    Total Newbie 24" MagicMirror (Munich, Germany)
    42 Posts 13 Posters 52.6k Views 13 Watching
    • thedoorsfanaticT
      thedoorsfanatic @zdenek
      @zdenek
      I just glued the mirror to the edge of the monitor with this Pattex:
      https://amzn.to/2XyGVbj
      Newbie style :relieved_face:
      Since the glass is just 4mm thick it is not that heavy
      My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
      zdenekZ 1 Reply Last reply
      • zdenekZ
        zdenek @thedoorsfanatic
        @thedoorsfanatic ok, so another question - how did you “glue” it on the wall?
        thedoorsfanaticT 1 Reply Last reply
        • thedoorsfanaticT
          @zdenek
          Again, pretty simple, with this: https://amzn.to/2C7513z
          • zdenekZ
            @thedoorsfanatic great, thanks
            • thedoorsfanaticT
              thedoorsfanatic
              You are welcome !
              • ejay-ibmE
                ejay-ibm Project Sponsor Module Developer
                @zdenek Very nice looking and result.
                As often in mirror showcase, the back is not shown ( yes that’s often the ugly part as well I know :) ) but I think it is interesting to see how all hardware are implemented in the back .
                Would you mind to share some pictures of the back ?
                • thedoorsfanaticT
                  thedoorsfanatic @ejay-ibm
                  @ejay-ibm
                  Since there is no frame there is also no actual back besides the backside of the monitor.
                  The Raspi is sitting on a shelf below the mirror
                  • thedoorsfanaticT
                    thedoorsfanatic
                    Quick update:
                    https://youtu.be/xpJ4ubovD_o
                    Now with a Philips Hue Lightstrip in the back of the mirror
                    • A
                      Aries1984 Module Developer
                      Hi there…looks great! What module did you use for the countdown?
                      • thedoorsfanaticT
                        thedoorsfanatic @Aries1984
                        @Aries1984
                        Thanks a lot!
                        I used MMM-CountDown:
                        https://github.com/boazarad/MMM-CountDown
                        • thedoorsfanaticT
                          thedoorsfanatic
                          Now also with Local Transport module:
                          https://youtu.be/xoh6VZHyznY
                          Nun wird mir morgens auf dem Magic Mirror meine tägliche Pendelstrecke über die Google Maps API angezeigt.
                          • thedoorsfanaticT
                            thedoorsfanatic
                            New update with PIR sensor and new modules: Wunderlist to-dos, SoccerLiveScore & fuel prices in a range of a certain distance to my home:
                            https://youtu.be/5Cs3pCZamuM
                              dxfan227
                              Looks good, can I ask what kind of glassed you used. For me I want someting a little more Mirror like…your’s looks good but appeakrs not so reflective? A little more like clear acrylic.
                              Which PIR module did you use? and With PIR hardware?
                              • thedoorsfanaticT
                                thedoorsfanatic @dxfan227
                                @dxfan227
                                Thanks a lot!
                                I used Mirropane™ Chrome Spy glas, 4 mm thick, next time I might get 6 mm.
                                PIR hardware: https://amzn.to/2YNSxYr
                                Module: https://github.com/paviro/MMM-PIR-Sensor
                                • thedoorsfanaticT
                                  thedoorsfanatic
                                  I integrated two new modules into my MagicMirror:
                                  • MMM-GoogleFit
                                  • MMM-GoogleMapsTraffic
                                  Watch a short video:
                                  https://youtu.be/Z1bWmxJHmAQ
                                  German:
                                  Meinem MagicMirror habe ich zwei neue Module hinzugefügt: Tägliche Schrittanzahl meiner Garmin Fitness Watch und Körpergewicht, synchronisiert über Google Fit. Dazu eine Google Map meiner Umgebung inklusive aktueller Stauanzeige.
                                  • thedoorsfanaticT
                                    thedoorsfanatic
                                    https://youtu.be/VEH_AFpjQgM
                                    Experimenting with Background Slideshow module on my test monitor before inserting new functions into my Smart Mirror …
                                    Auf meinem Test-Monitor experimentiere ich mit dem Background Slideshow Modul herum, bevor ich meinem Smart Mirror neue Funktionen hinzufüge …
                                    • thedoorsfanaticT
                                      thedoorsfanatic
                                      https://youtu.be/frFSshaYkjw
                                      My Smart Mirror will now show the birthdays from my Google Contacts. In addition, the IP of two smartphones is polled every 30 seconds to check when a person was connected to the home network.
                                      German translation:
                                      Auf meinem Smart Mirror werden nun auch die Geburtstage aus meinen Google Kontakten angezeigt. Zusätzlich wird alle 30 Sekunden die IP zweier Smartphones abgefragt, um zu checken, wann eine Person mit dem heimischen Netzwerk verbunden war.
                                      • strawberry 3.141S
                                        strawberry 3.141 Project Sponsor Module Developer @thedoorsfanatic
                                        @thedoorsfanatic Looks nice and clean. Good job on the build.
                                        Greetings from Munich
                                        • H
                                          hayman @thedoorsfanatic
                                          @thedoorsfanatic said in Total Newbie 24" MagicMirror (Munich, Germany):
                                          .currentweather .wi-day-sunny {
                                          content: url(“/css/icons/day.svg”);
                                          nicely done will you please send your custom.css files ,thanks
                                          • thedoorsfanaticT
                                            thedoorsfanatic @hayman
                                            @hayman
                                            What exactly do you wanna know?
                                            H 1 Reply Last reply
