    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 918.1k Views 74 Watching
      A Former User
      MMM-WeatherBackground supports MMM-DarkSkyForecast now. (Just set source as "MMM-DarkSkyForecast")
      Thanks @j-e-f-f again.
        jasondreher
        Awesome!!! Just want I want after WeatherUndergrown stops its free api.
        I have it working but it takes up my entire screen even thought its set to top_right. And I cant get it to take any config changes, like table vs tiled.
          module: "MMM-DarkSkyForecast",
          header: "Weather",
          classes: "default everyone",
          disabled: false,
            apikey: "xxxx",
            latitude: "xxxx",
            longitude: "-xxxx",
            iconset: "4c",
            concise: false,
            forecastLayout: "table"
        Any idea why this would happen?
        • karsten13K Offline
          karsten13 @rudibarani
          @rudibarani
          @baschke, @karsten13, @Hein-Jan
          @j-e-f-f has updated the module on GitHub. Go to the module folder and update it via git pull.
          If the error still persists, leave out line
              concise: false,
          from the config file. That solved it for me in the prior version.
          Had already the newest version, but leaving out concise: false did the trick. Thanks!
            j.e.f.f Project Sponsor Module Developer @jasondreher
            @jasondreher said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
            @rudibarani said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
            concise: false,
            Both of the above issues are now fixed. Do a git pull for the latest version and restart Magic Mirror.
            By default the width is fixed to 300px. If you wish to override this, you can do so in your custom.css file as follows:
            .MMM-DarkSkyForecast .module-content {
              width: 500px; /* adjust this to taste */
              j.e.f.f Project Sponsor Module Developer @BKeyport
              @bkeyport said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
              Does it handle midnight properly in 12 hour mode? So darned tired of the 0am stuff the other DarkSky one has. ;)
              I’m using moment.js to format the time display, and midnight gets displayed properly by default. You can also override the default display style for time with the parameter label_timeFormat. Provide any valid formatting string you can find from the moment.js docs: https://momentjs.com/docs/#/displaying/
                jasondreher @j.e.f.f
                @j-e-f-f
                All works great!! Love the module! Thanks
                  colel83
                  I was using your MyWeather module and was really bummed that weather underground was shutting down their free API. I just found your new module last night and I am ecstatic to be able to switch over to this one. Everything seems to be working well except that I have a couple of Moon icons for the forecast table. 3 of the 7 days are showing moon/clouds instead of sun/clouds. Is that something I can fix or is it on Dark Sky’s end?
                    j.e.f.f Project Sponsor Module Developer @colel83
                    @colel83 Do you have a screenshot?
                      colel83
                      Sure. It’s only showing 2 incorrect icons tonight.
                        shbatm Module Developer
                        @j-e-f-f Awesome module! Great replacement for MMM-Wunderground.
                        Is there a way to turn off the total precipitation and max wind speed for the forecasts in the table, without turning it off for the current conditions?
                          j.e.f.f Project Sponsor Module Developer @shbatm
                          @shbatm You can do this in your custom.css file. First make sure both showPrecipitation and showWind are set to true in your config, and showForecastTableColumnHeaderIcons is to false.
                          Next, add the following to your custom.css file:
                          .MMM-DarkSkyForecast .wrapper.tiled .forecast-container .forecast-item .precipitation-container,
                          .MMM-DarkSkyForecast .wrapper.tiled .forecast-container .forecast-item .wind-container,
                          .MMM-DarkSkyForecast .wrapper.table .forecast-container .forecast-item .precipitation-container,
                          .MMM-DarkSkyForecast .wrapper.table .forecast-container .forecast-item .wind-container {
                              display: none;
                            @j-e-f-f Thanks. I got it with the following. I was just wondering if you had a config option for it that I missed.
                            .MMM-DarkSkyForecast .forecast-container .wind-gusts,
                            .MMM-DarkSkyForecast .forecast-container .accumulation {
                                display: none !important;
                            • michael5rM Offline
                              michael5r Module Developer
                              Great module - I really liked the fact that you had everything classed out, so it was super easy to manipulate the UI without having to screw with your JS.
                              Looks very nice on my mirror:
                              C C 2 Replies Last reply Reply Quote 1
                                Arjan Project Sponsor
                                first of all, great that you made a new weather module like MMM-WunderGround. I really liked that one.
                                I have a problem with hourlyForecastInterval. If I don’t put it in de config and leave it to the default and put maxHourliesToShow : “6”, in the config, than I receive 6 forecasts with 3 hours apart.
                                When I put hourlyForecastInterval to 1 or 2 I only get 2 forecasts that are 10 hours apart.
                                Is this a problem or am I doing something wrong?
                                  j.e.f.f Project Sponsor Module Developer @Arjan
                                  @arjan let me look into this. Doesn’t sound right…
                                  • K Offline
                                    kwabenalexx
                                    Please help.Not sure what I’m doing wrong here but cant seem to have the module show up on the screen. 0_1544341171559_dark.JPG 0_1544341182053_screen.JPG
                                      j.e.f.f Project Sponsor Module Developer @kwabenalexx
                                      @kwabenalexx Your exact config works for me as-is. But I noticed it looks like you also have another weather module running. I wonder if something is clashing… can you try to disable the other one and try DarkSky again?
                                      Also, did you run npm install in the MMM-DarkSkyForecast directory?
                                      • K Offline
                                        kwabenalexx @j.e.f.f
                                        @j-e-f-f said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                                        MM
                                        Thanks for the help. I deleted the other weather module and it worked. Now i see my units are in Km/h instead of miles/hr and the temperature readings are different from my local weather alerts my area
                                        michael5rM 1 Reply Last reply Reply Quote 0
                                          michael5r Module Developer @kwabenalexx
                                          @kwabenalexx Add:
                                          units: 'us'
                                          to the DarkSkyForecast config to switch to imperial units. It’s the default for darksky, but not the default for this module.
                                          K J 2 Replies Last reply Reply Quote 0
                                          • K Offline
                                            kwabenalexx @michael5r
                                            @michael5r i added that to the config file and i get ‘‘Please create a config File’’ page
                                            • 16
                                            • 17
                                            • 2 / 17
