    Beginner
    14 Posts 8 Posters 7.1k Views 8 Watching
    • thedoorsfanaticT
      thedoorsfanatic
      I am still a beginner but one of my best tipps so far:
      Don’t use a cheap SD card and make constant backups.
      For backups I use Win32DiskImager and WinSCP
      My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
        before doing anything mirror related, use the pi to turn on/off a light when u press a button…
        learn how the pi works.
          dxfan227
          Get a cana kit. will include most of waht you need and has a very good quick setup guide to get you up an running
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @BandNerd1002
            @BandNerd1002
            I think the installation tutorial is pretty good, only outdated a bit. Really, you’re only talking about 2 commands: The installation command for MagicMirror and the installation of dependencies command for MagicMirror. Installation of your OS is pretty straightforward, as well.
            You will learn as you go along. I did, starting out with no prior knowledge of the Pi or coding. I second all the suggestions above. Don’t forget to have fun.
              sdetweil @Mykle1
              @Mykle1 try my install script. It handles missing npm
              https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer/16
              Mykle1M 2 Replies Last reply Reply Quote 1
              • Mykle1M
                RIght! Forgot about that. I used it on my last install :thumbsup:
                  BandNerd1002
                  In the Pi terminal what is the command for the config file?
                  • Mykle1M
                    @BandNerd1002
                    This? In the MM directory:
                    npm run config:check
                    • Mykle1M
                      @sdetweil said in Beginner:
                      I just used your install script again, Sam, and it worked perfectly. :thumbsup:
                      In case it matters to you, I installed on an HP G60 laptop running ubuntu 16.04 LTS
                      • wdmarkW
                        wdmark @motdog
                        @motdog I am also a new and its fun when it works just the way I want
                        English is not my best I try my best and have fun
                          motdog @wdmark
                          @wdmark I “bugged” people when I couldn’t figure things out. Then you start to know what to look for. I am picking up my one way mirror tomorrow and will build in the next week or so. Just make sure you have a good working backup before trying to install a new module or changing the configuration of one you have working. It allows you to see what was working and prevents you from pulling your hair out.
                          • A
                            AImirror Banned
                            @BandNerd1002 said in Beginner:
                            What are some tips for a complete beginner for a raspberry pi?
                            Youtube has a grensom
                            He has a lot of set up videos
                            I think there will be a lot of help for beginners.
