    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 933.2k Views 74 Watching
    • H
      Hein-Jan
      @j-e-f-f ,
      I am also stuck at “Loading” actually it says “Bezig met laden…” which is Dutch for “Loading”.
      I ran the “git clone…”, switched to the “MMM-DarkSkyForecast” directory, and ran the NPM Install.
      I do get this warning: “npm WARN mmm-darkskyforecast@1.0.0 No repository field.”, but I do not know how to act upon it.
      The module is making calls to DarkSky, I see that in the Api usage.
      The logs show no error.
      This is the config:
        			module: "MMM-DarkSkyForecast",
        			header: "Weersverwachting",
      //  			classes: "default everyone",
        			disabled: false,
          				apikey: "XXXXXXXXXXXXX",
          				latitude: "51.5096192",
          				longitude: "5.6364183",
          				iconset: "1c",
      //				maxHourliesToShow: 4,
      //				maxDailiesToShow: 4,
      //				useAnimatedIcons: true,
          				concise: false,
      //				label_timeFormat: "k[h]",
          				forecastLayout: "table"
      I am not sure were I went wrong. Can you provide help?
      Kind Regards,
      Hein-Jan
      • karsten13K
        karsten13
        Same here with “Loading” and nothing happens.
        Seems to be a problem with lon/lat.
        If i provide the example lon/lat it works.
          baschke
          looks awesome but doesn’t work with the coordinates of Berlin. It says “loading” but nothing happens.
            header: "Weather",
            disabled: false,
              apikey: "db7derpderpderp214eae3b0f6e",
              latitude: "52.520008",
              longitude: "13.404954",
              iconset: "2m",
              concise: false,
              forecastLayout: "table",
              language: "de"
          • K
            krouton
            I posted this on the GitHub page;
            When I use the default Long and Lat, the module loads. London works as does Vancouver and New York however when trying Hawaii, Sydney, Paris, Cape Town, Moscow, Melbourne, and Wellington, the module will not load. Using https://www.latlong.net/ for Long and Lat.
            When I use the same Long and Lat in this module that works with the Forecast.io module, the module won’t load. At first, I thought it was southern hemisphere’s (given the Lat is a ‘negative’ number) but that doesn’t appear to be the cause.
            • rudibaraniR
              rudibarani Project Sponsor
              @baschke, @karsten13, @Hein-Jan
              @j-e-f-f has updated the module on GitHub. Go to the module folder and update it via git pull.
              If the error still persists, leave out line
              concise: false,
              from the config file. That solved it for me in the prior version.
              karsten13K 1 Reply Last reply
                cyberphox
                I had the same loading issue after just installing it…but leaving out the concise line worked for me too
                • lavolp3L
                  lavolp3 Module Developer
                  Beautiful module!
                  A bit too beautiful in my opinion since I’m currently putting a lot of work into MMM-forecast-io :-D
                  How to troubleshoot modules
                  MMM-soccer v2, MMM-AVStock
                    A Former User
                    MMM-WeatherBackground supports MMM-DarkSkyForecast now. (Just set source as "MMM-DarkSkyForecast")
                    Thanks @j-e-f-f again.
                      jasondreher
                      Awesome!!! Just want I want after WeatherUndergrown stops its free api.
                      I have it working but it takes up my entire screen even thought its set to top_right. And I cant get it to take any config changes, like table vs tiled.
                        header: "Weather",
                        disabled: false,
                          apikey: "xxxx",
                          latitude: "xxxx",
                          longitude: "-xxxx",
                          iconset: "4c",
                          concise: false,
                      Any idea why this would happen?
                      J 1 Reply Last reply
                      • karsten13K
                        karsten13 @rudibarani
                        @rudibarani
                            concise: false,
                        Had already the newest version, but leaving out concise: false did the trick. Thanks!
                          j.e.f.f Project Sponsor Module Developer @jasondreher
                          @jasondreher said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                          @rudibarani said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                          concise: false,
                          Both of the above issues are now fixed. Do a git pull for the latest version and restart Magic Mirror.
                          By default the width is fixed to 300px. If you wish to override this, you can do so in your custom.css file as follows:
                          .MMM-DarkSkyForecast .module-content {
                            width: 500px; /* adjust this to taste */
                            j.e.f.f Project Sponsor Module Developer @BKeyport
                            @bkeyport said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                            Does it handle midnight properly in 12 hour mode? So darned tired of the 0am stuff the other DarkSky one has. ;)
                            I’m using moment.js to format the time display, and midnight gets displayed properly by default. You can also override the default display style for time with the parameter label_timeFormat. Provide any valid formatting string you can find from the moment.js docs: https://momentjs.com/docs/#/displaying/
                              jasondreher @j.e.f.f
                              @j-e-f-f
                              All works great!! Love the module! Thanks
                                colel83
                                I was using your MyWeather module and was really bummed that weather underground was shutting down their free API. I just found your new module last night and I am ecstatic to be able to switch over to this one. Everything seems to be working well except that I have a couple of Moon icons for the forecast table. 3 of the 7 days are showing moon/clouds instead of sun/clouds. Is that something I can fix or is it on Dark Sky’s end?
                                  j.e.f.f Project Sponsor Module Developer @colel83
                                  @colel83 Do you have a screenshot?
                                    colel83
                                    Sure. It’s only showing 2 incorrect icons tonight.
                                      shbatm Module Developer
                                      @j-e-f-f Awesome module! Great replacement for MMM-Wunderground.
                                      Is there a way to turn off the total precipitation and max wind speed for the forecasts in the table, without turning it off for the current conditions?
                                        j.e.f.f Project Sponsor Module Developer @shbatm
                                        @shbatm You can do this in your custom.css file. First make sure both showPrecipitation and showWind are set to true in your config, and showForecastTableColumnHeaderIcons is to false.
                                        Next, add the following to your custom.css file:
                                        .MMM-DarkSkyForecast .wrapper.tiled .forecast-container .forecast-item .precipitation-container,
                                        .MMM-DarkSkyForecast .wrapper.tiled .forecast-container .forecast-item .wind-container,
                                        .MMM-DarkSkyForecast .wrapper.table .forecast-container .forecast-item .precipitation-container,
                                        .MMM-DarkSkyForecast .wrapper.table .forecast-container .forecast-item .wind-container {
                                            display: none;
                                          @j-e-f-f Thanks. I got it with the following. I was just wondering if you had a config option for it that I missed.
                                          .MMM-DarkSkyForecast .forecast-container .wind-gusts,
                                          .MMM-DarkSkyForecast .forecast-container .accumulation {
                                              display: none !important;
                                          • michael5rM
                                            michael5r Module Developer
                                            Great module - I really liked the fact that you had everything classed out, so it was super easy to manipulate the UI without having to screw with your JS.
                                            Looks very nice on my mirror:
                                            C C 2 Replies Last reply
                                            • 16
                                            • 17
                                            • 2 / 17
