    24 Hour clock problem
    25 Posts 5 Posters 13.6k Views 4 Watching
      Rasmus rytter @Nilnik
      thanks @nilnik
      Can u send it as a Text so i can copy it in mine?
      • N
        Nilnik Project Sponsor
        I don’t know how to,when I paste in the textfile I lose all tabs so you have to put in them
        disabled: false,
        module: ‘calendar’,
        header: ‘Namnsdagar’,
        position: ‘bottom_left’,
        colored: ‘true’,
        timeFormat: ‘absolute’,
        maximumEntries: 5,
        fullDayEventDateFormat: ‘Do MMM’,
        showEnd: false,
        urgency: 1,
        color: ‘#00ff00’,
        symbol:'calendar-check-o ',
        url: ‘http://www.webcal.fi/cal.php?id=99’
        R Mykle1M 3 Replies Last reply Reply Quote 0
          i can try do i have to paste my own google link in insted of urs?
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @Nilnik
            @nilnik said in 24 Hour clock problem:
            https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
            • N
              Thanks, we learn all the time . Happy New year
                I think i have done some wrong but cant find it, there is just the clock in the MM now, no calendar.
                  Rasmus rytter
                  Everything has gone except of the clock?
                  • N
                    Try this link: https://github.com/MichMich/MagicMirror/wiki/faq#q-im-having-problems-with-my-configjs-but-cant-find-the-issue-
                      Rasmus rytter
                      I try to do it all over do anyone have a clear starting config i can copy?
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @Rasmus rytter
                        @rasmus-rytter
                        You don’t have your config.js.sample file?
                        var config = {
                        	port: 8080,
                        	language: "en",
                        	timeFormat: 24,
                        	units: "metric",
                        			module: "alert",
                        			module: "updatenotification",
                        			position: "top_bar"
                        			module: "clock",
                        			position: "top_left"
                        			header: "US Holidays",
                        						symbol: "calendar-check-o ",
                        			module: "compliments",
                        			position: "lower_third"
                        			module: "currentweather",
                        				locationID: "",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
                        			module: "weatherforecast",
                        			header: "Weather Forecast",
                        				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                        			module: "newsfeed",
                        			position: "bottom_bar",
                        				feeds: [
                        						title: "New York Times",
                        				showSourceTitle: true,
                        				showPublishDate: true
                          bhepler Module Developer
                          Everyone! Please, use the Markdown features of the forum when posting code.
                          @rasmus-rytter said in 24 Hour clock problem:
                          Looking at your config.js file, you are missing the code to include the clock module entirely. @Mykle1 has it correct: It’s best at this point to copy the config.js.sample file to config.js and just start from a known working baseline.
                          • Mykle1M
                            @rasmus-rytter
                            Also, for future reference, a value of true should not be in quotes as you have in colored: "true", above.
                              Rasmus rytter
                              Thanks, i learn some new everyday :)
                              • Mykle1M
                                As do I, my friend. As do I. :thumbsup:
