    Problem server client configuration
    21 Posts 6 Posters 11.2k Views 5 Watching
      Akkor
      Hi all
      I have a MM on my Ubuntu server and it seems to work fine, i can watch on 192.168.x.x:8080 on my browser.
      Now the question is…the only way to watch the mirror on a Raspberry pi3 client is by chromium or there is a way with electron ?
      I tried to change my mm.sh with: node clientonly --address 192.168.2.100 --port 8080 but I got error:
      pi@raspberrypi:~/MagicMirror $ node clientonly --address 192.168.2.100 --port 8080
      Client:
      (electron:1213): Gtk-WARNING **: cannot open display:
      There something wrong. The clientonly is not running code 1
      Some help to solve ?
      idoodlerI B 2 Replies Last reply Reply Quote 0
      • idoodlerI Offline
        idoodler Module Developer @Akkor
        @akkor Are you trying to start the MagicMirror via an SSH connection?
        You can’t start an MagicMirror instance via SSH: https://github.com/MichMich/MagicMirror#installation
          Akkor
          @idoodler I have tried to start changing the mm.sh
          This is the command I’ve put in:
          but when I restart raspberry the system show me only the desktop and MM seems don’t start
          idoodlerI 1 Reply Last reply Reply Quote 0
          • idoodlerI Offline
            @akkor Ok, check the log with the following command: pm2 log mm
            On the top you will see the last 15 lines of the error log.
              Akkor
                Akkor
                @idoodler
                This is the answer
                pi@raspberrypi:~ $ pm2 log mm
                [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
                0|mm       | (electron:2017): Gtk-WARNING **: cannot open display:
                0|mm       | Client:
                0|mm       | (electron:2027): Gtk-WARNING **: cannot open display:
                0|mm       | Client:
                0|mm       | (electron:2037): Gtk-WARNING **: cannot open display:
                0|mm       | Client:
                0|mm       | (electron:2047): Gtk-WARNING **: cannot open display:
                0|mm       | Client:
                0|mm       | (electron:2057): Gtk-WARNING **: cannot open display:
                0|mm       | Client:
                0|mm       | (electron:2067): Gtk-WARNING **: cannot open display:
                0|mm       | Client:
                0|mm       | (electron:2077): Gtk-WARNING **: cannot open display:
                0|mm       | Client:
                0|mm       | (electron:2093): Gtk-WARNING **: cannot open display:
                  Akkor
                  Pls help I cannot find any solution
                    if you are trying to start over an ssh session, you need to add this before the node clientonly
                    if [ -z “$DISPLAY” ]; then #If not set DISPLAY is SSH remote or tty
                    export DISPLAY=:0 # Set by default display
                    fi
                      bhepler Module Developer @Akkor
                      @akkor - Ugh. Why would you want to use Electron if you didn’t have to? There’s already a web browser on your Pi. Just point it at the MM server and be done with it.
                      I’ve learned that you can get Chromium to start in kiosk mode at a particular URL with about an hour of research and testing. Minimal swearing was involved.
                      • idoodlerI Offline
                        idoodler Module Developer @bhepler
                        @bhepler Electron is already a premade solution that works great. However using Chromium in Kiosk mode is also a nice and easy solution. And it may solve the issue here.
                        @Akkor How to open Chromium in kioksmode on startup: https://raspberrypi.stackexchange.com/questions/40631/setting-up-a-kiosk-with-chromium
                          Akkor
                          @idoodler @bhepler
                          I Have setup chromium to autostart and it’s ok
                          But I would like use Electron to use the voice command on client like this one https://github.com/mykle1/Hello-Lucy or https://github.com/joanaz/MMM-MirrorMirrorOnTheWall but I don’t know if it’s doable in server/client mode
                          • idoodlerI Offline
                            @akkor I don’t think you can use Hello-Lucy in client mode.
                            But I bet the developer @Mykle1 knows it.
                              Akkor
                              ok so wait for @Mykle1
                                macnice
                                • idoodlerI Offline
                                  idoodler Module Developer @macnice
                                  @macnice Hi, is your issue related to the problem described in this thread? You May want to create a new thread if the issue are not related.
                                    Mykle1 Project Sponsor Module Developer @idoodler
                                    @idoodler said in Problem server client configuration:
                                    @Akkor ok so wait for @Mykle1
                                    I never even thought about trying it. I just run standard installations. If @idoodler doesn’t think it will work, it probably won’t. However, you could always try for yourself.
                                    • idoodlerI Offline
                                      idoodler Module Developer @Mykle1
                                      @mykle1 I am currently unable to test it. I quickly checked your code on my phone, but I didn‘t quite got your code :flushed_face:
                                      I am curious, how did you make the voice recognition?
                                        Akkor
                                        It could be fine if someone really skilled test Hello Lucy server/client mode
                                          I didn’t mean that YOU should test it. I meant that @Akkor should test it as it is he that is looking for that functionality.
                                          I didn’t. MMM-voice was already written by @strawberry-3-141. It’s a fantastic piece of software. I just made some additions/modifications to original so that I could hide/show individual modules, hide/show pages of modules, hide show all modules, turn the display on and off, audio, all through the use of notifications. I use it every day for a year now. It’s stable, very fast and does exactly what I want it to do.
                                            Akkor
                                            @Mykle1
                                            I could test but I need your assistance 'couse I’m not a programmer
                                            I’m just good following guide… :(
