    24 Hour clock problem
    25 Posts 5 Posters 13.9k Views 4 Watching
    • N
      Nilnik Project Sponsor
      Thanks, we learn all the time . Happy New year
        Rasmus rytter @Nilnik
        I think i have done some wrong but cant find it, there is just the clock in the MM now, no calendar.
          Rasmus rytter
          Everything has gone except of the clock?
          Mykle1M 1 Reply Last reply
          • N
            Try this link: https://github.com/MichMich/MagicMirror/wiki/faq#q-im-having-problems-with-my-configjs-but-cant-find-the-issue-
              Rasmus rytter
              I try to do it all over do anyone have a clear starting config i can copy?
              • Mykle1M
                Mykle1 Project Sponsor Module Developer @Rasmus rytter
                @rasmus-rytter
                You don’t have your config.js.sample file?
                var config = {
                	port: 8080,
                	language: "en",
                	timeFormat: 24,
                	units: "metric",
                			module: "alert",
                			module: "updatenotification",
                			position: "top_bar"
                			module: "clock",
                			position: "top_left"
                			header: "US Holidays",
                						symbol: "calendar-check-o ",
                			module: "compliments",
                			position: "lower_third"
                			module: "currentweather",
                				locationID: "",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
                			module: "weatherforecast",
                			header: "Weather Forecast",
                				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
                			module: "newsfeed",
                			position: "bottom_bar",
                				feeds: [
                						title: "New York Times",
                				showSourceTitle: true,
                				showPublishDate: true
                  bhepler Module Developer
                  Everyone! Please, use the Markdown features of the forum when posting code.
                  @rasmus-rytter said in 24 Hour clock problem:
                  Looking at your config.js file, you are missing the code to include the clock module entirely. @Mykle1 has it correct: It’s best at this point to copy the config.js.sample file to config.js and just start from a known working baseline.
                  • Mykle1M
                    @rasmus-rytter
                    Also, for future reference, a value of true should not be in quotes as you have in colored: "true", above.
                      Rasmus rytter
                      Thanks, i learn some new everyday :)
                      • Mykle1M
                        As do I, my friend. As do I. :thumbsup:
