Problem server client configuration
Hi all
I have a MM on my Ubuntu server and it seems to work fine, i can watch on 192.168.x.x:8080 on my browser.
Now the question is…the only way to watch the mirror on a Raspberry pi3 client is by chromium or there is a way with electron ?
I tried to change my mm.sh with: node clientonly --address 192.168.2.100 --port 8080 but I got error:pi@raspberrypi:~/MagicMirror $ node clientonly --address 192.168.2.100 --port 8080
Client:
(electron:1213): Gtk-WARNING **: cannot open display:
There something wrong. The clientonly is not running code 1Some help to solve ?
@akkor Are you trying to start the MagicMirror via an
SSHconnection?You can’t start an MagicMirror instance via
SSH: https://github.com/MichMich/MagicMirror#installation -
@akkor Ok, check the log with the following command:
pm2 log mmOn the top you will see the last 15 lines of the error log.
This post is deleted! -
@idoodler
This is the answerpi@raspberrypi:~ $ pm2 log mm [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option) /home/pi/.pm2/logs/mm-error.log last 15 lines: 0|mm | (electron:2017): Gtk-WARNING **: cannot open display: 0|mm | Client: 0|mm | (electron:2027): Gtk-WARNING **: cannot open display: 0|mm | Client: 0|mm | (electron:2037): Gtk-WARNING **: cannot open display: 0|mm | Client: 0|mm | (electron:2047): Gtk-WARNING **: cannot open display: 0|mm | Client: 0|mm | (electron:2057): Gtk-WARNING **: cannot open display: 0|mm | Client: 0|mm | (electron:2067): Gtk-WARNING **: cannot open display: 0|mm | Client: 0|mm | (electron:2077): Gtk-WARNING **: cannot open display: 0|mm | Client: 0|mm | (electron:2093): Gtk-WARNING **: cannot open display: -
Pls help I cannot find any solution
if you are trying to start over an ssh session, you need to add this before the node clientonly
if [ -z “$DISPLAY” ]; then #If not set DISPLAY is SSH remote or tty
export DISPLAY=:0 # Set by default display
fi -
@akkor - Ugh. Why would you want to use Electron if you didn’t have to? There’s already a web browser on your Pi. Just point it at the MM server and be done with it.
I’ve learned that you can get Chromium to start in kiosk mode at a particular URL with about an hour of research and testing. Minimal swearing was involved.
@bhepler Electron is already a premade solution that works great. However using Chromium in Kiosk mode is also a nice and easy solution. And it may solve the issue here.
@Akkor How to open Chromium in kioksmode on startup: https://raspberrypi.stackexchange.com/questions/40631/setting-up-a-kiosk-with-chromium
@idoodler @bhepler
I Have setup chromium to autostart and it’s ok
But I would like use Electron to use the voice command on client like this one https://github.com/mykle1/Hello-Lucy or https://github.com/joanaz/MMM-MirrorMirrorOnTheWall but I don’t know if it’s doable in server/client mode -
ok so wait for @Mykle1
@macnice Hi, is your issue related to the problem described in this thread? You May want to create a new thread if the issue are not related.
@idoodler said in Problem server client configuration:
I don’t think you can use Hello-Lucy in client mode.
But I bet the developer @Mykle1 knows it.I never even thought about trying it. I just run standard installations. If @idoodler doesn’t think it will work, it probably won’t. However, you could always try for yourself.
@mykle1 I am currently unable to test it. I quickly checked your code on my phone, but I didn‘t quite got your code :flushed_face:
I am curious, how did you make the voice recognition?
It could be fine if someone really skilled test Hello Lucy server/client mode
I didn’t mean that YOU should test it. I meant that @Akkor should test it as it is he that is looking for that functionality.
I didn’t. MMM-voice was already written by @strawberry-3-141. It’s a fantastic piece of software. I just made some additions/modifications to original so that I could hide/show individual modules, hide/show pages of modules, hide show all modules, turn the display on and off, audio, all through the use of notifications. I use it every day for a year now. It’s stable, very fast and does exactly what I want it to do.
@Mykle1
I could test but I need your assistance 'couse I’m not a programmer
I’m just good following guide… :(
