    690 Posts 77 Posters 3.3m Views 70 Watching
      Smotx
      Ok. i’m waiting about.
      • cowboysdudeC
        If you’re using DarkSky as your api good news… That one is done…users can now input their own lat and lon to override the geolocation in the provider.
        Example config:
            module: 'MMM-NOAA3',
           position: 'top_left',
                  provider: "darksky", // From list above
                  apiKey: "YOUR API KEY",        // From one of the providers listed above
                  airKey: "YOUR API KEY",
                  css: "NOAA3"                   // THIS MUST CONTAIN A CSS STYLE NAME
                  userlat: "42.071420",  //overrides the default geolocation with a more precise lat and lon
                  userlon: "-76.799440" //ONLY works with the Darksky api at this time!!
        Mykle1M 1 Reply Last reply
          Smotx
          Cool, so i think now it’s my town^^.
          • Mykle1M
            @cowboysdude said in MMM-NOAA - Another Weather Module:
            YES! Nice work, you ole sum beach. :-)
            • cowboysdudeC
              Description:
              NEW you must now provide your latitude and longitude… [after fighting with geolocation services it’s just not accurate enough]. SEE the readme on Github!
              NOW works with all providers!
              To update to a ‘git pull’ in the MagicMirror/modules/MMM-NOAA3 directory
              example config:
                           provider: "must be in quotes",
                           css: "NOAA3"
                           userlat: "xxxx",
                           userlon: "xxxx"
              Current weather
              current condition
              current temp
              UV Index [using the UV Index color codes]
              Humidity [if above certain % changes number color]
              Wind and direction
              Barometer [Shows number plus if rising, falling or steady]
              Sunrise/Sunset times
              Forecast
              Rotates through 10 day forecast [including today]
              Expected condition
              with high/low temps
              expected humidity
              Please follow Readme on Github!
              Screenshots:
              NONE – See Github
              Version 3.1.1
              Download:
              [card:cowboysdude/MMM-NOAA]
                JRCelis
                Does not run after updated and modified the config file.
                0|mm       | WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
                0|mm       | TypeError: Cannot read property 'data' of undefined
                0|mm       |     at Object.parseResponse (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ds.js:61:43)
                0|mm       |     at Request._callback (/home/pi/MagicMirror/modules/MMM-NOAA3/providers/ds.js:52:28)
                0|mm       |     at Request.self.callback (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:185:22)
                0|mm       |     at emitTwo (events.js:126:13)
                0|mm       |     at Request.emit (events.js:214:7)
                0|mm       |     at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1161:10)
                0|mm       |     at emitOne (events.js:116:13)
                0|mm       |     at Request.emit (events.js:211:7)
                0|mm       |     at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-NOAA3/node_modules/request/request.js:1083:12)
                0|mm       |     at Object.onceWrapper (events.js:313:30)
                My config.js
                			position: 'top_right',
                       			apiKey: "xxxxxx",        // From one of the providers listed above
                       			airKey: "xxxxxx",
                			userlat: "43.02xxxx",
                             		userlon: "-81.32xxxx"
                tbbearT cowboysdudeC 2 Replies Last reply
                • tbbearT
                  tbbear Module Developer @JRCelis
                  @jrcelis after your css: … their is no comma
                  Robert the Bear
                  cowboysdudeC J Mykle1M 3 Replies Last reply
                  • cowboysdudeC
                    cowboysdude Module Developer @tbbear
                    @tbbear Nice catch!! Thanks!!
                    • cowboysdudeC
                      cowboysdude Module Developer @JRCelis
                      @jrcelis said in MMM-NOAA - Another Weather Module:
                      PS please edit your post and remove your api key… :)
                        JRCelis @tbbear
                        @tbbear Thanks!!!
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @tbbear
                          @tbbear said in MMM-NOAA - Another Weather Module:
                          Robert! How are you doing? Long time, no see!
                          • Mykle1M
                            @cowboysdude
                            There is no comma in the readme examples for the css: "NOAA3", line.
                            • cowboysdudeC
                              @mykle1 did you go a pull request to fix it?
                              • Mykle1M
                                Uhhh, no. Haha. I went to do it but it appears you already corrected it.
                                • cowboysdudeC
                                  @mykle1 That’s right LOL
                                    doogy_rev
                                    This is an awesome weather module! Just set mine up and using Darksky as my weather source. I have set my update interval to 30 min, which (unless I am being a div) would mean 24 a updates day and 700 or so a month. Monitoring my DarkSky console I am currently updating 45-50 times a day.
                                                            module: "MMM-NOAA3",
        apiKey: "xxxxxxxxxxxxxxxxxxxxxxxxxxx",        // From one of the providers listed above
        airKey: "xxxxxxxxxxxxxxxxxxx",
        css: "NOAA3",                 // THIS MUST CONTAIN A CSS STYLE NAME
        updateInterval: 30 * 60 * 1000,
        userlat: "49.238941", //MUST HAVE BOTH
        userlon: "-121.765883"  //MUST HAVE BOTH
                                    Is the above correct from a configuration perspective? Have I missed something?
                                    Thanks in advance!
                                    • Mykle1M
                                      Mykle1 Project Sponsor Module Developer @doogy_rev
                                      @doogy_rev said in MMM-NOAA - Another Weather Module:
                                      Math class, apparently. ;-)
                                      Every 30 minutes would be 48 calls a day, and in a 30 day month, 1440 calls
                                      Reply Quote 2
                                        doogy_rev
                                        Haha, yes you are right. What an utter putz I am 🙈
                                        • Mykle1M
                                          @doogy_rev
                                          Don’t be too hard on yourself. We all make mistakes. :thumbsup:
                                          Reply Quote 2
                                          • E
                                            epi
                                            Did someone managed to change css to make this module look more like this?
                                            Or like this
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 34
                                            • 35
                                            • 26 / 35
