    MMM-iFrame-Ping
    58 Posts 12 Posters 49.9k Views 13 Watching
    • A
      AgP42 Project Sponsor Module Developer @lpgjg
      @lpgjg
      can you send your configuration ?
      And also the log ? (when the MagicMirror is running, Ctrl+i and then filter to “iFrame-Ping” and copy the data°
      Thanks,
      AgP42
      • L
        lpgjg
        Will try to do so when I get home from work tonight. May take a few attempts as this very alien to me given that I’m probably older than most all of you…or your dads.
        May be worth noting: After a few attempts I noticed if I used my companies playlist, or that of Bombardier, Nord-Gear or any other company / commercial play list, it works fine. Always begins at the same place when started but the module shows up and plays the videos.
        But if I try to add a Pop music playlist or any of the popular artist out their, it gives me the “video unavailable.”
        As if it’s a copy right issue when going through the mirror.
        BTW: I’m in Montreal, Canada
        S A 2 Replies Last reply
          sdetweil @lpgjg
          @lpgjg I’m 67… some of us are older…
          Mykle1M 1 Reply Last reply
          • A
            @lpgjg @sdetweil,
            the good news is that technology don’t care about the user age !
            and I also don’t care, old or young, gives me your logs and I will help you ! :smiling_face_with_halo: :face_with_tears_of_joy:
            • L
              lpgjg
              Nothing happens when I hit “ctrl” and then the letter ”i” while the mirror is running. Or was I actually suppose to add the plus sign “+”…and I tried that as well. Only thing that works is ctrl Q.
              As to my configuration. I assume this is what you are asking for:
              module: ‘MMM-iFrame-Ping’,
              position: ‘bottom_right’, // This can be any of the regions.
              // See ‘Configuration options’ for more information.
              url: “https://www.youtube.com/embed/LH4Y1ZUUx2g?list=PLw-VjHDlEOguL2K_NwIl_tYcs9_FSt5v_&autoplay=1&modestbranding=1&iv_load_policy=3”, //url to display
              height:“80%”,
              width:“80%”,
              autoRefresh: false, //set to false for video
              updateInterval: 1, //in min. Only if autoRefresh: true
              displayLastUpdate: true,
              width: “100%”, // Optional. Default: 100%
              height: “400px”, //Optional. Default: 100px
              scrolling: “no”
                sdetweil @lpgjg
                @lpgjg ctrl-shift-i (letter I) to open the dev window, then select the console tab
                • A
                  @lpgjg
                  This video is not available on youtube, so yes it is normal that the magicmirror cannot load it.
                  Is it a private video ?
                  • Mykle1M
                    @sdetweil said in MMM-iFrame-Ping:
                    I’m the youngest of my older friends. (60)
                    • L
                      lpgjg
                      I guess I am the baby of the group after all at 58.
                      AgP42
                      The videos are all from YouTube and do not seem to be private. I have tried this three amongst quite a few others. If someone has a pop play list that works, can you please give it to me. I can try it.
                      https://www.youtube.com/watch?v=LH4Y1ZUUx2g&list=PLw-VjHDlEOguL2K_NwIl_tYcs9_FSt5v_
                      https://www.youtube.com/watch?v=JGwWNGJdvx8&list=PLMC9KNkIncKtPzgY-5rmhvj7fax8fdxoj
                      https://www.youtube.com/watch?v=WXBHCQYxwr0&list=PL4o29bINVT4EG_y-k5jGoOu3-Am8Nvi10
                      I right click on the video while its playing and then click on copy embed code, from there I copy the src and input that into iFrame and/or iFramPing. Which gives me the “video unavailable” when I start the mirror.
                      When I do the exact same for the following YouTube videos, the vids play fine.
                      https://www.youtube.com/watch?v=I_bOFxxqXOg&list=PL6GgLDsVQ7J-JEVldGtzIVlmC1MbvIZbO
                      https://www.youtube.com/watch?v=M3AYuDFdf88&list=PLwMdN-ylsjO5633clbN4nkygVXHpbcFwX
                      I will try the ctrl-shift-i and will be back soon…hopefully.
                      • L
                        lpgjg
                        Wow…did not expect that screen to pop up? Hope I got what you asked for.
                        Filter:
                        Load script: modules/MMM-iFrame//MMM-iFrame.js
                        module.js:477 Module registered: MMM-iFrame
                        loader.js:152 Bootstrapping module: MMM-iFrame
                        loader.js:157 Scripts loaded for: MMM-iFrame
                        loader.js:197 Load stylesheet: modules/MMM-iFrame/MMM-iFrame.css
                        loader.js:159 Styles loaded for: MMM-iFrame
                        loader.js:161 Translations loaded for: MMM-iFrame
                        loader.js:182 Load script: modules/MMM-iFrame-Ping//MMM-iFrame-Ping.js
                        module.js:477 Module registered: MMM-iFrame-Ping
                        loader.js:152 Bootstrapping module: MMM-iFrame-Ping
                        loader.js:157 Scripts loaded for: MMM-iFrame-Ping
                        loader.js:197 Load stylesheet: modules/MMM-iFrame-Ping/MMM-iFrame-Ping.css
                        loader.js:159 Styles loaded for: MMM-iFrame-Ping
                        loader.js:161 Translations loaded for: MMM-iFrame-Ping
                        MMM-iFrame-Ping.js:30 Starting module: MMM-iFrame-Ping
                        module.js:156 MMM-iFrame received a system notification: ALL_MODULES_STARTED
                        module.js:156 MMM-iFrame received a system notification: MODULE_DOM_CREATED
                        module.js:156 MMM-iFrame received a system notification: DOM_OBJECTS_CREATED
                        module.js:154 MMM-iFrame received a module notification: WEATHER from sender: MMM-NOAA3
                        module.js:154 MMM-iFrame received a module notification: CALENDAR_EVENTS from sender: calendar
                        MMM-iFrame.js:26 update0
                        MMM-iFrame.js:26 update1
                        MMM-iFrame.js:26 update2
                        MMM-iFrame.js:26 update3
                        MMM-iFrame.js:26 update4
                        MMM-iFrame.js:26 update5
                        MMM-iFrame.js:26 update6
                        Actually been trying both the MMM-iFrame & MMM-iFrame-Ping.
                        • A
                          Please try only one module at the time : or iFrame or iFrame-Ping but not both on the same config file.
                          All the 5 link you gave bellow are also working fine in my browser, but the first one you gave previously didn’t work.
                          • L
                            lpgjg
                            At first I did only try one module at a time , removing one complete before trying the other. I’ve only recently installed a few at a time just to try different links on each module try to triple my combinations.
                            I see no difference if I try one at a time or three at the same time. Even have MMM-SmartWebDisplay installed now and it also behaves the same way.
                            But i will try one at a time again when I get home later.
                            Wondering if its a Canadian copy right thing? Any Canadians on here have these modules running properly. If so, would love to see which playlists you have running.
                            Was there any errors on the info I provided?
                              JeroenV99
                              Anyone can help me?:slightly_smiling_face:
                              i want to put my google spreadsheets on my Magic Mirror and I thought it would be best with iframe
                              but when i put my link in the config there is no new item on my mirror
                              https://docs.google.com/spreadsheets/d/e/2PACX-1vTd-e8mpbbkZSfsZzQHrIevINnb-DVZnm5mPOmX3FqzS6yp6q_mxd0SnBbZ-hurB_7ET3sZDH_GFXil/pubhtml?gid=0&single=true
                              A 1 Reply Last reply
                              • A
                                AgP42 Project Sponsor Module Developer @JeroenV99
                                @JeroenV99
                                I also have an empty page with your link, so normal that the iFrame don’t display it !
                                • E
                                  Egnos
                                  Thank you very much to the developer for the excellent work!
                                  I would have a problem:
                                  In my MM I call the “MMM-iFrame-Ping” module twice, it appear on two different pages.
                                  The problem is if I want to set two different sizes.
                                  For some reason the size of one module affects the other, not allowing to have two distinct measures.
                                  Here is my config.js:
                                  		module: 'MMM-iFrame-Ping',
                                  		//position: 'middle_center',	// This can be any of the regions.
                                  		pages: {Welcome: "middle_center"},
                                  			url: "xxxxxxxxxx",
                                  			//height:"100%",
                                  			//width:"100%",
                                  			displayLastUpdate: false,
                                  			width: "50%", // Optional. Default: 100%
                                  			height: "500px", //Optional. Default: 100px
                                  			scrolling: "no"
                                  		pages: {Sport: "middle_center"},
                                  			url: "xxxxxxxxxx",
                                  			//height:"100%",
                                  			//width:"100%",
                                  			width: "30%", // Optional. Default: 100%
                                  			height: "350px", //Optional. Default: 100px
                                  			//width: "50%", // Optional. Default: 100%
                                  			//height: "500px", //Optional. Default: 100px
                                  			scrolling: "no"
                                  Does it happen to you too?
                                  Is this behavior correct?
                                  I hope I explained myself!
                                  Thanks.
                                  • H
                                    hawkeye
                                    hi i have installed this module and have it working to a point i just cant get youtube to work on it is there some thing im missing ?
                                    if i out my own website in as the url that loads google dosent though
                                    • 3 / 3
