    690 Posts 77 Posters 3.1m Views 70 Watching
      Smotx
      Where to set the town/country ?
      Thx.
      • cowboysdudeC Offline
        cowboysdude Module Developer @Smotx
        @smotx You don’t. It’s automatically set to read your location.
        I am working on allowing users to input their own lat and lon… seems that the geolocation isn’t as accurate as I and other would like it to be…
          Smotx @cowboysdude
          @cowboysdude Ok but how it read my location,
          actually, it’s not my town (and I dontt know which city it is… 60° Celcius ?)
            @smotx I am working on allowing users to input their own lat and lon…
              Smotx
              Ok. i’m waiting about.
                If you’re using DarkSky as your api good news… That one is done…users can now input their own lat and lon to override the geolocation in the provider.
                Example config:
                    module: 'MMM-NOAA3',
                   position: 'top_left',
                          provider: "darksky", // From list above
                          apiKey: "YOUR API KEY",        // From one of the providers listed above
                          airKey: "YOUR API KEY",
                          css: "NOAA3"                   // THIS MUST CONTAIN A CSS STYLE NAME
                          userlat: "42.071420",  //overrides the default geolocation with a more precise lat and lon
                          userlon: "-76.799440" //ONLY works with the Darksky api at this time!!
                  Smotx
                  Cool, so i think now it’s my town^^.
                    @cowboysdude said in MMM-NOAA - Another Weather Module:
                    YES! Nice work, you ole sum beach. :-)
                      Description:
                      NEW you must now provide your latitude and longitude… [after fighting with geolocation services it’s just not accurate enough]. SEE the readme on Github!
                      NOW works with all providers!
                      To update to a ‘git pull’ in the MagicMirror/modules/MMM-NOAA3 directory
                      example config:
                                   provider: "must be in quotes",
                                   css: "NOAA3"
                                   userlat: "xxxx",
                                   userlon: "xxxx"
                      Current weather
                      current condition
                      current temp
                      UV Index [using the UV Index color codes]
                      Humidity [if above certain % changes number color]
                      Wind and direction
                      Barometer [Shows number plus if rising, falling or steady]
                      Sunrise/Sunset times
                      Forecast
                      Rotates through 10 day forecast [including today]
                      Expected condition
                      with high/low temps
                      expected humidity
                      Please follow Readme on Github!
                      Screenshots:
                      NONE – See Github
                      Version 3.1.1
                      Download:
                      [card:cowboysdude/MMM-NOAA]
                        JRCelis
                        Does not run after updated and modified the config file.
                        0|mm       | WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
                        0|mm       | TypeError: Cannot read property 'data' of undefined
                        0|mm       |     at Object.parseResponse (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ds.js:61:43)
                        0|mm       |     at Request._callback (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ds.js:52:28)
                        0|mm       |     at Request.self.callback (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:185:22)
                        0|mm       |     at emitTwo (events.js:126:13)
                        0|mm       |     at Request.emit (events.js:214:7)
                        0|mm       |     at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1161:10)
                        0|mm       |     at emitOne (events.js:116:13)
                        0|mm       |     at Request.emit (events.js:211:7)
                        0|mm       |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1083:12)
                        0|mm       |     at Object.onceWrapper (events.js:313:30)
                        My config.js
                        			position: 'top_right',
                               			apiKey: "xxxxxx",        // From one of the providers listed above
                               			airKey: "xxxxxx",
                        			userlat: "43.02xxxx",
                                     		userlon: "-81.32xxxx"
                        tbbearT cowboysdudeC 2 Replies Last reply Reply Quote 0
                        • tbbearT Offline
                          tbbear Module Developer @JRCelis
                          @jrcelis after your css: … their is no comma
                          Robert the Bear
                          cowboysdudeC J Mykle1M 3 Replies Last reply Reply Quote 1
                            cowboysdude Module Developer @tbbear
                            @tbbear Nice catch!! Thanks!!
                              cowboysdude Module Developer @JRCelis
                              @jrcelis said in MMM-NOAA - Another Weather Module:
                              PS please edit your post and remove your api key… :)
                                JRCelis @tbbear
                                @tbbear Thanks!!!
                                  Mykle1 Project Sponsor Module Developer @tbbear
                                  @tbbear said in MMM-NOAA - Another Weather Module:
                                  Robert! How are you doing? Long time, no see!
                                    @cowboysdude
                                    There is no comma in the readme examples for the css: "NOAA3", line.
                                      @mykle1 did you go a pull request to fix it?
                                        Uhhh, no. Haha. I went to do it but it appears you already corrected it.
                                          @mykle1 That’s right LOL
                                            doogy_rev
                                            This is an awesome weather module! Just set mine up and using Darksky as my weather source. I have set my update interval to 30 min, which (unless I am being a div) would mean 24 a updates day and 700 or so a month. Monitoring my DarkSky console I am currently updating 45-50 times a day.
        module: "MMM-NOAA3",
        apiKey: "xxxxxxxxxxxxxxxxxxxxxxxxxxx",        // From one of the providers listed above
        airKey: "xxxxxxxxxxxxxxxxxxx",
        css: "NOAA3",                 // THIS MUST CONTAIN A CSS STYLE NAME
        updateInterval: 30 * 60 * 1000,
        userlat: "49.238941", //MUST HAVE BOTH
        userlon: "-121.765883"  //MUST HAVE BOTH
                                            Is the above correct from a configuration perspective? Have I missed something?
                                            Thanks in advance!
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 34
                                            • 35
                                            • 26 / 35
