    328 Posts 27 Posters 740.6k Views 24 Watching
      Those files are in the current GitHub repo.
      • G
        Gomalley @sdetweil
        • Mykle1M
          @sdetweil said in new update/upgrade script, ready for testing:
          can u send me the mm/installers/upgrade.log
          Tried using the your upgrade script. Current MM version 2.6.
          Upgrade started - Tue Aug 20 21:51:16 EDT 2019
          doing test run = true
          downloading dumpactivemodules script
          saving custom.css
          remote name =
          fetching latest revisions
          MagicMirror git pull failed
          restoring custom.css
          Upgrade ended - Tue Aug 20 21:51:17 EDT 2019
            sdetweil @Mykle1
            @Mykle1 can u do a git status, and git remote -v
            In the MagicMirror folder
              i added a check for the git remote not being set.
                sdetweil @Mykle1
                @Mykle1 but at least there is a log to look at!
                • Mykle1M
                  It’s very likely that this was a manual installation of MM (in case that matters)
                  pop@E8300:~$ cd MagicMirror/
                  pop@E8300:~/MagicMirror$ git status
                  fatal: not a git repository (or any of the parent directories): .git
                  pop@E8300:~/MagicMirror$ git remote -v
                  pop@E8300:~/MagicMirror$ ^C
                    sdetweil @Mykle1
                    @Mykle1 is it possible u might have downloaded the code as a zip file, instead of doing git clone?
                    Only way I can think of to get into this state
                    • Mykle1M
                      Yes Sam, that is what I meant by a manual installation. :-/
                        sdetweil @Mykle1
                        @Mykle1 cool. Thanks for the test. Updated script to handle
                        • Mykle1M
                          I wish I would have waited for the updated script. I went ahead and installed a new MM because I couldn’t move forward with what I am doing. Again, thanks for your scripts. I will continue to use them. They’re awesome. :thumbsup:
                            sdetweil @Mykle1
                            @Mykle1 I think u did the right thing. The “handle” is to bail out gracefully if there is no git repo locally (zip file install doesn’t provide any path forward, that I have found)
                            • Mykle1M
                              Understood, thanks. :-)
                                Added some reporting of current version and version upgrading to.
                                Also had path that did a live merge when u were just testing. Fixed that
                                  another update… i was reporting ALL the files that changed between versions, but who cares (things are SUPPOSED the change!)… we only care if there is a conflict… fixed that
                                    potts-mike
                                    I am getting the below errors when trying to run your installer script, thoughts?
                                    bash: line 18: $‘\r’: command not found
                                    bash: line 20: $‘\r’: command not found
                                    bash: line 27: $‘\r’: command not found
                                    bash: -c: line 28: syntax error near unexpected token $'{\r'' 'ash: -c: line 28: trim() {
                                      sdetweil @potts-mike
                                      @potts-mike thanks… try now… danged editing from windows got the wrong line end characters…
                                        potts-mike
                                        it ran with the following errors and magic mirror did not start.
                                        install log being saved to /home/pi/MagicMirror/installers/install.log
                                        Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                                        Get:2 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
                                        Fetched 25.4 kB in 1s (22.4 kB/s)
                                        Reading package lists... Done
                                        Building dependency tree
                                        build-essential is already the newest version (12.3).
                                        curl is already the newest version (7.52.1-5+deb9u9).
                                        git is already the newest version (1:2.11.0-3+deb9u4).
                                        unzip is already the newest version (6.0-21+deb9u2).
                                        wget is already the newest version (1.18-5+deb9u3).
                                          coinor-libipopt1v5 libmumps-seq-4.10.0 libraw15
                                        Use 'sudo apt autoremove' to remove them.
                                        (node:4945) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
                                        npm is already the newest version (1.4.21+ds-2).
                                        (node:4979) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
                                        npm WARN package.json path-is-inside@1.0.2 No README data
                                        npm WARN package.json sorted-object@2.0.1 No README data
                                        /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                                        /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                                        npm WARN package.json config-chain@1.1.12 No license field.
                                        npm WARN package.json cyclist@0.2.2 No license field.
                                        npm WARN package.json json-schema@0.2.3 No license field.
                                        npm WARN package.json punycode@1.4.1 punycode is also the name of a node core module.
                                        npm WARN package.json qrcode-terminal@0.12.0 No license field.
                                        npm WARN package.json string_decoder@1.2.0 string_decoder is also the name of a node core module.
                                        npm@6.11.3 /usr/local/lib/node_modules/npm
                                          @potts-mike can u send me the install.log, /home/pi/MagicMirror/installers/install.log
                                          same userid as here at gmail
                                          or post it here
                                            @potts-mike also, try again… fixed a messaging problem
                                            but… you have MM already installed… (if the folder exists, cause the log is put there)…
                                            so, you should be using the update-script to bring to next version…
                                            • 16
                                            • 17
                                            • 1 / 17
