project Sponsor Module Developer @tbbear
                                        @tbbear said in MMM-NOAA - Another Weather Module:
                                        Robert! How are you doing? Long time, no see!
                                          @cowboysdude
                                          There is no comma in the readme examples for the css: "NOAA3", line.
                                            @mykle1 did you go a pull request to fix it?
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 34
                                            • 35
                                            • 25 / 35
