    Total Newbie 24" MagicMirror (Munich, Germany)
    42 Posts 13 Posters 51.7k Views 13 Watching
    • thedoorsfanaticT Offline
      thedoorsfanatic @zdenek
      @zdenek
      I downloaded the animated icon set from amcharts and copied them to a folder named “icons” in the css folder. Then I made changes to my custom.css.
      For example:
      .currentweather .wi-day-sunny {
      content: url("/css/icons/day.svg");
      .weatherforecast .wi-day-sunny {
      height: 48px;
      margin-top: -6px;
      margin-left: -6px;
      * Change these numbers depending on your layout
      My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
      zdenekZ H 2 Replies Last reply Reply Quote 1
      • zdenekZ Offline
        zdenek @thedoorsfanatic
        @thedoorsfanatic great, thanks
        and how did you made frame-less mirror? there is no frame …
        thanks, Zdeněk
        thedoorsfanaticT 1 Reply Last reply Reply Quote 1
          @zdenek
          I just glued the mirror to the edge of the monitor with this Pattex:
          https://amzn.to/2XyGVbj
          Newbie style :relieved_face:
          Since the glass is just 4mm thick it is not that heavy
          zdenekZ 1 Reply Last reply Reply Quote 0
          • zdenekZ Offline
            @thedoorsfanatic ok, so another question - how did you “glue” it on the wall?
            thedoorsfanaticT 1 Reply Last reply Reply Quote 0
              @zdenek
              Again, pretty simple, with this: https://amzn.to/2C7513z
              • zdenekZ Offline
                  thedoorsfanatic
                  You are welcome !
                  • ejay-ibmE Offline
                    ejay-ibm Project Sponsor Module Developer
                    @zdenek Very nice looking and result.
                    As often in mirror showcase, the back is not shown ( yes that’s often the ugly part as well I know :) ) but I think it is interesting to see how all hardware are implemented in the back .
                    Would you mind to share some pictures of the back ?
                      thedoorsfanatic @ejay-ibm
                      @ejay-ibm
                      Since there is no frame there is also no actual back besides the backside of the monitor.
                      The Raspi is sitting on a shelf below the mirror
                        thedoorsfanatic
                        Quick update:
                        https://youtu.be/xpJ4ubovD_o
                        Now with a Philips Hue Lightstrip in the back of the mirror
                          Aries1984 Module Developer
                          Hi there…looks great! What module did you use for the countdown?
                            thedoorsfanatic @Aries1984
                            @Aries1984
                            Thanks a lot!
                            I used MMM-CountDown:
                            https://github.com/boazarad/MMM-CountDown
                              thedoorsfanatic
                              Now also with Local Transport module:
                              https://youtu.be/xoh6VZHyznY
                              Nun wird mir morgens auf dem Magic Mirror meine tägliche Pendelstrecke über die Google Maps API angezeigt.
                                thedoorsfanatic
                                New update with PIR sensor and new modules: Wunderlist to-dos, SoccerLiveScore & fuel prices in a range of a certain distance to my home:
                                https://youtu.be/5Cs3pCZamuM
                                  dxfan227
                                  Looks good, can I ask what kind of glassed you used. For me I want someting a little more Mirror like…your’s looks good but appeakrs not so reflective? A little more like clear acrylic.
                                  Which PIR module did you use? and With PIR hardware?
                                    thedoorsfanatic @dxfan227
                                    @dxfan227
                                    Thanks a lot!
                                    I used Mirropane™ Chrome Spy glas, 4 mm thick, next time I might get 6 mm.
                                    PIR hardware: https://amzn.to/2YNSxYr
                                    Module: https://github.com/paviro/MMM-PIR-Sensor
                                      thedoorsfanatic
                                      I integrated two new modules into my MagicMirror:
                                      • MMM-GoogleFit
                                      • MMM-GoogleMapsTraffic
                                      Watch a short video:
                                      https://youtu.be/Z1bWmxJHmAQ
                                      German:
                                      Meinem MagicMirror habe ich zwei neue Module hinzugefügt: Tägliche Schrittanzahl meiner Garmin Fitness Watch und Körpergewicht, synchronisiert über Google Fit. Dazu eine Google Map meiner Umgebung inklusive aktueller Stauanzeige.
                                        thedoorsfanatic
                                        https://youtu.be/VEH_AFpjQgM
                                        Experimenting with Background Slideshow module on my test monitor before inserting new functions into my Smart Mirror …
                                        Auf meinem Test-Monitor experimentiere ich mit dem Background Slideshow Modul herum, bevor ich meinem Smart Mirror neue Funktionen hinzufüge …
                                          thedoorsfanatic
                                          https://youtu.be/frFSshaYkjw
                                          My Smart Mirror will now show the birthdays from my Google Contacts. In addition, the IP of two smartphones is polled every 30 seconds to check when a person was connected to the home network.
                                          German translation:
                                          Auf meinem Smart Mirror werden nun auch die Geburtstage aus meinen Google Kontakten angezeigt. Zusätzlich wird alle 30 Sekunden die IP zweier Smartphones abgefragt, um zu checken, wann eine Person mit dem heimischen Netzwerk verbunden war.
                                          • strawberry 3.141S Offline
                                            strawberry 3.141 Project Sponsor Module Developer @thedoorsfanatic
                                            @thedoorsfanatic Looks nice and clean. Good job on the build.
                                            Greetings from Munich
