    Bathroom Cabinet MM
    18 Posts 8 Posters 17.5k Views 8 Watching
    • cowboysdudeC Offline
      Very nice job!!! I like it!
        Mitchfarino Module Developer
        Is there a glow coming through from your monitor?
        That’s what I’m worrying about when I build mine
        • Y Offline
          yawns Moderator
          Looks very nice. I like the Y-Splitter to only have one power cord. That’s what I will try as well, when I start building the mirror.
          What is the blue light thing?
          • O Offline
            olliewarren411 @Mitchfarino
            @Mitchfarino
            There is no glow, if anything i would like my monitor to be brighter, for daytime use.
            • O Offline
              olliewarren411 @yawns
              @yawns The y-splitter is a good idea I definitely recommend it. the blue light is the control buttons for the monitor, so I can change settings etc. It was a lot bigger/the size of the foot for the monitor so I cut it down to as small as it would go.
              I 1 Reply Last reply Reply Quote 1
              • I Offline
                indigomejor @olliewarren411
                @olliewarren411 Hi, may I ask how you did the Y-splitter? Thank you!
                • O Offline
                  olliewarren411 @indigomejor
                  @indigomejor Hi,
                  It’s a pre-made product just so I can power the raspberry pi and my monitor but only have one wall outlet in use.
                  http://www.lindy.co.uk/cables-adapters-c1/power-c136/2-5m-uk-3-pin-plug-to-iec-c13-iec-c7-splitter-extension-cable-black-p9209/s9367?utm_source=google&utm_medium=cpc&utm_term=2-5m-uk-3-pin-plug-to-iec-c13-amp-iec-c7-splitter-extension-cable-black&utm_campaign=product%2Blisting%2Bads&gclid=CMfcgtndyM4CFU-6Gwod7TsKiw
                  I M 2 Replies Last reply Reply Quote 1
                  • I Offline
                    @olliewarren411 Oh! I’ve been looking for something like that, but cant find anything, because didnt know what I should write to google, now, I need to find it with EU plug, but thanks! You helped me very much!
                      Mitchfarino Module Developer @olliewarren411
                      @olliewarren411 How do you get that microusb for the Pi?
                      • O Offline
                        @Mitchfarino
                        I used an apple ipad charger to take from 240V to 5V 2.1A
                        http://www.apple.com/uk/shop/product/MD836B/B/apple-12w-usb-power-adapter?fnode=91
                          @olliewarren411 How does that work? Because the first cable you bought didn’t have anywhere to plug the ipad charger in to?
                          Sorry for the confusion, I’m just trying to visualise it
                          • Y Offline
                            yawns Moderator @Mitchfarino
                            @Mitchfarino
                            This should answer your question: http://www.hdcplayer.com/Up/day_150403/201504030705367346.jpg
                            You can remove the country specific adapter and plug in an ordinary cable. @MichMich did the same thing after blowing his first charging adapter.
                            M 2 Replies Last reply Reply Quote 2
                              Mitchfarino Module Developer @yawns
                              @yawns thanks very much!
                              Much better than having two wires coming out
                                @yawns @olliewarren411 I can’t find one anywhere
                                That one you posted is out of stock
                                • W Offline
                                  WeedWood @Mitchfarino
                                  @Mitchfarino https://www.amazon.de/Apple-MD836ZM-Power-Adapter-Watt/dp/B009WHV380/ref=sr_1_5?ie=UTF8&qid=1475758114&sr=8-5&keywords=apple+ladegerät
                                  Its just a apple charger
                                    Mitchfarino Module Developer @WeedWood
                                    @WeedWood I was talking about one of these, sorry - http://www.lindy.co.uk/cables-adapters-c1/power-c136/2-5m-uk-3-pin-plug-to-iec-c13-iec-c7-splitter-extension-cable-black-p9209/s9367?utm_source=google&utm_medium=cpc&utm_term=2-5m-uk-3-pin-plug-to-iec-c13-amp-iec-c7-splitter-extension-cable-black&utm_campaign=product%2Blisting%2Bads&gclid=CMfcgtndyM4CFU-6Gwod7TsKiw
                                      Simmons06
                                      @olliewarren411 said in Bathroom Cabinet MM:
                                      @indigomejor Hi,
                                      http://www.lindy.co.uk/cables-adapters-c1/power-c136/2-5m-uk-3-pin-plug-to-iec-c13-iec-c7-splitter-extension-cable-black-p9209/s9367?utm_source=google&utm_medium=cpc&utm_term=2-5m-uk-3-pin-plug-to-iec-c13-amp-iec-c7-splitter-extension-cable-black&utm_campaign=product%2Blisting%2Bads&gclid=CMfcgtndyM4CFU-6Gwod7TsKiw/[MyBalanceNow](https://www.mybalancenow.bid/)
                                      Thank you for posting that it could be just the thing to give inspiration to someone who needs it! Keep up the great work!
