    Clean installation... fails left and right
    17 Posts 6 Posters 7.7k Views 4 Watching
      Mykle1 Project Sponsor Module Developer @devinhedge
      @devinhedge said in Clean installation... fails left and right:
      ‘Electron failed to install correctly, please delete node_modules/electron and try installing again’
      It can be frustrating. I think you would be missing out if you abandoned MM at this point. I dare say that the members here can get you up and running. I would address the last error first, the one I quoted.
      1. Go to your MagicMirror/node_modules folder and delete the electron folder.
      2. In your terminal, go to your MagicMirror directory and run npm install.
      This will install electron (we hope) and very likely be the end of your troubles.
      Run npm start in your MagicMirror directory.
      This should start your mirror. Good luck. Report back.
        devinhedge
        Thanks for talking me off the ledge. I uninstalled electron. Then I deleted the electron folder. Then I ran npm install again. I received several warnings but the installation completed.
        Here is the result.
        pi@mirrorpi:~/MagicMirror $ npm start
        > magicmirror@2.5.0 start /home/pi/MagicMirror
        > sh run-start.sh
        /home/pi/MagicMirror/node_modules/electron/dist/electron: /lib/arm-linux-gnueabihf/libc.so.6: version `GLIBC_2.27' not found (required by /home/pi/MagicMirror/node_modules/electron/dist/electron)
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! magicmirror@2.5.0 start: `sh run-start.sh`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the magicmirror@2.5.0 start script.
        npm ERR!     /home/pi/.npm/_logs/2019-01-01T02_28_54_363Z-debug.log
        [0_1546310061028_2019-01-01T02_28_54_363Z-debug.log](Uploading 100%)
          @devinhedge
          Ok, so now you’re missing a library:
          /lib/arm-linux-gnueabihf/libc.so.6: version `GLIBC_2.27’ not found (required by /home/pi/MagicMirror/node_modules/electron/dist/electron)
          I don’t know where you would acquire that specific file. You could try running npm install in the MagicMirror directory again. I know, that seems silly but it might work. It can’t hurt anything. Otherwise, I’m sure someone else will jump in here and help
            bhepler Module Developer @devinhedge
            Config info:
            RasPi 3b+
            8GB SD card
            Running on Rasbian Stretch Lite
            Attempting to run using sample config.js
            No other installed modules at this point
            Attempting to run as either server/client or server only
            Well, I think I’ve detected your problem. From the GitHub page for the Magic Mirror project:
            Note that you will need to install the latest full version of Raspbian, don’t use the Lite version.
            So. My advice is to pull your SD card and flash the full desktop version of Raspbian Stretch. I don’t think you need the “recommended software” version, but you do need the desktop.
            Edited to add: It seems others have similar problems with the latest version of Raspian. Apparently they changed something in the base images. Anyhow, follow this advice and you should be able to get back on track.
            • MichMichM Offline
              MichMich @devinhedge
              Not to be snarky… really… I’m concerned that MagicMirror isn’t being maintained. During installation there are a lot of deprecated node.js module warnings, and security warnings…
              As others have said, most of your problems are because you use Raspbian Lite.
              That being said: you have a point. The auto installer script isn’t maintained as well as I want it to be. Due to the fast development speed of Raspbian, it runs into issues. Since most of the contributors don’t install the core from scratch very often, we don’t run into these issues.
              I’m considering deprecating the automatic installer and suggesting to manual install Node, clone MagicMirror and then run npm install. To be fair: that’s how I install my MagicMirror.
              Of course, PR’s to fix the auto-installer are more than welcome!
                dazza120
                Yep I tried lite on my Pi 3B+ but it doesn’t work, Stretch desktop works, but think I had to go for the full package ie all the bloat ware, I’ve uninstalled all the rubbish now, but it’s not really an issue for me as I’m running my Pi off of an SSD so no sd card size limit/price, PS I think from what I remember I had to do a manual install and then install PM2 as it didn’t boot MM after reboot
                  shbatm Module Developer
                  I’m seeing issues with the newest “Raspbian Stretch with desktop image” (Nov 2018–non-bloatware) as well – I did a fresh, manual installation, no errors, but electron will not start with the OpenGL driver (full KMS or fake KMS) enabled. It runs through everything fine on npm start but then just stalls at “Launching application.” If I disable OpenGL, it works fine.
                  Tested at Tag v2.6.0 and on the develop branch (2.7.0-dev), same issues.
                  EDIT: Definitely an issue with electron: adding app.disableHardwareAcceleration(); in js/electron.js makes it open fine.
                  EDIT 2: Opened an issue for this #1500, looks like Electron v3.0.13 works.
                  D S 2 Replies Last reply Reply Quote 1
                    devinhedge @shbatm
                    @shbatm @dazza120 @MichMich @bhepler @Mykle1
                    Okay… I think I’ve figured it out. It isn’t good news:
                    I’ve brought this up on another thread, but I’ll mention here so that it is captured in context: for the last couple months Node.js and npm are currently BROKEN on RaspberryPi.
                    I just tried a test this morning using the started Electron app at https://electronjs.org/docs/tutorial/first-app
                    Running the automated install is a Red Herring. It is inappropriate to suggest it.
                    We have to figure out how to fix the bugs in the Node.js installation for Raspberry Pi before anything else. I’m wondering if installing an older version of Node.js is the solution. If so, then what version would we start with?
                      shbatm Module Developer @devinhedge
                      What version of node are you using and how are you trying to install it? Node.Js works fine with Raspberry Pi, just don’t install it from the default repos. Use these instructions:
                      https://github.com/nodesource/distributions/blob/master/README.md
                      I’ve installed both v8 and v10 successfully multiple times on new Pis in the last few months.
                        shbatm Module Developer @shbatm
                        @shbatm said in Clean installation... fails left and right:
                        Confirming what I confirmed in the issue on GitHub just so others aren’t misled… Upgrading to Electron v3.0.13 is working fine (this is now the version installed if you use the develop branch of MM). V2.x is not working on the new Raspbian because of the OpenGL driver and we can’t use V4.x yet because of bad dependency references.
                          dazza120 @shbatm
                          @shbatm how do I find out what version of electron I have, I’m on the latest version of Magic Mirror and would love to update everything on that side
                            shbatm Module Developer @dazza120
                            @dazza120
                            cat ~/MagicMirror/node_modules/electron/package.json | grep '"version":'
                            Upgrade with:
                            cd ~/MagicMirror/
                            npm install electron@3.0.13
                              devinhedge @shbatm
                              Current from default Rasbian repos.
                              That may be the problem.
                              I’ll give it a whirl. I was able to recreate the error 4 times so I just need to copy over the steps to recreate. I don’t have a lot of time to spend on it today.
                                dazza120 @shbatm
                                cat ~/MagicMirror/node_modules/electron/package.json | grep ‘“version”:’
                                Thanks appears I was running electron 2.0.16 3.0.13 installed fixed a few vulnerabilities and all seems to be working fine on the Pi3B+
                                  devinhedge
                                  Instructions for Installing MagicMirror on Rasbian Stretch Lite
                                  Install base Rasbian Stretch Lite image
                                  Update base installation
                                  sudo raspi-config
                                  1. Update pi password
                                  2. Update Timezone
                                  3. Update Keyboard
                                  4. Update hostname
                                  5. Update Localization (language)
                                  6. Update WiFi configuration
                                  7. Expand file system and reboot
                                  8. Enable ssh
                                  9. Update System
                                  sudo apt-get update && sudo apt upgrade -y && sudo apt-get dist-upgrade
                                  Install Xserver, LXDE-gui, lightdm and other nescessary things:
                                  sudo apt-get install raspberrypi-ui-mods firefox-esr build-essentials git -y
                                  Use raspi-config to autologin pi user to gui at boot
                                  raspi-config
                                  sudo reboot
                                  Use Raspi
                                  Install Node.js from source
                                  Remove Chris Lea’s Node.js if it has accidently been installed
                                  sudo rm -f /etc/apt/sources.list.d/chris-lea-node_js-.list
                                  .list.save
                                  Add the NodeSource package signing key
                                  curl -sSL https://deb.nodesource.com/gpgkey/nodesource.gpg.key | sudo apt-key add -
                                  Add the desired NodeSource repository
                                  VERSION=node_10.x
                                  DISTRO=“$(lsb_release -s -c)”
                                  echo “deb https://deb.nodesource.com/$VERSION $DISTRO main” | sudo tee /etc/apt/sources.list.d/nodesource.list
                                  echo “deb-src https://deb.nodesource.com/$VERSION $DISTRO main” | sudo tee -a /etc/apt/sources.list.d/nodesource.list
                                  Test if the installation is good.
                                  curl -sL https://deb.nodesource.com/test | bash -
                                  Received:
                                  (node:15418) TimeoutOverflowWarning: 4294967296000 does not fit into a 32-bit signed integer.
                                  Timer duration was truncated to 2147483647.
                                  SUCCESS
                                  (node:15418) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                                  Install the Sample Node.js Electron app
                                  npm install --save-dev electron
                                  Git clone the sample app
                                  git clone https://github.com/electron/electron-quick-start.git
                                  Then install it and run
                                  cd ./electron-quick-start
                                  npm install
                                  npm start
                                  Received:
                                  1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
                                  2 info using npm@6.4.1
                                  3 info using node@v10.15.0
                                  5 info lifecycle electron-quick-start@1.0.0~prestart: electron-quick-start@1.0.0
                                  6 info lifecycle electron-quick-start@1.0.0~start: electron-quick-start@1.0.0
                                  7 verbose lifecycle electron-quick-start@1.0.0~start: unsafe-perm in lifecycle true
                                  8 verbose lifecycle electron-quick-start@1.0.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/electron-quick-start/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                                  9 verbose lifecycle electron-quick-start@1.0.0~start: CWD: /home/pi/electron-quick-start
                                  10 silly lifecycle electron-quick-start@1.0.0~start: Args: [ '-c', 'electron .' ]
                                  11 silly lifecycle electron-quick-start@1.0.0~start: Returned: code: 1  signal: null
                                  12 info lifecycle electron-quick-start@1.0.0~start: Failed to exec start script
                                  13 verbose stack Error: electron-quick-start@1.0.0 start: `electron .`
                                  13 verbose stack Exit status 1
                                  13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:301:16)
                                  13 verbose stack     at EventEmitter.emit (events.js:182:13)
                                  13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                                  13 verbose stack     at ChildProcess.emit (events.js:182:13)
                                  13 verbose stack     at maybeClose (internal/child_process.js:962:16)
                                  13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:251:5)
                                  14 verbose pkgid electron-quick-start@1.0.0
                                  15 verbose cwd /home/pi/electron-quick-start
                                  16 verbose Linux 4.14.79-v7+
                                  17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
                                  18 verbose node v10.15.0
                                  19 verbose npm  v6.4.1
                                  20 error code ELIFECYCLE
                                  21 error errno 1
                                  22 error electron-quick-start@1.0.0 start: `electron .`
                                  22 error Exit status 1
                                  23 error Failed at the electron-quick-start@1.0.0 start script.
                                  23 error This is probably not a problem with npm. There is likely additional logging output above.
                                  24 verbose exit [ 1, true ]
                                  I’m beginning to think about the quote:
                                  Insanity: doing the same thing over and over again and expecting different results.
                                    The Nodesource install scripts will save you some time/steps:
                                    curl -sL https://deb.nodesource.com/setup_10.x | bash -
                                    apt-get install -y nodejs
                                    It looks like everything installed correctly. As has been said before:
                                    @michmich said in Clean installation... fails left and right:
                                    The electron-quick-start app tries to install electron v4.0, which as I said above, does not work on the latest version of Raspbian–you need to use v3.0.13 (npm i electron@3.0.13).
                                    Also, are you trying to run electron from the Pi’s desktop or SSH? If you’re running it from SSH you need to run it with DISPLAY=:0 npm start
