Help file confing. js
12 Posts 3 Posters 3.6k Views 3 Watching
  • G Offline
    Gianluca
    Hello to all. I would like a help if possible on how to find a solution to my problem. After carrying out the steps for the installation of the Magic Mirror, at the start of the MM tells me that I have to configure the file confing.js
    How can I do ? where can I find the solution?
    J 1 Reply Last reply Oct 7, 2018, 7:08 AM Reply Quote 0
      justjim1220 Module Developer @Gianluca
      @gianluca
      when you downloaded MagicMirror, you should have a folder named config
      in that folder, you should have a config.js.sample or a config.sample.js
      rename that file to config.js
      it should work then
      "Life's Too Short To Dance With Ugly People"
      Jim Hallock - 1995
      • G Offline
        Gianluca
        thank you so much!!! it works. But if I want to do it in Italian, I have to modify the Forms or find modules in Italian
        J 1 Reply Last reply Oct 7, 2018, 7:56 AM Reply Quote 0
          @gianluca
          No problem, always glad to help.
          most modules and including MagicMirror should have an Italian translation
          At the top of the config file, just above modules: [
          You should find this…
          	language: "en",
          	timeFormat: 24,
          	units: "imperial",
          this is where you put in the code for your language. I think yours should be ‘it’
          Jim Hallock - 1995
          • G Offline
            Gianluca
            Changed the confing, but only the calendar description changes me. So the rest should I change it? I would love to insert the weather module is difficult? are there any tutorials explaining how to insert the forms?
            J 2 Replies Last reply Oct 7, 2018, 8:20 AM Reply Quote 0
              @gianluca
              Every module SHOULD have a sample config entry for them in the Readme file or on the main page of the modules
              Jim Hallock - 1995
                @gianluca
                I just switched mine to Italian and the only module that changed was MMM-NOAA3 which is a really good weather module.
                Jim Hallock - 1995
                • G Offline
                  Gianluca
                  I have difficulty entering the weather. I modified the form and configured the boundary. js but nothing does not appear to me. is there a tutorial that explains how to modify and insert the modules?
                  M 1 Reply Last reply Oct 7, 2018, 9:51 PM Reply Quote 0
                    Mykle1 Project Sponsor Module Developer @Gianluca
                    @gianluca said in Help file confing. js:
                    https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
                    • G Offline
                      Gianluca
                      Hello, I’m vcerc with the weather. I execute the description of wuthnerground
                      I can not understand the reason that nion works for me.
                          module: "MMM-WunderGround",
                              apikey: "++++++++++++++", // private; don't share!
                              pws: "locid:NLXX8014;loctype:1", //culemborg
                              hourly: "1",
                              fctext: "1",
                              fcdaycount: "5",
                              fcdaystart: "0",
                              hourlyinterval: "3",
                              hourlycount: "2",
                              alerttime: 10000,
                              alerttruncatestring: "english:",
                      	roundTmpDecs: 1,
                      	UseCardinals: 0,
                      	layout: "horizontal",
                      	sysstat: 0
                      this is the module I put in confing.js while in the modules folder I inserted the MMM-wutherGround module. Should I be wrong?
                      in the APIKEY I put my KEY
                      in psw what dev or put? I do not have the password
                      M 1 Reply Last reply Oct 10, 2018, 11:48 PM Reply Quote 0
