Help file confing. js
Hello to all. I would like a help if possible on how to find a solution to my problem. After carrying out the steps for the installation of the Magic Mirror, at the start of the MM tells me that I have to configure the file confing.js
How can I do ? where can I find the solution? -
when you downloaded MagicMirror, you should have a folder named config
in that folder, you should have a config.js.sample or a config.sample.js
rename that file to config.js
it should work then -
thank you so much!!! it works. But if I want to do it in Italian, I have to modify the Forms or find modules in Italian
No problem, always glad to help.
most modules and including MagicMirror should have an Italian translation
At the top of the config file, just above modules: [
You should find this…language: "en", timeFormat: 24, units: "imperial", modules: [this is where you put in the code for your language. I think yours should be ‘it’
Changed the confing, but only the calendar description changes me. So the rest should I change it? I would love to insert the weather module is difficult? are there any tutorials explaining how to insert the forms?
Every module SHOULD have a sample config entry for them in the Readme file or on the main page of the modules
I just switched mine to Italian and the only module that changed was MMM-NOAA3 which is a really good weather module.
I have difficulty entering the weather. I modified the form and configured the boundary. js but nothing does not appear to me. is there a tutorial that explains how to modify and insert the modules?
@gianluca said in Help file confing. js:
https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
Hello, I’m vcerc with the weather. I execute the description of wuthnerground
I can not understand the reason that nion works for me.{ module: "MMM-WunderGround", position: "top_right", config: { apikey: "++++++++++++++", // private; don't share! pws: "locid:NLXX8014;loctype:1", //culemborg hourly: "1", fctext: "1", fcdaycount: "5", fcdaystart: "0", hourlyinterval: "3", hourlycount: "2", alerttime: 10000, alerttruncatestring: "english:", roundTmpDecs: 1, UseCardinals: 0, layout: "horizontal", sysstat: 0 } },this is the module I put in confing.js while in the modules folder I inserted the MMM-wutherGround module. Should I be wrong?
in the APIKEY I put my KEY
in psw what dev or put? I do not have the password -
I just used your example above, inserting my api key and it works. Be very careful when entering your api key
Thanks for your help. everything works now
