    Problem server client configuration
    21 Posts 6 Posters 12.2k Views 5 Watching
    • idoodlerI
      idoodler Module Developer @Akkor
      @akkor Are you trying to start the MagicMirror via an SSH connection?
      You can’t start an MagicMirror instance via SSH: https://github.com/MichMich/MagicMirror#installation
      • A
        Akkor
        @idoodler I have tried to start changing the mm.sh
        This is the command I’ve put in:
        node clientonly --address 192.168.2.100 --port 8080
        but when I restart raspberry the system show me only the desktop and MM seems don’t start
        idoodlerI 1 Reply Last reply
        • idoodlerI
          @akkor Ok, check the log with the following command: pm2 log mm
          On the top you will see the last 15 lines of the error log.
          • A
            Akkor
            • A
              Akkor
              @idoodler
              This is the answer
              pi@raspberrypi:~ $ pm2 log mm
              [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
              0|mm       | (electron:2017): Gtk-WARNING **: cannot open display:
              0|mm       | Client:
              0|mm       | (electron:2027): Gtk-WARNING **: cannot open display:
              0|mm       | Client:
              0|mm       | (electron:2037): Gtk-WARNING **: cannot open display:
              0|mm       | Client:
              0|mm       | (electron:2047): Gtk-WARNING **: cannot open display:
              0|mm       | Client:
              0|mm       | (electron:2057): Gtk-WARNING **: cannot open display:
              0|mm       | Client:
              0|mm       | (electron:2067): Gtk-WARNING **: cannot open display:
              0|mm       | Client:
              0|mm       | (electron:2077): Gtk-WARNING **: cannot open display:
              0|mm       | Client:
              0|mm       | (electron:2093): Gtk-WARNING **: cannot open display:
              • A
                Akkor
                Pls help I cannot find any solution
                  if you are trying to start over an ssh session, you need to add this before the node clientonly
                  if [ -z “$DISPLAY” ]; then #If not set DISPLAY is SSH remote or tty
                  export DISPLAY=:0 # Set by default display
                  fi
                    bhepler Module Developer @Akkor
                    @akkor - Ugh. Why would you want to use Electron if you didn’t have to? There’s already a web browser on your Pi. Just point it at the MM server and be done with it.
                    I’ve learned that you can get Chromium to start in kiosk mode at a particular URL with about an hour of research and testing. Minimal swearing was involved.
                    • idoodlerI
                      idoodler Module Developer @bhepler
                      @bhepler Electron is already a premade solution that works great. However using Chromium in Kiosk mode is also a nice and easy solution. And it may solve the issue here.
                      @Akkor How to open Chromium in kioksmode on startup: https://raspberrypi.stackexchange.com/questions/40631/setting-up-a-kiosk-with-chromium
                      • A
                        Akkor
                        @idoodler @bhepler
                        I Have setup chromium to autostart and it’s ok
                        But I would like use Electron to use the voice command on client like this one https://github.com/mykle1/Hello-Lucy or https://github.com/joanaz/MMM-MirrorMirrorOnTheWall but I don’t know if it’s doable in server/client mode
                        • idoodlerI
                          @akkor I don’t think you can use Hello-Lucy in client mode.
                          But I bet the developer @Mykle1 knows it.
                          Mykle1M 1 Reply Last reply
                          • A
                            Akkor
                            ok so wait for @Mykle1
                              macnice
                              • idoodlerI
                                idoodler Module Developer @macnice
                                @macnice Hi, is your issue related to the problem described in this thread? You May want to create a new thread if the issue are not related.
                                • Mykle1M
                                  Mykle1 Project Sponsor Module Developer @idoodler
                                  @idoodler said in Problem server client configuration:
                                  @Akkor ok so wait for @Mykle1
                                  I never even thought about trying it. I just run standard installations. If @idoodler doesn’t think it will work, it probably won’t. However, you could always try for yourself.
                                  • idoodlerI
                                    idoodler Module Developer @Mykle1
                                    @mykle1 I am currently unable to test it. I quickly checked your code on my phone, but I didn‘t quite got your code :flushed_face:
                                    I am curious, how did you make the voice recognition?
                                    • A
                                      Akkor
                                      It could be fine if someone really skilled test Hello Lucy server/client mode
                                      • Mykle1M
                                        I didn’t mean that YOU should test it. I meant that @Akkor should test it as it is he that is looking for that functionality.
                                        I didn’t. MMM-voice was already written by @strawberry-3-141. It’s a fantastic piece of software. I just made some additions/modifications to original so that I could hide/show individual modules, hide/show pages of modules, hide show all modules, turn the display on and off, audio, all through the use of notifications. I use it every day for a year now. It’s stable, very fast and does exactly what I want it to do.
                                        Reply Quote 2
                                        • A
                                          Akkor
                                          @Mykle1
                                          I could test but I need your assistance 'couse I’m not a programmer
                                          I’m just good following guide… :(
                                          • Mykle1M
                                            Mykle1 Project Sponsor Module Developer @Akkor
                                            @akkor said in Problem server client configuration:
                                            Why I think it won’t work. You’ll be running MM and MMM-voice on the server machine. The client machine will only have a browser pointed at MM running on the server machine. The client has no way of accepting the voice commands because only the browser is running.
                                            Now, if you had a microphone (at the client machine) with a cable that reached all the way to where the server machine is . . . :)
