    328 Posts 27 Posters 691.1k Views 24 Watching
      given that we will have a regular update quarterly, and we have such a large number of new users experiencing troubles after updates (mostly cause they have a ton to learn)… I have developed a script I would like to get included for future updates…
      it should handle all the work…
      and give you a trial run of all that…
      only applying changes if u request them
      give it a try
      this works on Mac as well
        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
      no changes are made to the local repo or the working copy
      if you WANT to actually apply the changes do
        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
      there is a log file in the installers folder…
      edited Jan 4, 2020 - move from dropbox to github as distro
      S 1 Reply Last reply Reply Quote 6
        I also have a newer installer that resolves a lot of problems with PM2, and supports installing on non-PI systems (Mac, pi zero, odroid, jetson nano)
         bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
        Mykle1M 1 Reply Last reply Reply Quote 4
          Personally, I’d like to thank you, Sam, for your excellent work on the install scripts. I’ve used them twice in the past and they worked perfectly
            sdetweil @Mykle1
            @Mykle1 thx. The pm2 on Mac was a challenge. Helped cleanup the older code tho.
            • T Offline
              trividar
              @sdetweil Could you explain exactly what this script is? THX
              T S 2 Replies Last reply Reply Quote 0
              • T Offline
                trividar @trividar
                @sdetweil I found it ;o)
                  sdetweil @trividar
                  @trividar there are two scripts referenced above
                  a new updated installer script, that hopefully fixes some of the problems reported
                  a brand new script that will do the update/upgrade to the next MM version when it comes out.
                  the current MM plan is to release a new version every 90 days (quarter)
                  look thru the forums for how many people had trouble installing the update…
                  2.7 from 2.6, and 2.8 from 2.7…
                    i updated the links in the 1st post to add .sh to the end of the script name to be consistent with the other two scripts
                    raspberry.sh install
                    fixuppm2.sh fix pm2 without having to do install (or u changed your mind)
                    and now
                    update-script.sh do all the work to update your current install to new code level
                      MwMagicMirror
                      @sdetweil said in new update/upgrade script, ready for testing:
                      bash -c “$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)” apply
                      I just ran your script and get the following errors:
                      error: pathspec ‘.github/stale.yml’ did not match any file(s) known to git.
                      error: pathspec ‘modules/default/calendar/vendor/ical.js/example_rrule.js’ did not match any file(s) known to git.
                      error: pathspec ‘modules/default/calendar/vendor/ical.js/examples/example_rrule.ics’ did not match any file(s) known to git.
                      error: pathspec ‘modules/default/calendar/vendor/ical.js/test/test12.ics’ did not match any file(s) known to git.
                      error: pathspec ‘modules/default/calendar/vendor/ical.js/test/test13.ics’ did not match any file(s) known to git.
                      error: pathspec ‘modules/default/calendar/vendor/ical.js/test/test14.ics’ did not match any file(s) known to git.
                      error: pathspec ‘modules/default/weather/providers/ukmetoffice.js’ did not match any file(s) known to git.
                      error: pathspec ‘modules/default/weather/providers/weathergov.js’ did not match any file(s) known to git.
                      error: pathspec ‘translations/sk.json’ did not match any file(s) known to git.
                      error: pathspec ‘translations/tlh.json’ did not match any file(s) known to git.
                      error: pathspec ‘vendor/css/font-awesome.css’ did not match any file(s) known to git.
                      Any Ideas? I dont recall messing with any of those files.
                      MW
                        sdetweil @MwMagicMirror
                        @MwMagicMirror can u send me the mm/installers/upgrade.log
                        Same userid as here at Gmail.com
                        G Mykle1M 2 Replies Last reply Reply Quote 0
                          Those files are in the current GitHub repo.
                          • G Offline
                            Gomalley @sdetweil
                              Tried using the your upgrade script. Current MM version 2.6.
                              Upgrade started - Tue Aug 20 21:51:16 EDT 2019
                              doing test run = true
                              downloading dumpactivemodules script
                              saving custom.css
                              remote name =
                              fetching latest revisions
                              MagicMirror git pull failed
                              restoring custom.css
                              Upgrade ended - Tue Aug 20 21:51:17 EDT 2019
                                sdetweil @Mykle1
                                @Mykle1 can u do a git status, and git remote -v
                                In the MagicMirror folder
                                  i added a check for the git remote not being set.
                                    sdetweil @Mykle1
                                    @Mykle1 but at least there is a log to look at!
                                      It’s very likely that this was a manual installation of MM (in case that matters)
                                      pop@E8300:~$ cd MagicMirror/
                                      pop@E8300:~/MagicMirror$ git status
                                      fatal: not a git repository (or any of the parent directories): .git
                                      pop@E8300:~/MagicMirror$ git remote -v
                                      pop@E8300:~/MagicMirror$ ^C
                                        sdetweil @Mykle1
                                        @Mykle1 is it possible u might have downloaded the code as a zip file, instead of doing git clone?
                                        Only way I can think of to get into this state
                                          Yes Sam, that is what I meant by a manual installation. :-/
                                            sdetweil @Mykle1
                                            @Mykle1 cool. Thanks for the test. Updated script to handle
                                            • 16
                                            • 17
                                            • 1 / 17
