    Help file confing. js
    12 Posts 3 Posters 3.9k Views 3 Watching
    • justjim1220J Offline
      justjim1220 Module Developer @Gianluca
      @gianluca
      No problem, always glad to help.
      most modules and including MagicMirror should have an Italian translation
      At the top of the config file, just above modules: [
      You should find this…
      	language: "en",
      	timeFormat: 24,
      	units: "imperial",
      this is where you put in the code for your language. I think yours should be ‘it’
      "Life's Too Short To Dance With Ugly People"
      Jim Hallock - 1995
      • G Offline
        Gianluca
        Changed the confing, but only the calendar description changes me. So the rest should I change it? I would love to insert the weather module is difficult? are there any tutorials explaining how to insert the forms?
        justjim1220J 2 Replies Last reply Reply Quote 0
          @gianluca
          Every module SHOULD have a sample config entry for them in the Readme file or on the main page of the modules
          Jim Hallock - 1995
            @gianluca
            I just switched mine to Italian and the only module that changed was MMM-NOAA3 which is a really good weather module.
            Jim Hallock - 1995
            • G Offline
              Gianluca
              I have difficulty entering the weather. I modified the form and configured the boundary. js but nothing does not appear to me. is there a tutorial that explains how to modify and insert the modules?
                Mykle1 Project Sponsor Module Developer @Gianluca
                @gianluca said in Help file confing. js:
                https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
                • G Offline
                  Gianluca
                  Hello, I’m vcerc with the weather. I execute the description of wuthnerground
                  I can not understand the reason that nion works for me.
                      module: "MMM-WunderGround",
                          apikey: "++++++++++++++", // private; don't share!
                          pws: "locid:NLXX8014;loctype:1", //culemborg
                          hourly: "1",
                          fctext: "1",
                          fcdaycount: "5",
                          fcdaystart: "0",
                          hourlyinterval: "3",
                          hourlycount: "2",
                          alerttime: 10000,
                          alerttruncatestring: "english:",
                  	roundTmpDecs: 1,
                  	UseCardinals: 0,
                  	layout: "horizontal",
                  	sysstat: 0
                  this is the module I put in confing.js while in the modules folder I inserted the MMM-wutherGround module. Should I be wrong?
                  in the APIKEY I put my KEY
                  in psw what dev or put? I do not have the password
                    @gianluca
                    I just used your example above, inserting my api key and it works. Be very careful when entering your api key
                    • G Offline
                      Gianluca
                      Thanks for your help. everything works now
