    MMM-iFrame-Ping
    58 Posts 12 Posters 46.1k Views 13 Watching
      bolish
      maybe you should let your module more generic that what you currently did.
      If someone wants to STOP the video based on any other notification (like USER PRESENCE, false) he will always have the possibility to use MMM-NotificationTrigger to convert user presence to stop.
      Up to you.
      If you’re not keen to update that point (which I could understand), I believe I can maybe modify things a little bit myself to manage it.
      Maybe the modification should be done directly in MMM-PIR Sensor, which should only trigger PRESENCE FALSE once the additional delay is over and not before…
        AgP42 Project Sponsor Module Developer @bolish
        @bolish
        Yes I perfectly understand the issue you are facing, in fact I also did some contribution to the module PIR sensor :smiling_face_with_open_mouth_closed_eyes:
        Yes the delay on the module apply only about the screen off but the “USER_PRESENCE” is send anyway directly according to the sensor input.
        Normaly on your sensor you have 2 screws, one to change the sensibility of the sensor and the other one to adjust the time delay more infos here
        Did you check that ?
        But you are also right that I could let the choice to the user to use this USER_PRESENCE or not, I will check what I can do for that.
          bolish
          The sensor I’m using doesn’t offer this option, unfortunatly.
          link text
          Thinking of it again :
          Would it not be more “sustainable” to PR MMM-PIRSensor by putting a second notification trigger “USER_PRESENCE, Screen Off” after the timeout delay.
          Then, we could play within MMM-SmartWebDisplay with that one instead of the only USER PRESENCE false, true.
          By doing that + adding the option to use it or not, it would make the full thing more reliable and generic.
          If I believe it’s somewhere here :
                          else if (value == valueOff) {
                              self.sendSocketNotification('USER_PRESENCE', false);
                              if (!self.config.powerSaving){
                                  return;
                              self.deactivateMonitorTimeout = setTimeout(function() {
                                  self.deactivateMonitor();
                              }, self.config.powerSavingDelay * 1000);
            @bolish
            On the link you sent, this sensor is exactly the same as mine and its allow to change the timer ! ;-)
            The best way to make that clean will be to change the PIR-sensor module to send the notification only at the end of the timer, but I have no time to do so now…
            What you can do for now to desactivate the Stop at the reception of a USER_PRESENCE = false notification is to go on the file MMM-SmartWebDisplay.js, on the function “GestionUpdateIntervalSWD”, then comment (//) the line "this.StopDisplay();
            In fact I have no time to change the module PIR-Sensor now because I am about to finish an update of the module MMM-RemoteControl to be able to use "Next/Prev/Play/Pause/Stop directly on RemoteControl :
              bolish
              oh! I will look on the module again as I didn’t saw the famous screws you’re referring too…
              Don’t worry @AgP42 , you already did a great job! Thanks again for that.
              For the time being I will leave it like that (with your workaround) and if I have time on my side, I will maybe try to update MMM-PIRSensor. Maybe I could do it with trial and error method.
              Thanks to the latest update of your module and MMM-GroveGestures (from @Sean ) , I end up with a perfect user experience :
              • On my page 1 (main MM page), up / down gestures are handling news RSS details, etc…
              • On my page 2, I have your iFrame and I’m able to change youtube live channels by up / down gestures also.
              Perfect!
              The Remote Control you are working on looks great also!
              A bientôt et bonne continuation!! (tu as laissé qques indices dans ton code :-)
                :winking_face:
                Here is the new post about MMM-SmartWebDisplay, and the modification of MMM-RemoteControl to control it !
                • L Offline
                  lpgjg
                  Hey everyone,
                  Hoping I can jump in here at the beginners level. Been trying to load a number of YouTube modules for a week to no avail.
                  I’m more old school so this stuff doesn’t come natural to me and I’ve been trying to get iFrame-Ping to work the last few days.
                  Long story short, all I get is YouTube trying to load on the MM and then “Video unavailable” where the video should be.
                  The rest of the MM and its modules are working as should be. Strangely enough, I can click on the iframe-Ping module and the whole magic mirror disappears and the Pi switches to YouTube, full screen?
                  The only way to get out of youtube at this point is with “ctrl Q”.
                  Can anyone help?
                    AgP42 Project Sponsor Module Developer @lpgjg
                    @lpgjg
                    can you send your configuration ?
                    And also the log ? (when the MagicMirror is running, Ctrl+i and then filter to “iFrame-Ping” and copy the data°
                    Thanks,
                    AgP42
                    • L Offline
                      lpgjg
                      Will try to do so when I get home from work tonight. May take a few attempts as this very alien to me given that I’m probably older than most all of you…or your dads.
                      May be worth noting: After a few attempts I noticed if I used my companies playlist, or that of Bombardier, Nord-Gear or any other company / commercial play list, it works fine. Always begins at the same place when started but the module shows up and plays the videos.
                      But if I try to add a Pop music playlist or any of the popular artist out their, it gives me the “video unavailable.”
                      As if it’s a copy right issue when going through the mirror.
                      BTW: I’m in Montreal, Canada
                      S A 2 Replies Last reply Reply Quote 0
                        sdetweil @lpgjg
                        @lpgjg I’m 67… some of us are older…
                          @lpgjg @sdetweil,
                          the good news is that technology don’t care about the user age !
                          and I also don’t care, old or young, gives me your logs and I will help you ! :smiling_face_with_halo: :face_with_tears_of_joy:
                          • L Offline
                            lpgjg
                            Nothing happens when I hit “ctrl” and then the letter ”i” while the mirror is running. Or was I actually suppose to add the plus sign “+”…and I tried that as well. Only thing that works is ctrl Q.
                            As to my configuration. I assume this is what you are asking for:
                            module: ‘MMM-iFrame-Ping’,
                            position: ‘bottom_right’, // This can be any of the regions.
                            // See ‘Configuration options’ for more information.
                            url: “https://www.youtube.com/embed/LH4Y1ZUUx2g?list=PLw-VjHDlEOguL2K_NwIl_tYcs9_FSt5v_&autoplay=1&modestbranding=1&iv_load_policy=3”, //url to display
                            height:“80%”,
                            width:“80%”,
                            autoRefresh: false, //set to false for video
                            updateInterval: 1, //in min. Only if autoRefresh: true
                            displayLastUpdate: true,
                            width: “100%”, // Optional. Default: 100%
                            height: “400px”, //Optional. Default: 100px
                            scrolling: “no”
                              sdetweil @lpgjg
                              @lpgjg ctrl-shift-i (letter I) to open the dev window, then select the console tab
                                @lpgjg
                                This video is not available on youtube, so yes it is normal that the magicmirror cannot load it.
                                Is it a private video ?
                                  @sdetweil said in MMM-iFrame-Ping:
                                  I’m the youngest of my older friends. (60)
                                  • L Offline
                                    lpgjg
                                    I guess I am the baby of the group after all at 58.
                                    AgP42
                                    The videos are all from YouTube and do not seem to be private. I have tried this three amongst quite a few others. If someone has a pop play list that works, can you please give it to me. I can try it.
                                    https://www.youtube.com/watch?v=LH4Y1ZUUx2g&list=PLw-VjHDlEOguL2K_NwIl_tYcs9_FSt5v_
                                    https://www.youtube.com/watch?v=JGwWNGJdvx8&list=PLMC9KNkIncKtPzgY-5rmhvj7fax8fdxoj
                                    https://www.youtube.com/watch?v=WXBHCQYxwr0&list=PL4o29bINVT4EG_y-k5jGoOu3-Am8Nvi10
                                    I right click on the video while its playing and then click on copy embed code, from there I copy the src and input that into iFrame and/or iFramPing. Which gives me the “video unavailable” when I start the mirror.
                                    When I do the exact same for the following YouTube videos, the vids play fine.
                                    https://www.youtube.com/watch?v=I_bOFxxqXOg&list=PL6GgLDsVQ7J-JEVldGtzIVlmC1MbvIZbO
                                    https://www.youtube.com/watch?v=M3AYuDFdf88&list=PLwMdN-ylsjO5633clbN4nkygVXHpbcFwX
                                    I will try the ctrl-shift-i and will be back soon…hopefully.
                                    • L Offline
                                      lpgjg
                                      Wow…did not expect that screen to pop up? Hope I got what you asked for.
                                      Filter:
                                      Load script: modules/MMM-iFrame//MMM-iFrame.js
                                      module.js:477 Module registered: MMM-iFrame
                                      loader.js:152 Bootstrapping module: MMM-iFrame
                                      loader.js:157 Scripts loaded for: MMM-iFrame
                                      loader.js:197 Load stylesheet: modules/MMM-iFrame/MMM-iFrame.css
                                      loader.js:159 Styles loaded for: MMM-iFrame
                                      loader.js:161 Translations loaded for: MMM-iFrame
                                      loader.js:182 Load script: modules/MMM-iFrame-Ping//MMM-iFrame-Ping.js
                                      module.js:477 Module registered: MMM-iFrame-Ping
                                      loader.js:152 Bootstrapping module: MMM-iFrame-Ping
                                      loader.js:157 Scripts loaded for: MMM-iFrame-Ping
                                      loader.js:197 Load stylesheet: modules/MMM-iFrame-Ping/MMM-iFrame-Ping.css
                                      loader.js:159 Styles loaded for: MMM-iFrame-Ping
                                      loader.js:161 Translations loaded for: MMM-iFrame-Ping
                                      MMM-iFrame-Ping.js:30 Starting module: MMM-iFrame-Ping
                                      module.js:156 MMM-iFrame received a system notification: ALL_MODULES_STARTED
                                      module.js:156 MMM-iFrame received a system notification: MODULE_DOM_CREATED
                                      module.js:156 MMM-iFrame received a system notification: DOM_OBJECTS_CREATED
                                      module.js:154 MMM-iFrame received a module notification: WEATHER from sender: MMM-NOAA3
                                      module.js:154 MMM-iFrame received a module notification: CALENDAR_EVENTS from sender: calendar
                                      MMM-iFrame.js:26 update0
                                      MMM-iFrame.js:26 update1
                                      MMM-iFrame.js:26 update2
                                      MMM-iFrame.js:26 update3
                                      MMM-iFrame.js:26 update4
                                      MMM-iFrame.js:26 update5
                                      MMM-iFrame.js:26 update6
                                      Actually been trying both the MMM-iFrame & MMM-iFrame-Ping.
                                        Please try only one module at the time : or iFrame or iFrame-Ping but not both on the same config file.
                                        All the 5 link you gave bellow are also working fine in my browser, but the first one you gave previously didn’t work.
                                        • L Offline
                                          lpgjg
                                          At first I did only try one module at a time , removing one complete before trying the other. I’ve only recently installed a few at a time just to try different links on each module try to triple my combinations.
                                          I see no difference if I try one at a time or three at the same time. Even have MMM-SmartWebDisplay installed now and it also behaves the same way.
                                          But i will try one at a time again when I get home later.
                                          Wondering if its a Canadian copy right thing? Any Canadians on here have these modules running properly. If so, would love to see which playlists you have running.
                                          Was there any errors on the info I provided?
                                            JeroenV99
                                            Anyone can help me?:slightly_smiling_face:
                                            i want to put my google spreadsheets on my Magic Mirror and I thought it would be best with iframe
                                            but when i put my link in the config there is no new item on my mirror
                                            https://docs.google.com/spreadsheets/d/e/2PACX-1vTd-e8mpbbkZSfsZzQHrIevINnb-DVZnm5mPOmX3FqzS6yp6q_mxd0SnBbZ-hurB_7ET3sZDH_GFXil/pubhtml?gid=0&single=true
                                            • 3 / 3
