    MMM-NetworkConnection
    19 Posts 8 Posters 14.1k Views 6 Watching
    • slametpsS Offline
      slametps
      Description:
      A MM-module to display network connection status (ping, download speed, upload speed) for MagicMirror2.
      This module combines internet-monitor and MMM-connection-status…
      Download:
      [card:slametps/MMM-NetworkConnection]
      Screenshot
      Initial Version
      regards,
      Slamet PS
      Cr4z33C 2 Replies Last reply Reply Quote 1
        bhepler Module Developer
        Hrm. I can’t get this to show up. I did get npm-speedtest to install, but the module isn’t appearing for me. I’m not receiving any error messages, but I’m also not seeing the header.
        		module: "MMM-NetworkConnections",
        		header: "Network Speeds",
        		position: "top_center",
        			updateInterval: 600000,
        			maxTime: 5000,
        			initialLoadDelay: 2500,
        			decimal: 1,
        			displayTextStatus: true,
        			animationSpeed: 2500
          AgP42 Project Sponsor Module Developer
          I try to monitor my internet connection as my WiFi disconnect a lot, but none of the avaliable modules (this one, but also the 2 originals ones “internet-monitor” and “MMM-connection-status”) are able to detect a disconnection…
          When the WiFi is properly working, then I have the values displayed correctly, but in case of connection lost (I remove the wifi key…), then the module continu to display previous valid values.
          I am on a RPI2 with WiFi USB key, can this be the origin of the issue ?
          Thanks in advance for any help :slightly_smiling_face:
          • E Offline
            epi
            Installed as in readme file, fails to show up. No errors in browser. Module is not working.
              Mykle1 Project Sponsor Module Developer @epi
              @epi said in MMM-NetworkConnection:
              Uhh, I just installed it and it works just fine.
              Post your config entry in a code block
              • E Offline
                epi
                That is very strange, as I see nothing. OK, my code
                		module: "MMM-NetworkConnection",
                			maxTime: 5000,
                			decimal: 1,
                  @epi
                  I copy and pasted your config entry and it fires right up. Did you follow the directions in the readme for installation and dependencies? Have you tried the module by itself? Have you modified any of the module files?
                  My terminal output upon launch:
                  • Sandy2503S Offline
                    Sandy2503
                    module: “MMM-NetworkConnection”,
                    @epi
                    change in your config.js the name of the module from
                    to
                    I think that is your problem.
                    Sandy
                      Mykle1 Project Sponsor Module Developer @Sandy2503
                      @sandy2503
                      Uhhh . . . . no.
                      • E Offline
                        epi
                        @Sandy2503 I changed to “-s” and still did not work.
                        @Mykle1 I followed the installation guide, incl. the dependencies. I did not modify anything. I tried the module alone (all other cfg removed), still did not work for me.
                        What is the installation folder for dependencies in your case?
                        Mykle1M 1 Reply Last reply Reply Quote -1
                          @epi
                          Dependencies should be installed by running npm install in the MMM-NetworkConnection directory
                          • E Offline
                            epi
                            Guys, can someone also make a simplified version? No need for internet speed metrics, just the ability to ping specific ip address and return as “internet is working” either “network down”?
                            • Y Offline
                              yawns Moderator @epi
                              Like this? https://github.com/sheyabernstein/MMM-connection-status
                              • E Offline
                                epi
                                • Cr4z33C Offline
                                  Cr4z33 @slametps
                                  @slametps here is the Italian translation if you want to add it.
                                  	"NETCONN_CONNECTED": "Connesso ad Internet",
                                  	"NETCONN_NOTCONNECTED": "Nessuna connessione ad Internet",
                                  	"NETCONN_MILLISECOND": "ms",
                                  	"NETCONN_NA": "ND",
                                  	"TXT_NETCONN": "CONNESSIONE DI RETE",
                                  	"TXT_NETCONN_DESC": "mostra lo stato di connessione ad Internet"
                                  • Cr4z33C Offline
                                    Cr4z33 @slametps
                                    @slametps I had long read at speedtest readme however I couldn’t figure out what to edit to have a different server selected as best/favourite server.
                                    These are the details of the wanted server:
                                    server url="http://speedtestrm1.telecomitalia.it/speedtest/upload.php" lat="41.9000" lon="12.5000" name="Rome" country="Italy" cc="IT" sponsor="Telecom Italia S.p.A." id="3243" host="speedtestrm1.telecomitalia.it:8080"
                                    slametpsS 1 Reply Last reply Reply Quote 0
                                    • slametpsS Offline
                                      slametps @Cr4z33
                                      @Cr4z33 said in MMM-NetworkConnection:
                                      Currently, the module is using default test server provided by speedtest-net node module. You should modify node_helper.js to add your desired test server.
                                      You can find how to add the options, in here.
                                      regards,
                                      Slamet PS
                                      • Cr4z33C Offline
                                        Cr4z33 @slametps
                                        @slametps that is where I looked at, but then I didn’t understand what file and what lines to edit.
                                        The problem is that the default server looks to be located in the US therefore showing a very high ping and low speed results isn’t really what someone is expecting from the module. ;)
                                        • Cr4z33C Offline
                                          Cr4z33 @Cr4z33
                                          @slametps at the end of the day I found finally some examples around, but everybody is reporting that setting a specific server somehow is not working (anymore?).
                                          The line should look like
                                          var test = speedTest({maxTime: 5000, serverId : "3243"});
                                          however this causes an error in node_helper.js at MM loading and the screen goes black until I end MM itself. :confused_face:
