    Magic Mirror Mark IV
    7 Posts 3 Posters 7.7k Views 3 Watching
      bhepler Module Developer
      Yet another gift, this one for family. Lots of improvements in the basic wood craftsmanship, yet a few basic errors that I’m still kicking myself over. Most notably, the glass and the monitor aren’t the same size and it really affects how it turned out. The monitor isn’t the same quality as the previous ones and it shows if you’re looking for it. Ah, well.
      The next one will be better.
      That said, the miters on this one came out really well. A couple good passes with a router bit to get the multi-level effect:
      The Pi camera is attached to the construction paper. I had a devil of a time getting it flush, so I mounted it to the plastic case of a microSD->SD card adapter.
        Huh. Well, now the images uploaded properly. Yay!
        This one has the remote access code on it and I’ve already modified the compliments file to fit their house. They love it and they are the only people in their town to have one!
        Mykle1M M 2 Replies Last reply Reply Quote 0
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @bhepler
          @bhepler
          Nice miter and router work. 5 Star bro!
          Now, how the hell did you wind up with different sizes on your monitor and glass???
            motdog @bhepler
            @bhepler said in Magic Mirror Mark IV:
            Remote access code?
              bhepler Module Developer @Mykle1
              @Mykle1 - Remember when I mentioned the dumb mistakes? Yeah.
              I cut the pieces for the box to go around the monitor and put them roughly in place around the monitor for a test fit. I moved the pieces aside and then moved the monitor away and pushed the pieces back. Unfortunately… when I put the pieces back I screwed up the orientation of which piece butted into which other piece. So instead of having the sides capped by the top & bottom, I had the top & bottom capped by the sides. Then I measured the box & ordered the mirror.
              So the glass that arrived was too wide and too short. Instead of re-ordering the glass, I ordered another monitor and had to drop a size in order for it to fit. So… yeah, the monitor isn’t the full size of the glass.
              On the positive side, there is enough room above the monitor to mount the camera behind the glass. So it’s invisible to the family. On the downside… the screen isn’t as large as it could be and the backlight on the monitor lets you easily see the transition from monitor to construction paper. :(
                bhepler Module Developer @motdog
                @motdog said in Magic Mirror Mark IV:
                Remote access code?
                Technically, remote SSH access into the mirror through their firewall. It’s not really a code so much as an encrypted passkey.
                • Mykle1M
                  Ugh!
