    mmm Dad Jokes
    13 Posts 5 Posters 5.7k Views 4 Watching
      bokow
      Ok, what am I not doing right. I have placed the module
      in the config file and get no errror when running he MMM yet nothing shows on the screen when I run MM other than the normal MM items.
      Mykle1M 1 Reply Last reply
        motdog
        Try a reboot. I believe that it’s needed for this module
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @bokow
          @bokow
          Have you cloned the module into your modules folder?
          Your config entry should look like this. There is a comma missing in the example of the README file:
                   module: 'MMM-Dad-Jokes',
                   position: 'bottom_left', // Or wherever you want
                       updateInterval: 60000,
                       fadeSpeed: 4000
          Notice the closing curly bracket. It has a comma after it that needs to be there which is not depicted in the README example. Here is a screenshot of the module displayed in the lower_third position.
            bokow
            Thanks for all the reply’s will let you know if it works
              bokow
              Still have not got it to work, Here are the errors:
              SyntaxError: Unexpected token var
              at new Script (vm.js:74:7)
              at createScript (vm.js:246:10)
              at Object.runInThisContext (vm.js:298:10)
              at Module._compile (internal/modules/cjs/loader.js:678:28)
              at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
              at Module.load (internal/modules/cjs/loader.js:620:32)
              at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
              at Function.Module._load (internal/modules/cjs/loader.js:551:3)
              at Module.require (internal/modules/cjs/loader.js:658:17)
              at require (internal/modules/cjs/helpers.js:20:18)
              B 1 Reply Last reply
                bhepler Module Developer @bokow
                @bokow - Copy & paste your relevant config.js entry for MMM-Dad-Jokes here and we’ll take a quick look at it. Remember to use the markdown features of the board.
                  bokow
                  /* Magic Mirror Config Sample
                  • MIT Licensed.
                  • For more information how you can configurate this file
                  • See https://github.com/MichMich/MagicMirror#configuration
                  var config = {
                  // - “”, “0.0.0.0”, “::” to listen on any interface
                  // Default, when address config is left out, is “localhost”
                  port: 8080,
                  ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
                  // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
                  // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
                  language: "en",
                  timeFormat: 24,
                  units: "metric",
                  		module: "alert",
                  		module: "updatenotification",
                  		position: "top_bar"
                          module: 'MMM-icanhazdadjoke',
                          position: 'bottom_right',
                              // See below for configurable options
                  		module: "clock",
                  		position: "top_left"
                  		header: "US Holidays",
                  					symbol: "calendar-check",
                  		module: "compliments",
                  		position: "lower_third"
                  		module: "currentweather",
                  			locationID: "5007989",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
                  			appid: "90f012418925c43d4ac4e54f147c53be"
                  		module: "weatherforecast",
                  		header: "Weather Forecast",
                  			locationID: "5007989",  //ID from https://openweathermap.org/city
                  		module: "newsfeed",
                  		position: "bottom_bar",
                  			feeds: [
                  					title: "New York Times",
                  			showSourceTitle: true,
                  			showPublishDate: true
                  if (typeof module !== “undefined”) {module.exports = config;}
                    bokow
                    Never mind got the Dad Jokes working by moving where the text was displayed to a blank area of the screen
                      sdetweil @bokow
                      @bokow could u edit your post with the config and add three backticks (shifted left of 1 key) on the 1st line, then config start on line 2, and 3 backticks on the last line by themselves…
                        bokow
                        All I had to do was place the location of the jokes to an unoccupied part of the screen. It now works as advertised but t his raises a new problem with the calendar module. The calendar shows nothing, even holidays. I guess my question is where does this app take the calendar info from??
                          sdetweil @bokow
                          @bokow this app??
                          from your google calendar or apple ical…
                          u have to configure the url to the calendar
                            bokow
                            what url and to what app?
                              @bokow - First, please go edit your post with the config.js content and add the three back-ticks before the first line of the code and after the last line. That’s the markdown feature I was talking about.
                              Second, you will have to find the URL for your calendar in .ics format. Depending on what provider you are using, there will be different instructions on how to find it. A search for “export my calendar to ICS format” will get you pointed in the right direction.
