    328 Posts 27 Posters 740.6k Views 24 Watching
      sdetweil @potts-mike
      @potts-mike thanks… try now… danged editing from windows got the wrong line end characters…
        potts-mike
        it ran with the following errors and magic mirror did not start.
        install log being saved to /home/pi/MagicMirror/installers/install.log
        Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
        Get:2 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
        Fetched 25.4 kB in 1s (22.4 kB/s)
        Reading package lists... Done
        Building dependency tree
        build-essential is already the newest version (12.3).
        curl is already the newest version (7.52.1-5+deb9u9).
        git is already the newest version (1:2.11.0-3+deb9u4).
        unzip is already the newest version (6.0-21+deb9u2).
        wget is already the newest version (1.18-5+deb9u3).
          coinor-libipopt1v5 libmumps-seq-4.10.0 libraw15
        Use 'sudo apt autoremove' to remove them.
        (node:4945) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
        npm is already the newest version (1.4.21+ds-2).
        (node:4979) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
        npm WARN package.json path-is-inside@1.0.2 No README data
        npm WARN package.json sorted-object@2.0.1 No README data
        /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
        /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
        npm WARN package.json config-chain@1.1.12 No license field.
        npm WARN package.json cyclist@0.2.2 No license field.
        npm WARN package.json json-schema@0.2.3 No license field.
        npm WARN package.json punycode@1.4.1 punycode is also the name of a node core module.
        npm WARN package.json qrcode-terminal@0.12.0 No license field.
        npm WARN package.json string_decoder@1.2.0 string_decoder is also the name of a node core module.
        npm@6.11.3 /usr/local/lib/node_modules/npm
        S 2 Replies Last reply
          @potts-mike can u send me the install.log, /home/pi/MagicMirror/installers/install.log
          same userid as here at gmail
          or post it here
            @potts-mike also, try again… fixed a messaging problem
            but… you have MM already installed… (if the folder exists, cause the log is put there)…
            so, you should be using the update-script to bring to next version…
              satsatt @sdetweil
              @sdetweil Can You help me please with this, running Your script gives me this
              doing test run = false
              saving custom.css
              upgrading from version 2.6.0 to 2.8.0
              fetching latest revisions
              error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge
              überschrieben werden:
              	package-lock.json
              	vendor/package-lock.json
              Bitte committen oder stashen Sie Ihre Änderungen, bevor sie mergen.
              Abbruch
              there were merge errors
              you should examine and resolve them
              using the command git log --oneline --decorate
              de57daa (grafted, HEAD ->
              how do i commit or stash?
                sdetweil @satsatt
                @satsatt can u post the contents of /home/pi/MagicMirror/installers/upgrade.log
                to stash, it is git stash
                but it should have prompted you to do that… so, please wait til I look thru the log
                  satsatt @sdetweil
                  @sdetweil ```
                  Upgrade started - Sa Sep 14 09:01:30 CEST 2019
                  doing test run = true
                  downloading dumpactivemodules script
                  saving custom.css
                  remote name = origin
                  current branch = master
                  no files different from github version
                  test merge result rc=‘’ if empty, no conflicts
                  skipping merge, only test run
                  processing for module MMM-SystemStats . please wait
                  skipped processing for MMM-SystemStats, doing test run
                  processing for module MMM-DWD-WarnWeather . please wait
                  skipped processing for MMM-DWD-WarnWeather, doing test run
                  restoring custom.css
                  Upgrade ended - Sa Sep 14 09:01:33 CEST 2019
                  Upgrade started - Sa Sep 14 09:02:16 CEST 2019
                  user requested to apply changes
                  saving custom.css
                  executing merge, apply specified
                  merge result rc= 1 Aktualisiere de57daa…a31546b
                  Upgrade ended - Sa Sep 14 09:02:18 CEST 2019
                  Upgrade started - Sa Sep 14 14:50:08 CEST 2019
                  saving custom.css
                    sdetweil @satsatt
                    @satsatt great thanks…
                    can u show me the results of
                    git status
                    thanks
                      satsatt @sdetweil
                      @sdetweil ```
                      pi@raspberrypi:~/MagicMirror $ git status
                      Auf Branch master
                      Ihr Branch ist zu ‘origin/master’ um 2639 Commits hinterher, und kann vorgespult werden.
                      (benutzen Sie “git pull”, um Ihren lokalen Branch zu aktualisieren)
                      zum Commit vorgemerkte Änderungen:
                      (benutzen Sie “git reset HEAD …” zum Entfernen aus der Staging-Area)
                      geändert:       package-lock.json
                      geändert:       vendor/package-lock.json
                      Unversionierte Dateien:
                      (benutzen Sie “git add …”, um die Änderungen zum Commit vorzumerken)
                      installers/dumpactivemodules.js
                        sdetweil @satsatt
                        @satsatt english word search…
                        can u show me output of
                        locale
                          satsatt
                          pi@raspberrypi:~/MagicMirror $ locale
                          LANG=de_DE.UTF-8
                          LANGUAGE=de_DE.UTF-8
                          LC_CTYPE="de_DE.UTF-8"
                          LC_NUMERIC="de_DE.UTF-8"
                          LC_TIME="de_DE.UTF-8"
                          LC_COLLATE="de_DE.UTF-8"
                          LC_MONETARY="de_DE.UTF-8"
                          LC_MESSAGES="de_DE.UTF-8"
                          LC_PAPER="de_DE.UTF-8"
                          LC_NAME="de_DE.UTF-8"
                          LC_ADDRESS="de_DE.UTF-8"
                          LC_TELEPHONE="de_DE.UTF-8"
                          LC_MEASUREMENT="de_DE.UTF-8"
                          LC_IDENTIFICATION="de_DE.UTF-8"
                          LC_ALL=de_DE.UTF-8
                            satsatt
                            you want git status in english i suppose?
                              sdetweil @satsatt
                              @satsatt yes, working on that…
                                satsatt
                                I try
                                "your branch is regarding to origin/master 2639 commits back and can brought forward
                                use git pull to make your local branch actual
                                registered changes for Commit
                                ( use git reset for deleting from Staging-Area )
                                changed: package-lock.json
                                changed: vendor/package-lock.json
                                files not in version:
                                ( use git add for preparing files to commit )
                                  sdetweil @satsatt
                                  @satsatt ok, was gonna ask for this
                                  alias git='LANGUAGE=en_US.UTF-8 git"
                                  git status
                                  unalias git
                                    satsatt
                                    @sdetweil said in new update/upgrade script, ready for testing:
                                    unalias git
                                    uh not ok
                                    pi@raspberrypi:~/MagicMirror $ alias git='LANGUAGE=en_US.UTF-8 git"
                                    > git status
                                    > unalias git
                                      sdetweil @satsatt
                                      @satsatt sorry, bad paste
                                      alias git='LANGUAGE=en_US.UTF-8 git'
                                      git status
                                      unalias git
                                        satsatt
                                        git status
                                        On branch master
                                        Your branch is behind 'origin/master' by 2639 commits, and can be fast-forwarded.
                                          (use "git pull" to update your local branch)
                                        Changes to be committed:
                                          (use "git reset HEAD <file>..." to unstage)
                                        	modified:   package-lock.json
                                        	modified:   vendor/package-lock.json
                                        Untracked files:
                                          (use "git add <file>..." to include in what will be committed)
                                          sdetweil @satsatt
                                          @satsatt great!.. thank you… can u try the update script again
                                            satsatt
                                            pi@raspberrypi:~/MagicMirror $ bash -c “$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)” apply
                                            saving custom.css
                                            apply: Zeile 88: alias: git: Nicht gefunden.
                                            package-lock.json
                                            Abbruch
                                            de57daa (grafted, HEAD -> master, tag: v2.6.0) Merge pull request #1498 from MichMich/develop
                                            apply: Zeile 256: [: ~=: Zweistelliger (binärer) Operator erwartet.
                                            • 16
                                            • 17
                                            • 2 / 17
