    How to start MM with a module as default hidden
    17 Posts 8 Posters 10.0k Views 8 Watching
    • G Offline
      ganget @THeStigh
      @thestigh Would you like to have the module running but not showing in your Magic Mirror? I guess you can do this by not assigning a position for the module.
      example for the clock module
      		module: "clock",
      		position: "",	// leave this blank
        Mykle1 Project Sponsor Module Developer @THeStigh
        @thestigh said in How to start MM with a module as default hidden:
        Anybody know how to start MM with a module default state as hidden?
        All of them? Some of them? One of them? Then how will you “show” the module(s)? Easiest solution would be MMM-RemoteControl I guess. Or, there are several voice modules that can do that for you.
        • T Offline
          THeStigh
          I want to start a specific module as hidden, and show it by issuing a voice command.
          Show/Hide is not the issue, this works fine, but I want the module to start hidden as default when starting MM.
            dazza120 @THeStigh
            @thestigh not sure why @Mykle1 hasn’t recommend Lucy it seems the best one for what you want to achieve
            T Mykle1M 2 Replies Last reply Reply Quote 0
            • T Offline
              THeStigh @dazza120
              @dazza120 I’m using Hotword together with AssistantMk2…
              Does Lucy support specifying “start [module] as hidden” ?
                dazza120 @THeStigh
                @thestigh Lucy hides all modules and you tell it what ones you want it to display
                  Mykle1 Project Sponsor Module Developer @dazza120
                  @dazza120 said in How to start MM with a module as default hidden:
                  I don’t want to “sell” Hello-Lucy to anyone and there are other voice modules that he may want to consider so that’s why I worded my answer that way. Lucy does exactly what I want “her” to do but it may be more complicated for some users
                  justjim1220J 1 Reply Last reply Reply Quote 2
                    mdhenriksen @THeStigh
                    @thestigh You could combine MMM-pages and MMM-voice and just setup a page with the module and without it. However, this will probably only work if you are talking about 1 module. If you want several to be turned on and off, Lucy is the way to go. I belive Mykle1 has a video with it working as well.
                      Mykle1 Project Sponsor Module Developer @mdhenriksen
                      @mdhenriksen said in How to start MM with a module as default hidden:
                      This was the first incarnation of Lucy with pages.
                      https://www.youtube.com/watch?v=bKHEXPzVb2A
                      1 Reply Last reply Reply Quote -1
                      • T Offline
                        THeStigh
                        I used sendNotification to resolve this :)
                        • F Offline
                          F17MC
                          Could you show me how?? I’m using MMM-AssistantMk2 and I can hide and show modules with voice. But I want set another modules hidden by default, and show it by voice.
                          If I set the modules hidden by MMM-remote-control I can’t show it by mmm-assistantmk2.
                          ? T 2 Replies Last reply Reply Quote 0
                            [[global:former-user]] @F17MC
                            @f17mc
                            You can show modules hidden by others by force with MMM-AssistantMk2.
                            modify your command(using moduleExec) like this.
                            exec: (module, params, key) => {
                                    module.show(1000, {"force":true})
                            F 1 Reply Last reply Reply Quote 3
                            • T Offline
                              THeStigh @F17MC
                              @f17mc
                              Hi, solution from @Sean is the ‘cleanest’ :) option (haven’t tested but trust Sean if he says so)
                              • F Offline
                                F17MC @Guest
                                @sean said in How to start MM with a module as default hidden:
                                @f17mc
                                        module.hide(1000, {"force":true})
                                it works perfect! Thanks a both!
                                • justjim1220J Offline
                                  justjim1220 Module Developer @Mykle1
                                  @mykle1 said in How to start MM with a module as default hidden:
                                  You should ‘sell’ Hello-Lucy! it’s the most awesome-est voice module I’ve used (in Ubuntu)
                                  AND, it was the ‘easiest’ for me to understand how to set up.
                                  Mainly because it was explained very well! :winking_face:
                                  Jim Hallock - 1995
                                    Mykle1 Project Sponsor Module Developer @justjim1220
                                    @justjim1220
                                    Thanks, I do appreciate your kind words. However, as @THeStigh mentioned, @Sean uses a cleaner (re: better) way of doing things. This better way of doing things just might inspire me to redo Lucy. :-)
