    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 915.5k Views 74 Watching
      colel83
      Sure. It’s only showing 2 incorrect icons tonight.
        shbatm Module Developer
        @j-e-f-f Awesome module! Great replacement for MMM-Wunderground.
        Is there a way to turn off the total precipitation and max wind speed for the forecasts in the table, without turning it off for the current conditions?
          j.e.f.f Project Sponsor Module Developer @shbatm
          @shbatm You can do this in your custom.css file. First make sure both showPrecipitation and showWind are set to true in your config, and showForecastTableColumnHeaderIcons is to false.
          Next, add the following to your custom.css file:
          .MMM-DarkSkyForecast .wrapper.tiled .forecast-container .forecast-item .precipitation-container,
          .MMM-DarkSkyForecast .wrapper.tiled .forecast-container .forecast-item .wind-container,
          .MMM-DarkSkyForecast .wrapper.table .forecast-container .forecast-item .precipitation-container,
          .MMM-DarkSkyForecast .wrapper.table .forecast-container .forecast-item .wind-container {
              display: none;
            @j-e-f-f Thanks. I got it with the following. I was just wondering if you had a config option for it that I missed.
            .MMM-DarkSkyForecast .forecast-container .wind-gusts,
            .MMM-DarkSkyForecast .forecast-container .accumulation {
                display: none !important;
            • michael5rM Offline
              michael5r Module Developer
              Great module - I really liked the fact that you had everything classed out, so it was super easy to manipulate the UI without having to screw with your JS.
              Looks very nice on my mirror:
              C C 2 Replies Last reply Reply Quote 1
                Arjan Project Sponsor
                first of all, great that you made a new weather module like MMM-WunderGround. I really liked that one.
                I have a problem with hourlyForecastInterval. If I don’t put it in de config and leave it to the default and put maxHourliesToShow : “6”, in the config, than I receive 6 forecasts with 3 hours apart.
                When I put hourlyForecastInterval to 1 or 2 I only get 2 forecasts that are 10 hours apart.
                Is this a problem or am I doing something wrong?
                  j.e.f.f Project Sponsor Module Developer @Arjan
                  @arjan let me look into this. Doesn’t sound right…
                  • K Offline
                    kwabenalexx
                    Please help.Not sure what I’m doing wrong here but cant seem to have the module show up on the screen. 0_1544341171559_dark.JPG 0_1544341182053_screen.JPG
                      j.e.f.f Project Sponsor Module Developer @kwabenalexx
                      @kwabenalexx Your exact config works for me as-is. But I noticed it looks like you also have another weather module running. I wonder if something is clashing… can you try to disable the other one and try DarkSky again?
                      Also, did you run npm install in the MMM-DarkSkyForecast directory?
                      • K Offline
                        kwabenalexx @j.e.f.f
                        @j-e-f-f said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                        MM
                        Thanks for the help. I deleted the other weather module and it worked. Now i see my units are in Km/h instead of miles/hr and the temperature readings are different from my local weather alerts my area
                        michael5rM 1 Reply Last reply Reply Quote 0
                          michael5r Module Developer @kwabenalexx
                          @kwabenalexx Add:
                          units: 'us'
                          to the DarkSkyForecast config to switch to imperial units. It’s the default for darksky, but not the default for this module.
                          K J 2 Replies Last reply Reply Quote 0
                          • K Offline
                            kwabenalexx @michael5r
                            @michael5r i added that to the config file and i get ‘‘Please create a config File’’ page
                            • K Offline
                              kwabenalexx
                              it’s fixed. thanks for all your help. i had to add a comma (,)
                                j.e.f.f Project Sponsor Module Developer @michael5r
                                @michael5r said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                                Add:
                                units: ‘us’
                                Yeah I did that intentionally because I’m Canadian and Imperial units make no sense to me ;)
                                  Hi folks
                                  Just wanted to let you know that with the latest update of this module, I’ve modified it to use the Nunjucks HTML templating system. This means as of version 1.6 of MMM-DarkSkyForecast, you’ll need to run it on MagicMirror 2.2.0 or later. It won’t run at all on older versions.
                                  If you’re running an older version of MagicMirror and you still want to use my module, then please download the source for version 1.5 from here:
                                  https://github.com/jclarke0000/MMM-DarkSkyForecast/releases/tag/v1.5
                                  Note that I will not update v1.5 with any new features or bug fixes. All future development work will be done against v1.6 and above. If you want the latest and greatest, then you’ll need to update MagicMirror.
                                    cyberphox @michael5r
                                      Smotx
                                      hello,
                                      how to reduce space between lines ?
                                      alt text
                                        j.e.f.f Project Sponsor Module Developer @Smotx
                                        @smotx said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                                        hello,
                                        alt text
                                        I’m assuming you mean the lines in the forecast when using the table layout. Here’s how:
                                        .MMM-DarkSkyForecast .wrapper.table .forecast-container .forecast-item > span,
                                        .MMM-DarkSkyForecast .wrapper.table .forecast-container .header-row > span {
                                          height: 40px;  /* Adjust this to taste */
                                        At some point you will be limited by the size of the icons, in which case if you want to go smaller, you can do this:
                                        .MMM-DarkSkyForecast .wrapper.table .forecast-container .forecast-item .forecast-icon {
                                          width: 30px;
                                          height: 30px; /* adjust these to taste */
                                        Finally, if it’s still not small enough for you, make the font size smaller like so:
                                          font-size: 17px;  /* Adjust this to taste */
                                          Messel
                                          Hi all, I love this module, but I updated to the latest version today, and my main icon disappeared. It just shows the temperature, no animated sun or (most likely) rain icon.
                                          Can anyone see what is wrong?
                                          This is my config:
                                          module: “MMM-DarkSkyForecast”,
                                          header: “Værmeldingen”,
                                          position: “top_right”,
                                          classes: “default everyone”,
                                          disabled: false,
                                          apikey: “XXXX”,
                                          latitude: “62.737709”,
                                          longitude: “7.160910”,
                                          maxDailiesToShow: “2”,
                                          showHourlyForecast: false,
                                          label_days: [“Søndag”, “Mandag”, “Tirsdag”, “Onsdag”, “Torsdag”, “Fredag”, “Lørdag”],
                                          label_high: “Høy”,
                                          label_low: “Lav”,
                                          iconset: “3c”,
                                          concise: false,
                                          forecastLayout: “tiled”
                                            Smotx @j.e.f.f
                                            @j-e-f-f
                                            Thx but, i have changed 3 settings on /home/pi/MagicMirror/modules/MMM-DarkSkyForecast/MMM-DarkSkyForecast.css
                                            after reboot nothing has changed :(
                                            it’s not MMM-DarkSkyForecast.css ?
                                            • 16
                                            • 17
                                            • 2 / 17
