    How to start MM with a module as default hidden
    17 Posts 8 Posters 10.1k Views 8 Watching
    • T Offline
      THeStigh
      Hi all,
      Anybody know how to start MM with a module default state as hidden?
      G Mykle1M M 3 Replies Last reply Reply Quote 0
      • G Offline
        ganget @THeStigh
        @thestigh Would you like to have the module running but not showing in your Magic Mirror? I guess you can do this by not assigning a position for the module.
        example for the clock module
        		module: "clock",
        		position: "",	// leave this blank
          Mykle1 Project Sponsor Module Developer @THeStigh
          @thestigh said in How to start MM with a module as default hidden:
          All of them? Some of them? One of them? Then how will you “show” the module(s)? Easiest solution would be MMM-RemoteControl I guess. Or, there are several voice modules that can do that for you.
          • T Offline
            THeStigh
            I want to start a specific module as hidden, and show it by issuing a voice command.
            Show/Hide is not the issue, this works fine, but I want the module to start hidden as default when starting MM.
              dazza120 @THeStigh
              @thestigh not sure why @Mykle1 hasn’t recommend Lucy it seems the best one for what you want to achieve
              T Mykle1M 2 Replies Last reply Reply Quote 0
              • T Offline
                THeStigh @dazza120
                @dazza120 I’m using Hotword together with AssistantMk2…
                Does Lucy support specifying “start [module] as hidden” ?
                  dazza120 @THeStigh
                  @thestigh Lucy hides all modules and you tell it what ones you want it to display
                    Mykle1 Project Sponsor Module Developer @dazza120
                    @dazza120 said in How to start MM with a module as default hidden:
                    I don’t want to “sell” Hello-Lucy to anyone and there are other voice modules that he may want to consider so that’s why I worded my answer that way. Lucy does exactly what I want “her” to do but it may be more complicated for some users
                    justjim1220J 1 Reply Last reply Reply Quote 2
                      mdhenriksen @THeStigh
                      @thestigh You could combine MMM-pages and MMM-voice and just setup a page with the module and without it. However, this will probably only work if you are talking about 1 module. If you want several to be turned on and off, Lucy is the way to go. I belive Mykle1 has a video with it working as well.
                        Mykle1 Project Sponsor Module Developer @mdhenriksen
                        @mdhenriksen said in How to start MM with a module as default hidden:
                        This was the first incarnation of Lucy with pages.
                        https://www.youtube.com/watch?v=bKHEXPzVb2A
                        1 Reply Last reply Reply Quote -1
                        • T Offline
                          THeStigh
                          I used sendNotification to resolve this :)
                          • F Offline
                            F17MC
                            Could you show me how?? I’m using MMM-AssistantMk2 and I can hide and show modules with voice. But I want set another modules hidden by default, and show it by voice.
                            If I set the modules hidden by MMM-remote-control I can’t show it by mmm-assistantmk2.
                            ? T 2 Replies Last reply Reply Quote 0
                              A Former User @F17MC
                              @f17mc
                              You can show modules hidden by others by force with MMM-AssistantMk2.
                              modify your command(using moduleExec) like this.
                              exec: (module, params, key) => {
                                      module.show(1000, {"force":true})
                              F 1 Reply Last reply Reply Quote 3
                              • T Offline
                                THeStigh @F17MC
                                @f17mc
                                Hi, solution from @Sean is the ‘cleanest’ :) option (haven’t tested but trust Sean if he says so)
                                • F Offline
                                  F17MC @Guest
                                  @sean said in How to start MM with a module as default hidden:
                                  @f17mc
                                          module.hide(1000, {"force":true})
                                  it works perfect! Thanks a both!
                                  • justjim1220J Offline
                                    justjim1220 Module Developer @Mykle1
                                    @mykle1 said in How to start MM with a module as default hidden:
                                    You should ‘sell’ Hello-Lucy! it’s the most awesome-est voice module I’ve used (in Ubuntu)
                                    AND, it was the ‘easiest’ for me to understand how to set up.
                                    Mainly because it was explained very well! :winking_face:
                                    Jim Hallock - 1995
                                      Mykle1 Project Sponsor Module Developer @justjim1220
                                      @justjim1220
                                      Thanks, I do appreciate your kind words. However, as @THeStigh mentioned, @Sean uses a cleaner (re: better) way of doing things. This better way of doing things just might inspire me to redo Lucy. :-)
