    MMM-Lunartic
    Scheduled Pinned Locked Moved Education
    266 Posts 30 Posters 553.7k Views 29 Watching
    • Mykle1M
      @cowboysdude
      True, but I did find it interesting.
        Pr05t3n
        https://www.moongiant.com/phase/today/
        http://lunaf.com/lunar-calendar/
        https://www.calendar-365.com/moon/current-moon-phase.html
        https://moonphases.co.uk/
        https://www.die.net/moon/
        https://www.starmessagesoftware.com/moonscreensaver/moon-phase-tonight.html
        Something like this?
        Mykle1M 1 Reply Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @Pr05t3n
          @pr05t3n said in MMM-Lunartic:
          Well, not really. I don’t think I was clear enough. Yes, these links are to websites that contain pictures of the moon but not directly to the pictures. I did dig into the first site and isolated the url to today’s moon phase picture. Try it.
          http://lunaf.com/img/moon/phase-13.png
          Tomorrow that url will change, as will the image name.
          The API url that is currently being used is static. It never changes. Only the image updates, not the url itself.
          So, that’s what we need. A url to a current image of the moon (not a website containing moon pictures) and it has to update just the image. I’ll look when I can. You can still look. :-)
          • bheplerB
            bhepler Module Developer
            This ought to keep @Mykle1 busy for a couple weeks at least: https://www.programmableweb.com/category/astronomy/api
            Mykle1M 2 Replies Last reply
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @bhepler
              @bhepler said in MMM-Lunartic:
              Haha, thanks b! I’ll take a look. :thumbsup:
              • Mykle1M
                @bhepler
                You do realize that I’ve done quite a few of those already? :-)
                bheplerB 1 Reply Last reply
                • bheplerB
                  bhepler Module Developer @Mykle1
                  @mykle1 - Yes. Yes, I have. But I’m hoping you have an addiction to catc… er, code 'em all.
                  • Mykle1M
                    I have several. ;-)
                    I threw together a companion module to MMM-MARS using one of the API’s from your link. For everyone that needs to know the weather on Mars. (Me). I don’t know how reliable the data is going to be but I learned how to make an array (in the node_helper) and push it to the the module.js. I needed to do that in order to rotate the data. So, the simplest of modules but very rewarding because I learned something new.
                    https://github.com/mykle1/MMM-MARS-Weather
                    It’s only the very last line that rotates through 8 objects of data. SolDate, season, min and max air temp, atmospheric conditions (Sunny), min and max ground temp, sunrise and sunset at the rover’s locaton. A little css put it right under MARS
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @qu1que
                      @qu1que said in MMM-Lunartic:
                      I can’t wait for next full moon to hear the wolf audio.
                      Your wait should be over. MMM-Lunartic just reported a full moon accurately and played the howling wolf sound file as expected.
                      I forgot I added that and was surprised when the audio played. Fun and pretty cool!
                      qu1queQ 2 Replies Last reply
                      • rudibaraniR
                        rudibarani Project Sponsor
                        Dear @Mykle1,
                        since yesterday, I do not get the current picture of the moon anymore, although I did not touch the MMM-Lunartic config. If I do, I can display other info - but not the current image.
                        I completely removed and reinstalled the module - but that did not solve the problem. I can open the direct link to the current NASA picture from the .js file - so it does not seem, that my IP is blocked from their side.
                        Do you have any idea, how to get the current picture of the moon back?
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @rudibarani
                          @rudibarani said in MMM-Lunartic:
                          Yes, I am aware of this problem and am working to correct it. I asked for help in a topic. Hopefully someone will give me some input on fixing it. Otherwise, it will be some time before I can get that working again. In the meantime, don’t use “current or DayNight” as your image in the config entry
                          • Mykle1M
                            This is what I’m up against at the moment. Try contacting the US Navy and telling them their API for moon images is not configured properly. This should be fun.
                            rudibaraniR 1 Reply Last reply
                            • rudibaraniR
                              rudibarani Project Sponsor @Mykle1
                              @mykle1 I also had to set an “exception”, as the HTTPS Certificate does not match. Maybe there is an option to ignore this threat.
                              • Mykle1M
                                @rudibarani
                                Yeah, I’m going to avoid using an exception, even if I knew how to do that. As you know, (you messaged me) the API started working again and then was gone again for a short period of time. This is encouraging. I think it means they are working on fixing the API. I’m working on a temporary fix but it will take some time. Lets hope they fix the API before I finish the fix.
                                • qu1queQ
                                  qu1que Project Sponsor @Mykle1
                                  • qu1queQ
                                    @mykle1
                                    Hahaha, I’ve heard it two or three days days ago, on last full moon. Awesome!! My sister heard it and she was scared with the wolf sound, hahaha.
                                    • Mykle1M
                                      @qu1que
                                      That’s fantastic. However, there is a problem with the API for the images so the module is having trouble at the moment. I’m looking at some options and @rudibarani has been assisting but I’m still hoping they correct the issue soon.
                                      qu1queQ 1 Reply Last reply
                                      • qu1queQ
                                        @mykle1
                                        Yes, I realised of that module not working, but at the same time, the MMM-SunRiseSet module doesn’t work too. Maybe is the same problem?
                                        • Mykle1M
                                          Yes, same API, same problem. I’m hoping they fix the API soon. Otherwise, a work-around might be necessary.
                                          • Mykle1M
                                            Temporary fix has been issued
                                            https://forum.magicmirror.builders/topic/9193/mmm-lunartic-fixed-temporarily
                                            • 13
                                            • 14
                                            • 5 / 14
