    328 Posts 27 Posters 726.8k Views 24 Watching
      sdetweil @potts-mike
      @potts-mike also, try again… fixed a messaging problem
      but… you have MM already installed… (if the folder exists, cause the log is put there)…
      so, you should be using the update-script to bring to next version…
        satsatt @sdetweil
        @sdetweil Can You help me please with this, running Your script gives me this
        doing test run = false
        saving custom.css
        upgrading from version 2.6.0 to 2.8.0
        fetching latest revisions
        error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge
        überschrieben werden:
        	package-lock.json
        	vendor/package-lock.json
        Bitte committen oder stashen Sie Ihre Änderungen, bevor sie mergen.
        Abbruch
        there were merge errors
        you should examine and resolve them
        using the command git log --oneline --decorate
        de57daa (grafted, HEAD ->
        how do i commit or stash?
          sdetweil @satsatt
          @satsatt can u post the contents of /home/pi/MagicMirror/installers/upgrade.log
          to stash, it is git stash
          but it should have prompted you to do that… so, please wait til I look thru the log
            satsatt @sdetweil
            @sdetweil ```
            Upgrade started - Sa Sep 14 09:01:30 CEST 2019
            doing test run = true
            downloading dumpactivemodules script
            saving custom.css
            remote name = origin
            current branch = master
            no files different from github version
            test merge result rc=‘’ if empty, no conflicts
            skipping merge, only test run
            processing for module MMM-SystemStats . please wait
            skipped processing for MMM-SystemStats, doing test run
            processing for module MMM-DWD-WarnWeather . please wait
            skipped processing for MMM-DWD-WarnWeather, doing test run
            restoring custom.css
            Upgrade ended - Sa Sep 14 09:01:33 CEST 2019
            Upgrade started - Sa Sep 14 09:02:16 CEST 2019
            user requested to apply changes
            saving custom.css
            executing merge, apply specified
            merge result rc= 1 Aktualisiere de57daa…a31546b
            Upgrade ended - Sa Sep 14 09:02:18 CEST 2019
            Upgrade started - Sa Sep 14 14:50:08 CEST 2019
            saving custom.css
              sdetweil @satsatt
              @satsatt great thanks…
              can u show me the results of
              git status
              thanks
                satsatt @sdetweil
                @sdetweil ```
                pi@raspberrypi:~/MagicMirror $ git status
                Auf Branch master
                Ihr Branch ist zu ‘origin/master’ um 2639 Commits hinterher, und kann vorgespult werden.
                (benutzen Sie “git pull”, um Ihren lokalen Branch zu aktualisieren)
                zum Commit vorgemerkte Änderungen:
                (benutzen Sie “git reset HEAD …” zum Entfernen aus der Staging-Area)
                geändert:       package-lock.json
                geändert:       vendor/package-lock.json
                Unversionierte Dateien:
                (benutzen Sie “git add …”, um die Änderungen zum Commit vorzumerken)
                installers/dumpactivemodules.js
                  sdetweil @satsatt
                  @satsatt english word search…
                  can u show me output of
                  locale
                    satsatt
                    pi@raspberrypi:~/MagicMirror $ locale
                    LANG=de_DE.UTF-8
                    LANGUAGE=de_DE.UTF-8
                    LC_CTYPE="de_DE.UTF-8"
                    LC_NUMERIC="de_DE.UTF-8"
                    LC_TIME="de_DE.UTF-8"
                    LC_COLLATE="de_DE.UTF-8"
                    LC_MONETARY="de_DE.UTF-8"
                    LC_MESSAGES="de_DE.UTF-8"
                    LC_PAPER="de_DE.UTF-8"
                    LC_NAME="de_DE.UTF-8"
                    LC_ADDRESS="de_DE.UTF-8"
                    LC_TELEPHONE="de_DE.UTF-8"
                    LC_MEASUREMENT="de_DE.UTF-8"
                    LC_IDENTIFICATION="de_DE.UTF-8"
                    LC_ALL=de_DE.UTF-8
                      satsatt
                      you want git status in english i suppose?
                        sdetweil @satsatt
                        @satsatt yes, working on that…
                          satsatt
                          I try
                          "your branch is regarding to origin/master 2639 commits back and can brought forward
                          use git pull to make your local branch actual
                          registered changes for Commit
                          ( use git reset for deleting from Staging-Area )
                          changed: package-lock.json
                          changed: vendor/package-lock.json
                          files not in version:
                          ( use git add for preparing files to commit )
                            sdetweil @satsatt
                            @satsatt ok, was gonna ask for this
                            alias git='LANGUAGE=en_US.UTF-8 git"
                            git status
                            unalias git
                              satsatt
                              @sdetweil said in new update/upgrade script, ready for testing:
                              unalias git
                              uh not ok
                              pi@raspberrypi:~/MagicMirror $ alias git='LANGUAGE=en_US.UTF-8 git"
                              > git status
                              > unalias git
                                sdetweil @satsatt
                                @satsatt sorry, bad paste
                                alias git='LANGUAGE=en_US.UTF-8 git'
                                git status
                                unalias git
                                  satsatt
                                  git status
                                  On branch master
                                  Your branch is behind 'origin/master' by 2639 commits, and can be fast-forwarded.
                                    (use "git pull" to update your local branch)
                                  Changes to be committed:
                                    (use "git reset HEAD <file>..." to unstage)
                                  	modified:   package-lock.json
                                  	modified:   vendor/package-lock.json
                                  Untracked files:
                                    (use "git add <file>..." to include in what will be committed)
                                    sdetweil @satsatt
                                    @satsatt great!.. thank you… can u try the update script again
                                      satsatt
                                      pi@raspberrypi:~/MagicMirror $ bash -c “$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)” apply
                                      saving custom.css
                                      apply: Zeile 88: alias: git: Nicht gefunden.
                                      package-lock.json
                                      Abbruch
                                      de57daa (grafted, HEAD -> master, tag: v2.6.0) Merge pull request #1498 from MichMich/develop
                                      apply: Zeile 256: [: ~=: Zweistelliger (binärer) Operator erwartet.
                                        satsatt
                                        sorry need to be away from terminal for 10h - thank’s alot
                                          sdetweil @satsatt
                                          @satsatt ok, when u have time , try the script again… thanks SO much for your help
                                          • BKeyportB Online
                                            BKeyport Module Developer
                                            Love this concept - question though - from what I’ve read (bits and pieces admittedly), it looks like it only handles the main software - could this be expanded to traverse your module directories and update them, so it could be run, say nightly, to check for and apply updates to everything?
                                            • 16
                                            • 17
                                            • 2 / 17
