    Help file confing. js
    12 Posts 3 Posters 4.5k Views 3 Watching
    • G
      Gianluca
      Hello to all. I would like a help if possible on how to find a solution to my problem. After carrying out the steps for the installation of the Magic Mirror, at the start of the MM tells me that I have to configure the file confing.js
      How can I do ? where can I find the solution?
      • justjim1220J
        justjim1220 Module Developer @Gianluca
        @gianluca
        when you downloaded MagicMirror, you should have a folder named config
        in that folder, you should have a config.js.sample or a config.sample.js
        rename that file to config.js
        it should work then
        Jim Hallock - 1995
        • G
          Gianluca
          thank you so much!!! it works. But if I want to do it in Italian, I have to modify the Forms or find modules in Italian
          • justjim1220J
            @gianluca
            No problem, always glad to help.
            most modules and including MagicMirror should have an Italian translation
            At the top of the config file, just above modules: [
            You should find this…
            	language: "en",
            	timeFormat: 24,
            	units: "imperial",
            this is where you put in the code for your language. I think yours should be ‘it’
            Jim Hallock - 1995
            • G
              Gianluca
              Changed the confing, but only the calendar description changes me. So the rest should I change it? I would love to insert the weather module is difficult? are there any tutorials explaining how to insert the forms?
              justjim1220J 2 Replies Last reply Reply Quote 0
              • justjim1220J
                @gianluca
                Every module SHOULD have a sample config entry for them in the Readme file or on the main page of the modules
                Jim Hallock - 1995
                • justjim1220J
                  @gianluca
                  I just switched mine to Italian and the only module that changed was MMM-NOAA3 which is a really good weather module.
                  Jim Hallock - 1995
                  • G
                    Gianluca
                    I have difficulty entering the weather. I modified the form and configured the boundary. js but nothing does not appear to me. is there a tutorial that explains how to modify and insert the modules?
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @Gianluca
                      @gianluca said in Help file confing. js:
                      https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
                      • G
                        Gianluca
                        Hello, I’m vcerc with the weather. I execute the description of wuthnerground
                        I can not understand the reason that nion works for me.
                            module: "MMM-WunderGround",
                                apikey: "++++++++++++++", // private; don't share!
                                pws: "locid:NLXX8014;loctype:1", //culemborg
                                hourly: "1",
                                fctext: "1",
                                fcdaycount: "5",
                                fcdaystart: "0",
                                hourlyinterval: "3",
                                hourlycount: "2",
                                alerttime: 10000,
                                alerttruncatestring: "english:",
                        	roundTmpDecs: 1,
                        	UseCardinals: 0,
                        	layout: "horizontal",
                        	sysstat: 0
                        this is the module I put in confing.js while in the modules folder I inserted the MMM-wutherGround module. Should I be wrong?
                        in the APIKEY I put my KEY
                        in psw what dev or put? I do not have the password
                        • Mykle1M
                          @gianluca
                          I just used your example above, inserting my api key and it works. Be very careful when entering your api key
                          • G
                            Gianluca
                            Thanks for your help. everything works now
