mmm Dad Jokes
Ok, what am I not doing right. I have placed the module
in the config file and get no errror when running he MMM yet nothing shows on the screen when I run MM other than the normal MM items. -
Try a reboot. I believe that it’s needed for this module
Have you cloned the module into your modules folder?
Your config entry should look like this. There is a comma missing in the example of the README file:
{ module: 'MMM-Dad-Jokes', position: 'bottom_left', // Or wherever you want config: { updateInterval: 60000, fadeSpeed: 4000 } },Notice the closing curly bracket. It has a comma after it that needs to be there which is not depicted in the README example. Here is a screenshot of the module displayed in the
lower_thirdposition.
Thanks for all the reply’s will let you know if it works
Still have not got it to work, Here are the errors:
SyntaxError: Unexpected token var
at new Script (vm.js:74:7)
at createScript (vm.js:246:10)
at Object.runInThisContext (vm.js:298:10)
at Module._compile (internal/modules/cjs/loader.js:678:28)
at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
at Module.load (internal/modules/cjs/loader.js:620:32)
at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
at Function.Module._load (internal/modules/cjs/loader.js:551:3)
at Module.require (internal/modules/cjs/loader.js:658:17)
at require (internal/modules/cjs/helpers.js:20:18) -
@bokow - Copy & paste your relevant
config.jsentry for MMM-Dad-Jokes here and we’ll take a quick look at it. Remember to use the markdown features of the board. -
/* Magic Mirror Config Sample
*- By Michael Teeuw http://michaelteeuw.nl
- MIT Licensed.
- For more information how you can configurate this file
- See https://github.com/MichMich/MagicMirror#configuration
var config = {
// - “”, “0.0.0.0”, “::” to listen on any interface
// Default, when address config is left out, is “localhost”
port: 8080,
ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
// [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
// [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],language: "en", timeFormat: 24, units: "metric", modules: [ { module: "alert", }, { module: "updatenotification", position: "top_bar" }, { module: 'MMM-icanhazdadjoke', position: 'bottom_right', config: { // See below for configurable options } }, { module: "clock", position: "top_left" }, { module: "calendar", header: "US Holidays", position: "top_left", config: { calendars: [ { symbol: "calendar-check", url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics" } ] } }, { module: "compliments", position: "lower_third" }, { module: "currentweather", position: "top_right", config: { location: "Saginaw", locationID: "5007989", //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city appid: "90f012418925c43d4ac4e54f147c53be" } }, { module: "weatherforecast", position: "top_right", header: "Weather Forecast", config: { location: "Saginaw", locationID: "5007989", //ID from https://openweathermap.org/city appid: "90f012418925c43d4ac4e54f147c53be" } }, { module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "New York Times", url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml" } ], showSourceTitle: true, showPublishDate: true } }, ]};
if (typeof module !== “undefined”) {module.exports = config;} -
Never mind got the Dad Jokes working by moving where the text was displayed to a blank area of the screen
@bokow could u edit your post with the config and add three backticks (shifted left of 1 key) on the 1st line, then config start on line 2, and 3 backticks on the last line by themselves…
All I had to do was place the location of the jokes to an unoccupied part of the screen. It now works as advertised but t his raises a new problem with the calendar module. The calendar shows nothing, even holidays. I guess my question is where does this app take the calendar info from??
@bokow this app??
from your google calendar or apple ical…
u have to configure the url to the calendar
what url and to what app?
@bokow - First, please go edit your post with the
config.jscontent and add the three back-ticks before the first line of the code and after the last line. That’s the markdown feature I was talking about.Second, you will have to find the URL for your calendar in .ics format. Depending on what provider you are using, there will be different instructions on how to find it. A search for “export my calendar to ICS format” will get you pointed in the right direction.
