Total Newbie 24" MagicMirror (Munich, Germany)
There is still a lot to do and improve but since I don’t have any experience in programming, Linux and home improvement, I am ok with it so far.
Short Video:
https://youtu.be/T5bE2UmlyXQ -
Looks good, what kind of glass an display are you using?
Best,
Peter
Danke! Thank you!
Glas:
https://www.brigla-shop.de/smart-mirror-921.htmlDisplay:
https://amzn.to/2SAy1pP -
what weather module and icons? pretty cool job!
This post is deleted! -
Thank you, I appreciate it!
The weather modules are both default but I changed the icons to animated ones:
https://www.amcharts.com/free-animated-svg-weather-icons/ -
@thedoorsfanatic hi, can you please share details, how to change icons? Just replace files in folder? How you make the “hw” - frameless mirror?
thanks
Zdeněk -
@zdenek
I downloaded the animated icon set from amcharts and copied them to a folder named “icons” in the css folder. Then I made changes to my custom.css.For example:
.currentweather .wi-day-sunny { content: url("/css/icons/day.svg"); } .weatherforecast .wi-day-sunny { content: url("/css/icons/day.svg"); height: 48px; margin-top: -6px; margin-left: -6px; } *
Change these numbers depending on your layout -
@thedoorsfanatic great, thanks
and how did you made frame-less mirror? there is no frame …
thanks, Zdeněk
@zdenek
I just glued the mirror to the edge of the monitor with this Pattex:
https://amzn.to/2XyGVbjNewbie style :relieved_face:
Since the glass is just 4mm thick it is not that heavy
