    How to start MM with a module as default hidden
    17 Posts 8 Posters 10.1k Views 8 Watching
      dazza120 @THeStigh
      @thestigh not sure why @Mykle1 hasn’t recommend Lucy it seems the best one for what you want to achieve
      T Mykle1M 2 Replies Last reply Reply Quote 0
      • T Offline
        THeStigh @dazza120
        @dazza120 I’m using Hotword together with AssistantMk2…
        Does Lucy support specifying “start [module] as hidden” ?
          dazza120 @THeStigh
          @thestigh Lucy hides all modules and you tell it what ones you want it to display
            Mykle1 Project Sponsor Module Developer @dazza120
            @dazza120 said in How to start MM with a module as default hidden:
            I don’t want to “sell” Hello-Lucy to anyone and there are other voice modules that he may want to consider so that’s why I worded my answer that way. Lucy does exactly what I want “her” to do but it may be more complicated for some users
            justjim1220J 1 Reply Last reply Reply Quote 2
              mdhenriksen @THeStigh
              @thestigh You could combine MMM-pages and MMM-voice and just setup a page with the module and without it. However, this will probably only work if you are talking about 1 module. If you want several to be turned on and off, Lucy is the way to go. I belive Mykle1 has a video with it working as well.
                Mykle1 Project Sponsor Module Developer @mdhenriksen
                @mdhenriksen said in How to start MM with a module as default hidden:
                This was the first incarnation of Lucy with pages.
                https://www.youtube.com/watch?v=bKHEXPzVb2A
                1 Reply Last reply Reply Quote -1
                • T Offline
                  THeStigh
                  I used sendNotification to resolve this :)
                  • F Offline
                    F17MC
                    @thestigh said in How to start MM with a module as default hidden:
                    Could you show me how?? I’m using MMM-AssistantMk2 and I can hide and show modules with voice. But I want set another modules hidden by default, and show it by voice.
                    If I set the modules hidden by MMM-remote-control I can’t show it by mmm-assistantmk2.
                    ? T 2 Replies Last reply Reply Quote 0
                      A Former User @F17MC
                      @f17mc
                      You can show modules hidden by others by force with MMM-AssistantMk2.
                      modify your command(using moduleExec) like this.
                      exec: (module, params, key) => {
                              module.show(1000, {"force":true})
                      F 1 Reply Last reply Reply Quote 3
                      • T Offline
                        THeStigh @F17MC
                        @f17mc
                        Hi, solution from @Sean is the ‘cleanest’ :) option (haven’t tested but trust Sean if he says so)
                        • F Offline
                          F17MC @Guest
                          @sean said in How to start MM with a module as default hidden:
                          @f17mc
                                  module.hide(1000, {"force":true})
                          it works perfect! Thanks a both!
                          • justjim1220J Offline
                            justjim1220 Module Developer @Mykle1
                            @mykle1 said in How to start MM with a module as default hidden:
                            You should ‘sell’ Hello-Lucy! it’s the most awesome-est voice module I’ve used (in Ubuntu)
                            AND, it was the ‘easiest’ for me to understand how to set up.
                            Mainly because it was explained very well! :winking_face:
                            Jim Hallock - 1995
                              Mykle1 Project Sponsor Module Developer @justjim1220
                              @justjim1220
                              Thanks, I do appreciate your kind words. However, as @THeStigh mentioned, @Sean uses a cleaner (re: better) way of doing things. This better way of doing things just might inspire me to redo Lucy. :-)
