    328 Posts 27 Posters 740.6k Views 24 Watching
    • Mykle1M
      @sdetweil said in new update/upgrade script, ready for testing:
      Thanks for the test. Updated script to handle
      I wish I would have waited for the updated script. I went ahead and installed a new MM because I couldn’t move forward with what I am doing. Again, thanks for your scripts. I will continue to use them. They’re awesome. :thumbsup:
        sdetweil @Mykle1
        @Mykle1 I think u did the right thing. The “handle” is to bail out gracefully if there is no git repo locally (zip file install doesn’t provide any path forward, that I have found)
        • Mykle1M
          Understood, thanks. :-)
            Added some reporting of current version and version upgrading to.
            Also had path that did a live merge when u were just testing. Fixed that
              another update… i was reporting ALL the files that changed between versions, but who cares (things are SUPPOSED the change!)… we only care if there is a conflict… fixed that
                potts-mike
                I am getting the below errors when trying to run your installer script, thoughts?
                bash: line 18: $‘\r’: command not found
                bash: line 20: $‘\r’: command not found
                bash: line 27: $‘\r’: command not found
                bash: -c: line 28: syntax error near unexpected token $'{\r'' 'ash: -c: line 28: trim() {
                  sdetweil @potts-mike
                  @potts-mike thanks… try now… danged editing from windows got the wrong line end characters…
                    potts-mike
                    it ran with the following errors and magic mirror did not start.
                    install log being saved to /home/pi/MagicMirror/installers/install.log
                    Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                    Get:2 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
                    Fetched 25.4 kB in 1s (22.4 kB/s)
                    Reading package lists... Done
                    Building dependency tree
                    build-essential is already the newest version (12.3).
                    curl is already the newest version (7.52.1-5+deb9u9).
                    git is already the newest version (1:2.11.0-3+deb9u4).
                    unzip is already the newest version (6.0-21+deb9u2).
                    wget is already the newest version (1.18-5+deb9u3).
                      coinor-libipopt1v5 libmumps-seq-4.10.0 libraw15
                    Use 'sudo apt autoremove' to remove them.
                    (node:4945) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
                    npm is already the newest version (1.4.21+ds-2).
                    (node:4979) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
                    npm WARN package.json path-is-inside@1.0.2 No README data
                    npm WARN package.json sorted-object@2.0.1 No README data
                    /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                    /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                    npm WARN package.json config-chain@1.1.12 No license field.
                    npm WARN package.json cyclist@0.2.2 No license field.
                    npm WARN package.json json-schema@0.2.3 No license field.
                    npm WARN package.json punycode@1.4.1 punycode is also the name of a node core module.
                    npm WARN package.json qrcode-terminal@0.12.0 No license field.
                    npm WARN package.json string_decoder@1.2.0 string_decoder is also the name of a node core module.
                    npm@6.11.3 /usr/local/lib/node_modules/npm
                      @potts-mike can u send me the install.log, /home/pi/MagicMirror/installers/install.log
                      same userid as here at gmail
                      or post it here
                        @potts-mike also, try again… fixed a messaging problem
                        but… you have MM already installed… (if the folder exists, cause the log is put there)…
                        so, you should be using the update-script to bring to next version…
                          satsatt @sdetweil
                          @sdetweil Can You help me please with this, running Your script gives me this
                          doing test run = false
                          saving custom.css
                          upgrading from version 2.6.0 to 2.8.0
                          fetching latest revisions
                          error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge
                          überschrieben werden:
                          	package-lock.json
                          	vendor/package-lock.json
                          Bitte committen oder stashen Sie Ihre Änderungen, bevor sie mergen.
                          Abbruch
                          there were merge errors
                          you should examine and resolve them
                          using the command git log --oneline --decorate
                          de57daa (grafted, HEAD ->
                          how do i commit or stash?
                            sdetweil @satsatt
                            @satsatt can u post the contents of /home/pi/MagicMirror/installers/upgrade.log
                            to stash, it is git stash
                            but it should have prompted you to do that… so, please wait til I look thru the log
                              satsatt @sdetweil
                              @sdetweil ```
                              Upgrade started - Sa Sep 14 09:01:30 CEST 2019
                              doing test run = true
                              downloading dumpactivemodules script
                              saving custom.css
                              remote name = origin
                              current branch = master
                              no files different from github version
                              test merge result rc=‘’ if empty, no conflicts
                              skipping merge, only test run
                              processing for module MMM-SystemStats . please wait
                              skipped processing for MMM-SystemStats, doing test run
                              processing for module MMM-DWD-WarnWeather . please wait
                              skipped processing for MMM-DWD-WarnWeather, doing test run
                              restoring custom.css
                              Upgrade ended - Sa Sep 14 09:01:33 CEST 2019
                              Upgrade started - Sa Sep 14 09:02:16 CEST 2019
                              user requested to apply changes
                              saving custom.css
                              executing merge, apply specified
                              merge result rc= 1 Aktualisiere de57daa…a31546b
                              Upgrade ended - Sa Sep 14 09:02:18 CEST 2019
                              Upgrade started - Sa Sep 14 14:50:08 CEST 2019
                              saving custom.css
                                sdetweil @satsatt
                                @satsatt great thanks…
                                can u show me the results of
                                git status
                                thanks
                                  satsatt @sdetweil
                                  @sdetweil ```
                                  pi@raspberrypi:~/MagicMirror $ git status
                                  Auf Branch master
                                  Ihr Branch ist zu ‘origin/master’ um 2639 Commits hinterher, und kann vorgespult werden.
                                  (benutzen Sie “git pull”, um Ihren lokalen Branch zu aktualisieren)
                                  zum Commit vorgemerkte Änderungen:
                                  (benutzen Sie “git reset HEAD …” zum Entfernen aus der Staging-Area)
                                  geändert:       package-lock.json
                                  geändert:       vendor/package-lock.json
                                  Unversionierte Dateien:
                                  (benutzen Sie “git add …”, um die Änderungen zum Commit vorzumerken)
                                  installers/dumpactivemodules.js
                                    sdetweil @satsatt
                                    @satsatt english word search…
                                    can u show me output of
                                    locale
                                      satsatt
                                      pi@raspberrypi:~/MagicMirror $ locale
                                      LANG=de_DE.UTF-8
                                      LANGUAGE=de_DE.UTF-8
                                      LC_CTYPE="de_DE.UTF-8"
                                      LC_NUMERIC="de_DE.UTF-8"
                                      LC_TIME="de_DE.UTF-8"
                                      LC_COLLATE="de_DE.UTF-8"
                                      LC_MONETARY="de_DE.UTF-8"
                                      LC_MESSAGES="de_DE.UTF-8"
                                      LC_PAPER="de_DE.UTF-8"
                                      LC_NAME="de_DE.UTF-8"
                                      LC_ADDRESS="de_DE.UTF-8"
                                      LC_TELEPHONE="de_DE.UTF-8"
                                      LC_MEASUREMENT="de_DE.UTF-8"
                                      LC_IDENTIFICATION="de_DE.UTF-8"
                                      LC_ALL=de_DE.UTF-8
                                        satsatt
                                        you want git status in english i suppose?
                                          sdetweil @satsatt
                                          @satsatt yes, working on that…
                                            satsatt
                                            I try
                                            "your branch is regarding to origin/master 2639 commits back and can brought forward
                                            use git pull to make your local branch actual
                                            registered changes for Commit
                                            ( use git reset for deleting from Staging-Area )
                                            changed: package-lock.json
                                            changed: vendor/package-lock.json
                                            files not in version:
                                            ( use git add for preparing files to commit )
                                            • 16
                                            • 17
                                            • 2 / 17
