    Clean installation... fails left and right
    17 Posts 6 Posters 7.7k Views 4 Watching
    • MichMichM Offline
      MichMich @devinhedge
      @devinhedge said in Clean installation... fails left and right:
      Not to be snarky… really… I’m concerned that MagicMirror isn’t being maintained. During installation there are a lot of deprecated node.js module warnings, and security warnings…
      As others have said, most of your problems are because you use Raspbian Lite.
      That being said: you have a point. The auto installer script isn’t maintained as well as I want it to be. Due to the fast development speed of Raspbian, it runs into issues. Since most of the contributors don’t install the core from scratch very often, we don’t run into these issues.
      I’m considering deprecating the automatic installer and suggesting to manual install Node, clone MagicMirror and then run npm install. To be fair: that’s how I install my MagicMirror.
      Of course, PR’s to fix the auto-installer are more than welcome!
        dazza120
        Yep I tried lite on my Pi 3B+ but it doesn’t work, Stretch desktop works, but think I had to go for the full package ie all the bloat ware, I’ve uninstalled all the rubbish now, but it’s not really an issue for me as I’m running my Pi off of an SSD so no sd card size limit/price, PS I think from what I remember I had to do a manual install and then install PM2 as it didn’t boot MM after reboot
          shbatm Module Developer
          I’m seeing issues with the newest “Raspbian Stretch with desktop image” (Nov 2018–non-bloatware) as well – I did a fresh, manual installation, no errors, but electron will not start with the OpenGL driver (full KMS or fake KMS) enabled. It runs through everything fine on npm start but then just stalls at “Launching application.” If I disable OpenGL, it works fine.
          Tested at Tag v2.6.0 and on the develop branch (2.7.0-dev), same issues.
          EDIT: Definitely an issue with electron: adding app.disableHardwareAcceleration(); in js/electron.js makes it open fine.
          EDIT 2: Opened an issue for this #1500, looks like Electron v3.0.13 works.
          D S 2 Replies Last reply Reply Quote 1
            devinhedge @shbatm
            @shbatm @dazza120 @MichMich @bhepler @Mykle1
            Okay… I think I’ve figured it out. It isn’t good news:
            I’ve brought this up on another thread, but I’ll mention here so that it is captured in context: for the last couple months Node.js and npm are currently BROKEN on RaspberryPi.
            I just tried a test this morning using the started Electron app at https://electronjs.org/docs/tutorial/first-app
            Running the automated install is a Red Herring. It is inappropriate to suggest it.
            We have to figure out how to fix the bugs in the Node.js installation for Raspberry Pi before anything else. I’m wondering if installing an older version of Node.js is the solution. If so, then what version would we start with?
              shbatm Module Developer @devinhedge
              What version of node are you using and how are you trying to install it? Node.Js works fine with Raspberry Pi, just don’t install it from the default repos. Use these instructions:
              https://github.com/nodesource/distributions/blob/master/README.md
              I’ve installed both v8 and v10 successfully multiple times on new Pis in the last few months.
                shbatm Module Developer @shbatm
                @shbatm said in Clean installation... fails left and right:
                Confirming what I confirmed in the issue on GitHub just so others aren’t misled… Upgrading to Electron v3.0.13 is working fine (this is now the version installed if you use the develop branch of MM). V2.x is not working on the new Raspbian because of the OpenGL driver and we can’t use V4.x yet because of bad dependency references.
                  dazza120 @shbatm
                  @shbatm how do I find out what version of electron I have, I’m on the latest version of Magic Mirror and would love to update everything on that side
                    shbatm Module Developer @dazza120
                    @dazza120
                    cat ~/MagicMirror/node_modules/electron/package.json | grep '"version":'
                    Upgrade with:
                    cd ~/MagicMirror/
                    npm install electron@3.0.13
                      devinhedge @shbatm
                      Current from default Rasbian repos.
                      That may be the problem.
                      I’ll give it a whirl. I was able to recreate the error 4 times so I just need to copy over the steps to recreate. I don’t have a lot of time to spend on it today.
                        dazza120 @shbatm
                        cat ~/MagicMirror/node_modules/electron/package.json | grep ‘“version”:’
                        Thanks appears I was running electron 2.0.16 3.0.13 installed fixed a few vulnerabilities and all seems to be working fine on the Pi3B+
                          devinhedge
                          Instructions for Installing MagicMirror on Rasbian Stretch Lite
                          Install base Rasbian Stretch Lite image
                          Update base installation
                          sudo raspi-config
                          1. Update pi password
                          2. Update Timezone
                          3. Update Keyboard
                          4. Update hostname
                          5. Update Localization (language)
                          6. Update WiFi configuration
                          7. Expand file system and reboot
                          8. Enable ssh
                          9. Update System
                          sudo apt-get update && sudo apt upgrade -y && sudo apt-get dist-upgrade
                          Install Xserver, LXDE-gui, lightdm and other nescessary things:
                          sudo apt-get install raspberrypi-ui-mods firefox-esr build-essentials git -y
                          Use raspi-config to autologin pi user to gui at boot
                          raspi-config
                          sudo reboot
                          Use Raspi
                          Install Node.js from source
                          Remove Chris Lea’s Node.js if it has accidently been installed
                          sudo rm -f /etc/apt/sources.list.d/chris-lea-node_js-.list
                          .list.save
                          Add the NodeSource package signing key
                          curl -sSL https://deb.nodesource.com/gpgkey/nodesource.gpg.key | sudo apt-key add -
                          Add the desired NodeSource repository
                          VERSION=node_10.x
                          DISTRO=“$(lsb_release -s -c)”
                          echo “deb https://deb.nodesource.com/$VERSION $DISTRO main” | sudo tee /etc/apt/sources.list.d/nodesource.list
                          echo “deb-src https://deb.nodesource.com/$VERSION $DISTRO main” | sudo tee -a /etc/apt/sources.list.d/nodesource.list
                          Test if the installation is good.
                          curl -sL https://deb.nodesource.com/test | bash -
                          Received:
                          (node:15418) TimeoutOverflowWarning: 4294967296000 does not fit into a 32-bit signed integer.
                          Timer duration was truncated to 2147483647.
                          SUCCESS
                          (node:15418) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                          Install the Sample Node.js Electron app
                          npm install --save-dev electron
                          Git clone the sample app
                          git clone https://github.com/electron/electron-quick-start.git
                          Then install it and run
                          cd ./electron-quick-start
                          npm install
                          npm start
                          Received:
                          1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
                          2 info using npm@6.4.1
                          3 info using node@v10.15.0
                          5 info lifecycle electron-quick-start@1.0.0~prestart: electron-quick-start@1.0.0
                          6 info lifecycle electron-quick-start@1.0.0~start: electron-quick-start@1.0.0
                          7 verbose lifecycle electron-quick-start@1.0.0~start: unsafe-perm in lifecycle true
                          8 verbose lifecycle electron-quick-start@1.0.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/electron-quick-start/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
                          9 verbose lifecycle electron-quick-start@1.0.0~start: CWD: /home/pi/electron-quick-start
                          10 silly lifecycle electron-quick-start@1.0.0~start: Args: [ '-c', 'electron .' ]
                          11 silly lifecycle electron-quick-start@1.0.0~start: Returned: code: 1  signal: null
                          12 info lifecycle electron-quick-start@1.0.0~start: Failed to exec start script
                          13 verbose stack Error: electron-quick-start@1.0.0 start: `electron .`
                          13 verbose stack Exit status 1
                          13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:301:16)
                          13 verbose stack     at EventEmitter.emit (events.js:182:13)
                          13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                          13 verbose stack     at ChildProcess.emit (events.js:182:13)
                          13 verbose stack     at maybeClose (internal/child_process.js:962:16)
                          13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:251:5)
                          14 verbose pkgid electron-quick-start@1.0.0
                          15 verbose cwd /home/pi/electron-quick-start
                          16 verbose Linux 4.14.79-v7+
                          17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
                          18 verbose node v10.15.0
                          19 verbose npm  v6.4.1
                          20 error code ELIFECYCLE
                          21 error errno 1
                          22 error electron-quick-start@1.0.0 start: `electron .`
                          22 error Exit status 1
                          23 error Failed at the electron-quick-start@1.0.0 start script.
                          23 error This is probably not a problem with npm. There is likely additional logging output above.
                          24 verbose exit [ 1, true ]
                          I’m beginning to think about the quote:
                          Insanity: doing the same thing over and over again and expecting different results.
                            The Nodesource install scripts will save you some time/steps:
                            curl -sL https://deb.nodesource.com/setup_10.x | bash -
                            apt-get install -y nodejs
                            It looks like everything installed correctly. As has been said before:
                            @michmich said in Clean installation... fails left and right:
                            The electron-quick-start app tries to install electron v4.0, which as I said above, does not work on the latest version of Raspbian–you need to use v3.0.13 (npm i electron@3.0.13).
                            Also, are you trying to run electron from the Pi’s desktop or SSH? If you’re running it from SSH you need to run it with DISPLAY=:0 npm start
