    [MMM-Showtimes] Local Cinema Showtimes
    10 Posts 6 Posters 5.3k Views 6 Watching
      Seann Module Developer @Mykle1
      @mykle1 Awesome. Guess you’re treating me to a movie tomorrow then.
      I actually have a small issue which i just realized, do you think you could help?
      Basically for some reason the css will only display 5 show times, the others seem to overflow, which is then hidden by the default “main.css” i used ul (the movie) display:block, and then ul li (the time) display inline-block and a set width, normally this would just put the next list item on a new line but not on this occasion. Any clue?
      Mykle1M cowboysdudeC lavolp3L 3 Replies Last reply Reply Quote 1
        Mykle1 Project Sponsor Module Developer @Seann
        @seann
        css is NOT my strong suit. I usually do a good bit of googling at that point and/or ask right here in the forum. Your question might be lost in here. If you can’t work it out I suggest you create another topic (ex. css help) and I am sure someone will give you the answer pretty quickly.
        • cowboysdudeC Offline
          cowboysdude Module Developer @Seann
          @seann He should…but he’s kinda cheap LOL
          • lavolp3L Offline
            lavolp3 Module Developer @Seann
            @seann
            My suggestion: Fire up the mirror UI on your browser, press F12, move the move over your module, right click -> inspect.
            Then look at the styles section and play with switching styles on and off.
            Then you can use whatever you need in your own css overwriting main.css in your module.
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
            S 1 Reply Last reply Reply Quote 3
              Seann Module Developer @lavolp3
              @lavolp3 Thanks! It was something stupid I had done. But I found it with your suggestion.
              • X Offline
                Xoni
                any luck sourcing a new api? and where would i go about changing the api if i found one?
                • lavolp3L Offline
                  lavolp3 Module Developer @Xoni
                  @Xoni Find me an API and I’ll integrate it for you :-D
                    swguk
                    Love this. Just got my board up and running and plan to integrate this asap !
