    How to start MM with a module as default hidden
    17 Posts 8 Posters 9.3k Views 8 Watching
    • T Offline
      THeStigh @dazza120
      @dazza120 I’m using Hotword together with AssistantMk2…
      Does Lucy support specifying “start [module] as hidden” ?
        dazza120 @THeStigh
        @thestigh Lucy hides all modules and you tell it what ones you want it to display
          Mykle1 Project Sponsor Module Developer @dazza120
          @dazza120 said in How to start MM with a module as default hidden:
          not sure why @Mykle1 hasn’t recommend Lucy it seems the best one for what you want to achieve
          I don’t want to “sell” Hello-Lucy to anyone and there are other voice modules that he may want to consider so that’s why I worded my answer that way. Lucy does exactly what I want “her” to do but it may be more complicated for some users
          justjim1220J 1 Reply Last reply Reply Quote 2
            mdhenriksen @THeStigh
            @thestigh You could combine MMM-pages and MMM-voice and just setup a page with the module and without it. However, this will probably only work if you are talking about 1 module. If you want several to be turned on and off, Lucy is the way to go. I belive Mykle1 has a video with it working as well.
              Mykle1 Project Sponsor Module Developer @mdhenriksen
              @mdhenriksen said in How to start MM with a module as default hidden:
              This was the first incarnation of Lucy with pages.
              https://www.youtube.com/watch?v=bKHEXPzVb2A
              1 Reply Last reply Reply Quote -1
              • T Offline
                THeStigh
                I used sendNotification to resolve this :)
                • F Offline
                  F17MC
                  @thestigh said in How to start MM with a module as default hidden:
                  Could you show me how?? I’m using MMM-AssistantMk2 and I can hide and show modules with voice. But I want set another modules hidden by default, and show it by voice.
                  If I set the modules hidden by MMM-remote-control I can’t show it by mmm-assistantmk2.
                  ? T 2 Replies Last reply Reply Quote 0
                    A Former User @F17MC
                    @f17mc
                    You can show modules hidden by others by force with MMM-AssistantMk2.
                    modify your command(using moduleExec) like this.
                    exec: (module, params, key) => {
                            module.show(1000, {"force":true})
                    F 1 Reply Last reply Reply Quote 3
                    • T Offline
                      THeStigh @F17MC
                      @f17mc
                      Hi, solution from @Sean is the ‘cleanest’ :) option (haven’t tested but trust Sean if he says so)
                      • F Offline
                        F17MC @Guest
                        @sean said in How to start MM with a module as default hidden:
                        @f17mc
                                module.hide(1000, {"force":true})
                        it works perfect! Thanks a both!
