    328 Posts 27 Posters 726.3k Views 24 Watching
      Personally, I’d like to thank you, Sam, for your excellent work on the install scripts. I’ve used them twice in the past and they worked perfectly
        sdetweil @Mykle1
        @Mykle1 thx. The pm2 on Mac was a challenge. Helped cleanup the older code tho.
        • T Offline
          trividar
          @sdetweil Could you explain exactly what this script is? THX
          T S 2 Replies Last reply Reply Quote 0
          • T Offline
            trividar @trividar
            @sdetweil I found it ;o)
              sdetweil @trividar
              @trividar there are two scripts referenced above
              a new updated installer script, that hopefully fixes some of the problems reported
              a brand new script that will do the update/upgrade to the next MM version when it comes out.
              the current MM plan is to release a new version every 90 days (quarter)
              look thru the forums for how many people had trouble installing the update…
              2.7 from 2.6, and 2.8 from 2.7…
                i updated the links in the 1st post to add .sh to the end of the script name to be consistent with the other two scripts
                raspberry.sh install
                fixuppm2.sh fix pm2 without having to do install (or u changed your mind)
                and now
                update-script.sh do all the work to update your current install to new code level
                  MwMagicMirror
                  @sdetweil said in new update/upgrade script, ready for testing:
                  bash -c “$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)” apply
                  I just ran your script and get the following errors:
                  error: pathspec ‘.github/stale.yml’ did not match any file(s) known to git.
                  error: pathspec ‘modules/default/calendar/vendor/ical.js/example_rrule.js’ did not match any file(s) known to git.
                  error: pathspec ‘modules/default/calendar/vendor/ical.js/examples/example_rrule.ics’ did not match any file(s) known to git.
                  error: pathspec ‘modules/default/calendar/vendor/ical.js/test/test12.ics’ did not match any file(s) known to git.
                  error: pathspec ‘modules/default/calendar/vendor/ical.js/test/test13.ics’ did not match any file(s) known to git.
                  error: pathspec ‘modules/default/calendar/vendor/ical.js/test/test14.ics’ did not match any file(s) known to git.
                  error: pathspec ‘modules/default/weather/providers/ukmetoffice.js’ did not match any file(s) known to git.
                  error: pathspec ‘modules/default/weather/providers/weathergov.js’ did not match any file(s) known to git.
                  error: pathspec ‘translations/sk.json’ did not match any file(s) known to git.
                  error: pathspec ‘translations/tlh.json’ did not match any file(s) known to git.
                  error: pathspec ‘vendor/css/font-awesome.css’ did not match any file(s) known to git.
                  Any Ideas? I dont recall messing with any of those files.
                  MW
                    sdetweil @MwMagicMirror
                    @MwMagicMirror can u send me the mm/installers/upgrade.log
                    Same userid as here at Gmail.com
                    G Mykle1M 2 Replies Last reply Reply Quote 0
                      Those files are in the current GitHub repo.
                      • G Offline
                        Gomalley @sdetweil
                          Tried using the your upgrade script. Current MM version 2.6.
                          Upgrade started - Tue Aug 20 21:51:16 EDT 2019
                          doing test run = true
                          downloading dumpactivemodules script
                          saving custom.css
                          remote name =
                          fetching latest revisions
                          MagicMirror git pull failed
                          restoring custom.css
                          Upgrade ended - Tue Aug 20 21:51:17 EDT 2019
                            sdetweil @Mykle1
                            @Mykle1 can u do a git status, and git remote -v
                            In the MagicMirror folder
                              i added a check for the git remote not being set.
                                sdetweil @Mykle1
                                @Mykle1 but at least there is a log to look at!
                                  It’s very likely that this was a manual installation of MM (in case that matters)
                                  pop@E8300:~$ cd MagicMirror/
                                  pop@E8300:~/MagicMirror$ git status
                                  fatal: not a git repository (or any of the parent directories): .git
                                  pop@E8300:~/MagicMirror$ git remote -v
                                  pop@E8300:~/MagicMirror$ ^C
                                    sdetweil @Mykle1
                                    @Mykle1 is it possible u might have downloaded the code as a zip file, instead of doing git clone?
                                    Only way I can think of to get into this state
                                      Yes Sam, that is what I meant by a manual installation. :-/
                                        sdetweil @Mykle1
                                        @Mykle1 cool. Thanks for the test. Updated script to handle
                                          I wish I would have waited for the updated script. I went ahead and installed a new MM because I couldn’t move forward with what I am doing. Again, thanks for your scripts. I will continue to use them. They’re awesome. :thumbsup:
                                            sdetweil @Mykle1
                                            @Mykle1 I think u did the right thing. The “handle” is to bail out gracefully if there is no git repo locally (zip file install doesn’t provide any path forward, that I have found)
                                            • 16
                                            • 17
                                            • 1 / 17
