    Beginner
    14 Posts 8 Posters 7.1k Views 8 Watching
      before doing anything mirror related, use the pi to turn on/off a light when u press a button…
      learn how the pi works.
        dxfan227
        Get a cana kit. will include most of waht you need and has a very good quick setup guide to get you up an running
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @BandNerd1002
          @BandNerd1002
          I think the installation tutorial is pretty good, only outdated a bit. Really, you’re only talking about 2 commands: The installation command for MagicMirror and the installation of dependencies command for MagicMirror. Installation of your OS is pretty straightforward, as well.
          You will learn as you go along. I did, starting out with no prior knowledge of the Pi or coding. I second all the suggestions above. Don’t forget to have fun.
            sdetweil @Mykle1
            @Mykle1 try my install script. It handles missing npm
            https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer/16
            Mykle1M 2 Replies Last reply Reply Quote 1
            • Mykle1M
              RIght! Forgot about that. I used it on my last install :thumbsup:
                BandNerd1002
                In the Pi terminal what is the command for the config file?
                • Mykle1M
                  @BandNerd1002
                  This? In the MM directory:
                  npm run config:check
                  • Mykle1M
                    @sdetweil said in Beginner:
                    I just used your install script again, Sam, and it worked perfectly. :thumbsup:
                    In case it matters to you, I installed on an HP G60 laptop running ubuntu 16.04 LTS
                    • wdmarkW
                      wdmark @motdog
                      @motdog I am also a new and its fun when it works just the way I want
                      English is not my best I try my best and have fun
                        motdog @wdmark
                        @wdmark I “bugged” people when I couldn’t figure things out. Then you start to know what to look for. I am picking up my one way mirror tomorrow and will build in the next week or so. Just make sure you have a good working backup before trying to install a new module or changing the configuration of one you have working. It allows you to see what was working and prevents you from pulling your hair out.
                        • A
                          AImirror Banned
                          @BandNerd1002 said in Beginner:
                          What are some tips for a complete beginner for a raspberry pi?
                          Youtube has a grensom
                          He has a lot of set up videos
                          I think there will be a lot of help for beginners.
