    Bathroom Cabinet MM
    18 Posts 8 Posters 17.3k Views 8 Watching
    • O Offline
      olliewarren411 @yawns
      @yawns The y-splitter is a good idea I definitely recommend it. the blue light is the control buttons for the monitor, so I can change settings etc. It was a lot bigger/the size of the foot for the monitor so I cut it down to as small as it would go.
      I 1 Reply Last reply Reply Quote 1
      • I Offline
        indigomejor @olliewarren411
        @olliewarren411 Hi, may I ask how you did the Y-splitter? Thank you!
        • O Offline
          olliewarren411 @indigomejor
          @indigomejor Hi,
          It’s a pre-made product just so I can power the raspberry pi and my monitor but only have one wall outlet in use.
          http://www.lindy.co.uk/cables-adapters-c1/power-c136/2-5m-uk-3-pin-plug-to-iec-c13-iec-c7-splitter-extension-cable-black-p9209/s9367?utm_source=google&utm_medium=cpc&utm_term=2-5m-uk-3-pin-plug-to-iec-c13-amp-iec-c7-splitter-extension-cable-black&utm_campaign=product%2Blisting%2Bads&gclid=CMfcgtndyM4CFU-6Gwod7TsKiw
          I M 2 Replies Last reply Reply Quote 1
          • I Offline
            @olliewarren411 Oh! I’ve been looking for something like that, but cant find anything, because didnt know what I should write to google, now, I need to find it with EU plug, but thanks! You helped me very much!
              Mitchfarino Module Developer @olliewarren411
              @olliewarren411 How do you get that microusb for the Pi?
              • O Offline
                olliewarren411 @Mitchfarino
                @Mitchfarino
                I used an apple ipad charger to take from 240V to 5V 2.1A
                http://www.apple.com/uk/shop/product/MD836B/B/apple-12w-usb-power-adapter?fnode=91
                  @olliewarren411 How does that work? Because the first cable you bought didn’t have anywhere to plug the ipad charger in to?
                  Sorry for the confusion, I’m just trying to visualise it
                  • Y Offline
                    yawns Moderator @Mitchfarino
                    @Mitchfarino
                    This should answer your question: http://www.hdcplayer.com/Up/day_150403/201504030705367346.jpg
                    You can remove the country specific adapter and plug in an ordinary cable. @MichMich did the same thing after blowing his first charging adapter.
                    M 2 Replies Last reply Reply Quote 2
                      Mitchfarino Module Developer @yawns
                      @yawns thanks very much!
                      Much better than having two wires coming out
                        @yawns @olliewarren411 I can’t find one anywhere
                        That one you posted is out of stock
                        • W Offline
                          WeedWood @Mitchfarino
                          @Mitchfarino https://www.amazon.de/Apple-MD836ZM-Power-Adapter-Watt/dp/B009WHV380/ref=sr_1_5?ie=UTF8&qid=1475758114&sr=8-5&keywords=apple+ladegerät
                          Its just a apple charger
                            Mitchfarino Module Developer @WeedWood
                            @WeedWood I was talking about one of these, sorry - http://www.lindy.co.uk/cables-adapters-c1/power-c136/2-5m-uk-3-pin-plug-to-iec-c13-iec-c7-splitter-extension-cable-black-p9209/s9367?utm_source=google&utm_medium=cpc&utm_term=2-5m-uk-3-pin-plug-to-iec-c13-amp-iec-c7-splitter-extension-cable-black&utm_campaign=product%2Blisting%2Bads&gclid=CMfcgtndyM4CFU-6Gwod7TsKiw
                              Simmons06
                              @olliewarren411 said in Bathroom Cabinet MM:
                              @indigomejor Hi,
                              http://www.lindy.co.uk/cables-adapters-c1/power-c136/2-5m-uk-3-pin-plug-to-iec-c13-iec-c7-splitter-extension-cable-black-p9209/s9367?utm_source=google&utm_medium=cpc&utm_term=2-5m-uk-3-pin-plug-to-iec-c13-amp-iec-c7-splitter-extension-cable-black&utm_campaign=product%2Blisting%2Bads&gclid=CMfcgtndyM4CFU-6Gwod7TsKiw/[MyBalanceNow](https://www.mybalancenow.bid/)
                              Thank you for posting that it could be just the thing to give inspiration to someone who needs it! Keep up the great work!
