    MMM-TracCar
    26 Posts 12 Posters 17.9k Views 12 Watching
    • A
      AgP42 Project Sponsor Module Developer
      Yes, they said it will be free minimum 12 month, so let’s see !
      In fact with the auto-start I didn’t see the log initially…
      To have clear logs only with TracCar I keep only this module on my config.js file and here are the console logs accordingly :
      > magicmirror@2.4.1 start /home/pi/MagicMirror
      > sh run-start.sh
      Starting MagicMirror: v2.4.1
      Loading config ...
      Loading module helpers ...
      Module helper loaded: MMM-TracCar
      All module helpers loaded.
      Server started ...
      Connecting socket for: MMM-TracCar
      Starting NodeHelper for MMM-TracCarmodule.
      { Error: listen EADDRINUSE 0.0.0.0:8080
      at Object._errnoException (util.js:1024:11)
      at _exceptionWithHostPort (util.js:1046:20)
      at Server.setupListenHandle [as _listen2] (net.js:1351:14)
      at listenInCluster (net.js:1392:12)
      at doListen (net.js:1501:7)
      at _combinedTickCallback (internal/process/next_tick.js:141:11)
      at process._tickCallback (internal/process/next_tick.js:180:9)
      at Function.Module.runMain (module.js:685:11)
      at startup (bootstrap_node.js:196:16)
      at bootstrap_node.js:622:3
      code: 'EADDRINUSE',
      errno: 'EADDRINUSE',
      syscall: 'listen',
      address: '0.0.0.0',
      port: 8080 }
      Launching application.
      The internet connection is working fine (all others modules can connect).
      But it’s true that I had to change the internet configuration of the MagicMirror in order to use Remote-Control module.
      To be sure this is not the cause of the error on your module, I re-use the inital config.js file, but still not working (but with different IP adresse on the log…) :
      > sh run-start.sh
      Loading config ...
      Server started ...
      { Error: listen EADDRINUSE 127.0.0.1:8080
      at GetAddrInfoReqWrap.doListen [as callback] (net.js:1501:7)
      at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:97:10)
      code: 'EADDRINUSE',
      syscall: 'listen',
      address: '127.0.0.1',
      port: 8080 }
      And here is my module configuration :
      module: 'MMM-TracCar',
      position: 'bottom_right',
      url: "demo5.traccar.org", // Traccar Server URL (free server @ http://demo5.traccar.org )
      username: "blabla@blabla.org", // Traccar Account username (email) (btw, there is a free account option too!) :)
      pass: "passworddddd", // Traccar Account Password
      gmapid: "keyxxxxxx", // Google Apps key
      map_width: "300", // width of the map element
      map_height: "400", // height of the map element
      map_border_radius: "10", // border radius of the map element (optional)
      map_shadow_color: "POWDERBLUE", // shadow color of the border element (optional)
      Maybe the error is coming from this line ? :
      But impossible to write the full URL due to the “//”…
      Also of course when I connect from my PC to the http://demo5.traccar.org with my username and password, I can see correctly the location of my phone (so the “TracCar” part is well configured)
      I hope I gave you enough infos :grinning_face_with_smiling_eyes:
      Thanks a lot !
      • A
        Solved ! :flushed_face:
        Oups…
        I “just” try with the full server address, including the http://, and it perfectly run…
        So my mistake, sorry !
        • asimhsiddA
          asimhsidd
          @AgP42
          Haha… glad your solved it yourself. Please give a thumbs-up on the git page…
          • A
            AgP42 Project Sponsor Module Developer @asimhsidd
            @asimhsidd done ! :slightly_smiling_face:
            • H
              hunty1980
              Great module - thank you for sharing.
              Is there anyway to start the Map in Satellite View as default and also adjust the default Zoom level. I want it to be a wider zoom from the current default.
              Thanks,
              G
              • I
                iwaldrum
                Bump - Is there a way adjust the default zoom level. I find that it is too zoomed in most cases.
                  maxs
                  Same question here about default zoom level. any option?
                  justjim1220J Mykle1M 2 Replies Last reply Reply Quote 0
                  • justjim1220J
                    justjim1220 Module Developer @maxs
                    @maxs @iwaldrum you can add zoom: 75; to your custum css file
                    Or you can use your keyboard and press Ctrl > - to zoom out or ctrl >Shift > + to zoom in
                    Jim Hallock - 1995
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @maxs
                      @maxs
                      https://forum.magicmirror.builders/topic/5619/how-to-find-and-use-key-commands-in-mm-for-absolute-beginners
                        maxs
                        @justjim1220 said in MMM-TracCar:
                        zoom: 75;
                        Sorry to tel, but that’s not what I meen. I just want to zoom out the traccar map window. I can’t find any think in the traccar.js file. I just don’t know. I’m absolute beginner.:smiling_face_with_halo:
                        @Mykle1 Thanks for sharing the link.
                        I 1 Reply Last reply Reply Quote 1
                        • I
                          iwaldrum @maxs
                          @maxs @justjim1220 I was looking for the samething… zoom level in the map… any luck or options for this?
                            JamesFargus
                            @iwaldrum hey I know this is really old, but if you comment out the lines in the .js file:
                            self.map.fitBounds(self.bounds);
                            self.map.panToBounds(self.bounds);
                            the map will not change zoom based on the object locations anymore. Hope this helps!
                              bl4ck4dd3r
                              This is a great plugin but for me it would be better if it didn’t rely on Google maps but instead used something like Leaflet
                              I may have a go at converting the map element of MMM-TracCar myself but my js coding is primative at best
                              :smirking_face:
                              • T
                                tangougou
                                hey i want to know how to change the time to refresh the map ,the marks ont the map was static,i want it change faster.
                                by the way ,i want to know your googlemapapi load type was synchronizing load or async loading.i was a Chinese,My English is not well ,So sorry about this . Thanks for your object.
                                • JerryPJ
                                  JerryP
                                  Hulp gevraagd…
                                  Goodmorning,
                                  I’m Jerry from Holland.
                                  First I like to say: great module!
                                  I woul’d like to use the module on my magic mirror to track and show my Carbagrun roadtrip at Home on my mirror.
                                  View questions I would like to ask
                                  *can you use openstreetmaps?
                                  *or maybe Google satelliet
                                  *google keeps showing errors (see pictures)
                                  *Is it possible to show the track line (route of the car)
                                  *the zoom level settings in the config does not work.
                                  Please help?!?!!
                                  -![0_1605953189378_4C8EE9DD-6B4D-4719-BB34-74C7243035D2.jpeg](Uploading 4%)
                                    maxs
                                    i hat also a lot of thinks I din’t like. So my solution is to run MMM-SmartWebDisplay, a internet page in your mirror and configure it to browse your traccar website. This is for me perfect working. So what you do on your traccar webpage is also possible on your mirror.
                                    JerryPJ 1 Reply Last reply Reply Quote 0
                                    • JerryPJ
                                      JerryP @maxs
                                      @maxs
                                      Hi, thanks for your reply. Can you send me your config?? So I can see what you mean, and how you did it.
                                      It would be great and super easy if that is the solution.
                                      Thanks again
                                        maxs
                                        @JerryP
                                        See my part of the config. Hope you have also success.
                                        Install the module MMM-SmartWebDisplay. Chance your config file, just put the right address of your traccar server.
                                        Wen all is ok, you get your login from the traccar website on your mirror.
                                        “module”: “MMM-SmartWebDisplay”,
                                        “pages”: {“main”: “bottom_left”},
                                        //position: “bottom_left”,
                                        “config”: {
                                        “height”:“320px”,
                                        “width”:“420px”,
                                        “updateInterval”: 0,
                                        “scrolling”: “no”,
                                        “displayStateInfos”: false,
                                        “NextURLInterval”: 0,
                                        “displayLastUpdate”: false,
                                        “url”: [“http://traccarserver.com”]
                                        • JerryPJ
                                          JerryP @maxs
                                          @maxs
                                          O Yes, it’s alive.
                                          Do you know if it’s possible to remove the borders ( “map” (kaart) above ) & (“appliances” (apparaten) below)
                                          And how do I process the login in the URL???
                                          Mij Config
                                          module: ‘MMM-SmartWebDisplay’,
                                          disabled: false, //false, true
                                          position: ‘bottom_right’, // This can be any of the regions.
                                          logDebug: false,
                                          height:“420px”,
                                          width:“520px”,
                                          updateInterval: 0,
                                          scrolling: “no”,
                                          displayLastUpdate: false,
                                          NextURLInterval: 0,
                                          url: [“http://demo.traccar.org”],
                                          alt text
                                            maxs
                                            @JerryP
                                            I get login by making a vnc connection to the mirror. Then it is possible to set user name / password on the mirror in the traccar window.
                                            I don’t remember how it was exactly. Wass playing whit it. but mark the remember me. than next time you loggin is automatic.
                                            The borders I don’t know.
