    690 Posts 77 Posters 3.3m Views 70 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @jeffreyking
      @jeffreyking
      imperial = F
      metric = C
        jeffreyking
        Thanks got that I am getting the wrong temp tell me 65 when it should be 27
        Mykle1M 1 Reply Last reply
        • Mykle1M
          @jeffreyking
          NOAA3?
          It works for me. I just tried it. Went right to C when I changed to metric. Have you changed anything in any of the module files?
            jeffreyking
            No the default weather module works fine I am using yahoo as provider.
            • Mykle1M
              @jeffreyking
              Well, if you haven’t changed any of the NOAA3 files then you’ll have to wait for the author to take a look at it for you.
              • cowboysdudeC
                cowboysdude Module Developer @jeffreyking
                @jeffreyking said in MMM-NOAA - Another Weather Module:
                Hello every one I like this module and it works great, but I would like to know how to change the temp from F to C thank you keep up the good work.
                The temp will change depending on your setting in your config.js
                Example = Imperial shows F
                Metric shows C
                  jeffreyking
                  Got it up and running it was yahoo weather that was the problem. thank you
                    Smotx
                      Smotx
                      Where to set the town/country ?
                      Thx.
                      • cowboysdudeC
                        cowboysdude Module Developer @Smotx
                        @smotx You don’t. It’s automatically set to read your location.
                        I am working on allowing users to input their own lat and lon… seems that the geolocation isn’t as accurate as I and other would like it to be…
                          Smotx @cowboysdude
                          @cowboysdude Ok but how it read my location,
                          actually, it’s not my town (and I dontt know which city it is… 60° Celcius ?)
                          • cowboysdudeC
                            @smotx I am working on allowing users to input their own lat and lon…
                              Smotx
                              Ok. i’m waiting about.
                              • cowboysdudeC
                                If you’re using DarkSky as your api good news… That one is done…users can now input their own lat and lon to override the geolocation in the provider.
                                Example config:
                                    module: 'MMM-NOAA3',
                                   position: 'top_left',
                                          provider: "darksky", // From list above
                                          apiKey: "YOUR API KEY",        // From one of the providers listed above
                                          airKey: "YOUR API KEY",
                                          css: "NOAA3"                   // THIS MUST CONTAIN A CSS STYLE NAME
                                          userlat: "42.071420",  //overrides the default geolocation with a more precise lat and lon
                                          userlon: "-76.799440" //ONLY works with the Darksky api at this time!!
                                  Smotx
                                  Cool, so i think now it’s my town^^.
                                  • Mykle1M
                                    @cowboysdude said in MMM-NOAA - Another Weather Module:
                                    YES! Nice work, you ole sum beach. :-)
                                    • cowboysdudeC
                                      Description:
                                      NEW you must now provide your latitude and longitude… [after fighting with geolocation services it’s just not accurate enough]. SEE the readme on Github!
                                      NOW works with all providers!
                                      To update to a ‘git pull’ in the MagicMirror/modules/MMM-NOAA3 directory
                                      example config:
                                                   provider: "must be in quotes",
                                                   css: "NOAA3"
                                                   userlat: "xxxx",
                                                   userlon: "xxxx"
                                      Current weather
                                      current condition
                                      current temp
                                      UV Index [using the UV Index color codes]
                                      Humidity [if above certain % changes number color]
                                      Wind and direction
                                      Barometer [Shows number plus if rising, falling or steady]
                                      Sunrise/Sunset times
                                      Forecast
                                      Rotates through 10 day forecast [including today]
                                      Expected condition
                                      with high/low temps
                                      expected humidity
                                      Please follow Readme on Github!
                                      Screenshots:
                                      NONE – See Github
                                      Version 3.1.1
                                      Download:
                                      [card:cowboysdude/MMM-NOAA]
                                        JRCelis
                                        Does not run after updated and modified the config file.
                                        0|mm       | WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
                                        0|mm       | TypeError: Cannot read property 'data' of undefined
                                        0|mm       |     at Object.parseResponse (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ds.js:61:43)
                                        0|mm       |     at Request._callback (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ds.js:52:28)
                                        0|mm       |     at Request.self.callback (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:185:22)
                                        0|mm       |     at emitTwo (events.js:126:13)
                                        0|mm       |     at Request.emit (events.js:214:7)
                                        0|mm       |     at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1161:10)
                                        0|mm       |     at emitOne (events.js:116:13)
                                        0|mm       |     at Request.emit (events.js:211:7)
                                        0|mm       |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1083:12)
                                        0|mm       |     at Object.onceWrapper (events.js:313:30)
                                        My config.js
                                        			position: 'top_right',
                                               			apiKey: "xxxxxx",        // From one of the providers listed above
                                               			airKey: "xxxxxx",
                                        			userlat: "43.02xxxx",
                                                     		userlon: "-81.32xxxx"
                                        tbbearT cowboysdudeC 2 Replies Last reply
                                        • tbbearT
                                          tbbear Module Developer @JRCelis
                                          @jrcelis after your css: … their is no comma
                                          Robert the Bear
                                          cowboysdudeC J Mykle1M 3 Replies Last reply
                                          • cowboysdudeC
                                            cowboysdude Module Developer @tbbear
                                            @tbbear Nice catch!! Thanks!!
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 34
                                            • 35
                                            • 25 / 35
