    mmm Dad Jokes
    13 Posts 5 Posters 4.8k Views 4 Watching
    • bheplerB Offline
      bhepler Module Developer @bokow
      @bokow - Copy & paste your relevant config.js entry for MMM-Dad-Jokes here and we’ll take a quick look at it. Remember to use the markdown features of the board.
        bokow
        /* Magic Mirror Config Sample
        • MIT Licensed.
        • For more information how you can configurate this file
        • See https://github.com/MichMich/MagicMirror#configuration
        var config = {
        // - “”, “0.0.0.0”, “::” to listen on any interface
        // Default, when address config is left out, is “localhost”
        port: 8080,
        ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
        // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
        // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
        language: "en",
        timeFormat: 24,
        units: "metric",
        		module: "alert",
        		module: "updatenotification",
        		position: "top_bar"
                module: 'MMM-icanhazdadjoke',
                position: 'bottom_right',
                    // See below for configurable options
        		module: "clock",
        		position: "top_left"
        		header: "US Holidays",
        					symbol: "calendar-check",
        		module: "compliments",
        		position: "lower_third"
        		module: "currentweather",
        			locationID: "5007989",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
        			appid: "90f012418925c43d4ac4e54f147c53be"
        		module: "weatherforecast",
        		header: "Weather Forecast",
        			locationID: "5007989",  //ID from https://openweathermap.org/city
        		module: "newsfeed",
        		position: "bottom_bar",
        			feeds: [
        					title: "New York Times",
        			showSourceTitle: true,
        			showPublishDate: true
        if (typeof module !== “undefined”) {module.exports = config;}
          bokow
          Never mind got the Dad Jokes working by moving where the text was displayed to a blank area of the screen
            sdetweil @bokow
            @bokow could u edit your post with the config and add three backticks (shifted left of 1 key) on the 1st line, then config start on line 2, and 3 backticks on the last line by themselves…
              bokow
              All I had to do was place the location of the jokes to an unoccupied part of the screen. It now works as advertised but t his raises a new problem with the calendar module. The calendar shows nothing, even holidays. I guess my question is where does this app take the calendar info from??
                sdetweil @bokow
                @bokow this app??
                from your google calendar or apple ical…
                u have to configure the url to the calendar
                  bokow
                  what url and to what app?
                  • bheplerB Offline
                    @bokow - First, please go edit your post with the config.js content and add the three back-ticks before the first line of the code and after the last line. That’s the markdown feature I was talking about.
                    Second, you will have to find the URL for your calendar in .ics format. Depending on what provider you are using, there will be different instructions on how to find it. A search for “export my calendar to ICS format” will get you pointed in the right direction.
