    Problem server client configuration
    21 Posts 6 Posters 11.5k Views 5 Watching
    • idoodlerI Offline
      idoodler Module Developer @bhepler
      @bhepler Electron is already a premade solution that works great. However using Chromium in Kiosk mode is also a nice and easy solution. And it may solve the issue here.
      @Akkor How to open Chromium in kioksmode on startup: https://raspberrypi.stackexchange.com/questions/40631/setting-up-a-kiosk-with-chromium
        Akkor
        @idoodler @bhepler
        I Have setup chromium to autostart and it’s ok
        But I would like use Electron to use the voice command on client like this one https://github.com/mykle1/Hello-Lucy or https://github.com/joanaz/MMM-MirrorMirrorOnTheWall but I don’t know if it’s doable in server/client mode
        idoodlerI 1 Reply Last reply Reply Quote 0
        • idoodlerI Offline
          idoodler Module Developer @Akkor
          @akkor I don’t think you can use Hello-Lucy in client mode.
          But I bet the developer @Mykle1 knows it.
            Akkor
            ok so wait for @Mykle1
              macnice
              • idoodlerI Offline
                idoodler Module Developer @macnice
                @macnice Hi, is your issue related to the problem described in this thread? You May want to create a new thread if the issue are not related.
                  Mykle1 Project Sponsor Module Developer @idoodler
                  @idoodler said in Problem server client configuration:
                  @Akkor ok so wait for @Mykle1
                  I never even thought about trying it. I just run standard installations. If @idoodler doesn’t think it will work, it probably won’t. However, you could always try for yourself.
                  • idoodlerI Offline
                    idoodler Module Developer @Mykle1
                    @mykle1 I am currently unable to test it. I quickly checked your code on my phone, but I didn‘t quite got your code :flushed_face:
                    I am curious, how did you make the voice recognition?
                      Akkor
                      It could be fine if someone really skilled test Hello Lucy server/client mode
                        I didn’t mean that YOU should test it. I meant that @Akkor should test it as it is he that is looking for that functionality.
                        I didn’t. MMM-voice was already written by @strawberry-3-141. It’s a fantastic piece of software. I just made some additions/modifications to original so that I could hide/show individual modules, hide/show pages of modules, hide show all modules, turn the display on and off, audio, all through the use of notifications. I use it every day for a year now. It’s stable, very fast and does exactly what I want it to do.
                          Akkor
                          @Mykle1
                          I could test but I need your assistance 'couse I’m not a programmer
                          I’m just good following guide… :(
                            Mykle1 Project Sponsor Module Developer @Akkor
                            @akkor said in Problem server client configuration:
                            Why I think it won’t work. You’ll be running MM and MMM-voice on the server machine. The client machine will only have a browser pointed at MM running on the server machine. The client has no way of accepting the voice commands because only the browser is running.
                            Now, if you had a microphone (at the client machine) with a cable that reached all the way to where the server machine is . . . :)
