    Total Newbie 24" MagicMirror (Munich, Germany)
    42 Posts 13 Posters 52.6k Views 13 Watching
    • thedoorsfanaticT
      thedoorsfanatic
      Danke! Thank you!
      Glas:
      https://www.brigla-shop.de/smart-mirror-921.html
      Display:
      https://amzn.to/2SAy1pP
        cyberphox
        what weather module and icons? pretty cool job!
        thedoorsfanaticT 1 Reply Last reply
        • thedoorsfanaticT
          thedoorsfanatic @PeterStahr
          • thedoorsfanaticT
            thedoorsfanatic @cyberphox
            Thank you, I appreciate it!
            The weather modules are both default but I changed the icons to animated ones:
            https://www.amcharts.com/free-animated-svg-weather-icons/
            zdenekZ 1 Reply Last reply
            • zdenekZ
              zdenek @thedoorsfanatic
              @thedoorsfanatic hi, can you please share details, how to change icons? Just replace files in folder? How you make the “hw” - frameless mirror?
              thanks
              Zdeněk
              • thedoorsfanaticT
                thedoorsfanatic @zdenek
                @zdenek
                I downloaded the animated icon set from amcharts and copied them to a folder named “icons” in the css folder. Then I made changes to my custom.css.
                For example:
                .currentweather .wi-day-sunny {
                content: url("/css/icons/day.svg");
                .weatherforecast .wi-day-sunny {
                height: 48px;
                margin-top: -6px;
                margin-left: -6px;
                * Change these numbers depending on your layout
                zdenekZ H 2 Replies Last reply
                • zdenekZ
                  @thedoorsfanatic great, thanks
                  and how did you made frame-less mirror? there is no frame …
                  thanks, Zdeněk
                  • thedoorsfanaticT
                    @zdenek
                    I just glued the mirror to the edge of the monitor with this Pattex:
                    https://amzn.to/2XyGVbj
                    Newbie style :relieved_face:
                    Since the glass is just 4mm thick it is not that heavy
                    • zdenekZ
                      @thedoorsfanatic ok, so another question - how did you “glue” it on the wall?
                      • thedoorsfanaticT
                        @zdenek
                        Again, pretty simple, with this: https://amzn.to/2C7513z
                        • zdenekZ
                          • thedoorsfanaticT
                            thedoorsfanatic
                            You are welcome !
                            • ejay-ibmE
                              ejay-ibm Project Sponsor Module Developer
                              @zdenek Very nice looking and result.
                              As often in mirror showcase, the back is not shown ( yes that’s often the ugly part as well I know :) ) but I think it is interesting to see how all hardware are implemented in the back .
                              Would you mind to share some pictures of the back ?
                              • thedoorsfanaticT
                                thedoorsfanatic @ejay-ibm
                                @ejay-ibm
                                Since there is no frame there is also no actual back besides the backside of the monitor.
                                The Raspi is sitting on a shelf below the mirror
                                • thedoorsfanaticT
                                  thedoorsfanatic
                                  Quick update:
                                  https://youtu.be/xpJ4ubovD_o
                                  Now with a Philips Hue Lightstrip in the back of the mirror
                                  • A
                                    Aries1984 Module Developer
                                    Hi there…looks great! What module did you use for the countdown?
                                    • thedoorsfanaticT
                                      thedoorsfanatic @Aries1984
                                      @Aries1984
                                      Thanks a lot!
                                      I used MMM-CountDown:
                                      https://github.com/boazarad/MMM-CountDown
                                      • thedoorsfanaticT
                                        thedoorsfanatic
                                        Now also with Local Transport module:
                                        https://youtu.be/xoh6VZHyznY
                                        Nun wird mir morgens auf dem Magic Mirror meine tägliche Pendelstrecke über die Google Maps API angezeigt.
                                        • thedoorsfanaticT
                                          thedoorsfanatic
                                          New update with PIR sensor and new modules: Wunderlist to-dos, SoccerLiveScore & fuel prices in a range of a certain distance to my home:
                                          https://youtu.be/5Cs3pCZamuM
                                            dxfan227
                                            Looks good, can I ask what kind of glassed you used. For me I want someting a little more Mirror like…your’s looks good but appeakrs not so reflective? A little more like clear acrylic.
                                            Which PIR module did you use? and With PIR hardware?
