    328 Posts 27 Posters 740.6k Views 24 Watching
    • G
      Gomalley @sdetweil
      • Mykle1M
        @sdetweil said in new update/upgrade script, ready for testing:
        can u send me the mm/installers/upgrade.log
        Tried using the your upgrade script. Current MM version 2.6.
        Upgrade started - Tue Aug 20 21:51:16 EDT 2019
        doing test run = true
        downloading dumpactivemodules script
        saving custom.css
        remote name =
        fetching latest revisions
        MagicMirror git pull failed
        restoring custom.css
        Upgrade ended - Tue Aug 20 21:51:17 EDT 2019
          sdetweil @Mykle1
          @Mykle1 can u do a git status, and git remote -v
          In the MagicMirror folder
            i added a check for the git remote not being set.
              sdetweil @Mykle1
              @Mykle1 but at least there is a log to look at!
              • Mykle1M
                It’s very likely that this was a manual installation of MM (in case that matters)
                pop@E8300:~$ cd MagicMirror/
                pop@E8300:~/MagicMirror$ git status
                fatal: not a git repository (or any of the parent directories): .git
                pop@E8300:~/MagicMirror$ git remote -v
                pop@E8300:~/MagicMirror$ ^C
                  sdetweil @Mykle1
                  @Mykle1 is it possible u might have downloaded the code as a zip file, instead of doing git clone?
                  Only way I can think of to get into this state
                  • Mykle1M
                    Yes Sam, that is what I meant by a manual installation. :-/
                      sdetweil @Mykle1
                      @Mykle1 cool. Thanks for the test. Updated script to handle
                      • Mykle1M
                        I wish I would have waited for the updated script. I went ahead and installed a new MM because I couldn’t move forward with what I am doing. Again, thanks for your scripts. I will continue to use them. They’re awesome. :thumbsup:
                          sdetweil @Mykle1
                          @Mykle1 I think u did the right thing. The “handle” is to bail out gracefully if there is no git repo locally (zip file install doesn’t provide any path forward, that I have found)
                          • Mykle1M
                            Understood, thanks. :-)
                              Added some reporting of current version and version upgrading to.
                              Also had path that did a live merge when u were just testing. Fixed that
                                another update… i was reporting ALL the files that changed between versions, but who cares (things are SUPPOSED the change!)… we only care if there is a conflict… fixed that
                                  potts-mike
                                  I am getting the below errors when trying to run your installer script, thoughts?
                                  bash: line 18: $‘\r’: command not found
                                  bash: line 20: $‘\r’: command not found
                                  bash: line 27: $‘\r’: command not found
                                  bash: -c: line 28: syntax error near unexpected token $'{\r'' 'ash: -c: line 28: trim() {
                                    sdetweil @potts-mike
                                    @potts-mike thanks… try now… danged editing from windows got the wrong line end characters…
                                      potts-mike
                                      it ran with the following errors and magic mirror did not start.
                                      install log being saved to /home/pi/MagicMirror/installers/install.log
                                      Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                                      Get:2 http://archive.raspberrypi.org/debian stretch InRelease [25.4 kB]
                                      Fetched 25.4 kB in 1s (22.4 kB/s)
                                      Reading package lists... Done
                                      Building dependency tree
                                      build-essential is already the newest version (12.3).
                                      curl is already the newest version (7.52.1-5+deb9u9).
                                      git is already the newest version (1:2.11.0-3+deb9u4).
                                      unzip is already the newest version (6.0-21+deb9u2).
                                      wget is already the newest version (1.18-5+deb9u3).
                                        coinor-libipopt1v5 libmumps-seq-4.10.0 libraw15
                                      Use 'sudo apt autoremove' to remove them.
                                      (node:4945) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
                                      npm is already the newest version (1.4.21+ds-2).
                                      (node:4979) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
                                      npm WARN package.json path-is-inside@1.0.2 No README data
                                      npm WARN package.json sorted-object@2.0.1 No README data
                                      /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                                      /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                                      npm WARN package.json config-chain@1.1.12 No license field.
                                      npm WARN package.json cyclist@0.2.2 No license field.
                                      npm WARN package.json json-schema@0.2.3 No license field.
                                      npm WARN package.json punycode@1.4.1 punycode is also the name of a node core module.
                                      npm WARN package.json qrcode-terminal@0.12.0 No license field.
                                      npm WARN package.json string_decoder@1.2.0 string_decoder is also the name of a node core module.
                                      npm@6.11.3 /usr/local/lib/node_modules/npm
                                        @potts-mike can u send me the install.log, /home/pi/MagicMirror/installers/install.log
                                        same userid as here at gmail
                                        or post it here
                                          @potts-mike also, try again… fixed a messaging problem
                                          but… you have MM already installed… (if the folder exists, cause the log is put there)…
                                          so, you should be using the update-script to bring to next version…
                                            satsatt @sdetweil
                                            @sdetweil Can You help me please with this, running Your script gives me this
                                            doing test run = false
                                            saving custom.css
                                            upgrading from version 2.6.0 to 2.8.0
                                            error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge
                                            überschrieben werden:
                                            	package-lock.json
                                            	vendor/package-lock.json
                                            Bitte committen oder stashen Sie Ihre Änderungen, bevor sie mergen.
                                            Abbruch
                                            there were merge errors
                                            you should examine and resolve them
                                            using the command git log --oneline --decorate
                                            de57daa (grafted, HEAD ->
                                            how do i commit or stash?
                                            • 16
                                            • 17
                                            • 2 / 17
