    328 Posts 27 Posters 740.6k Views 24 Watching
      i updated the links in the 1st post to add .sh to the end of the script name to be consistent with the other two scripts
      raspberry.sh install
      fixuppm2.sh fix pm2 without having to do install (or u changed your mind)
      and now
      update-script.sh do all the work to update your current install to new code level
        MwMagicMirror
        @sdetweil said in new update/upgrade script, ready for testing:
        bash -c “$(curl -sL https://www.dropbox.com/s/lxzwyzohg61sppu/upgrade-script.sh?dl=0)” apply
        I just ran your script and get the following errors:
        error: pathspec ‘.github/stale.yml’ did not match any file(s) known to git.
        error: pathspec ‘modules/default/calendar/vendor/ical.js/example_rrule.js’ did not match any file(s) known to git.
        error: pathspec ‘modules/default/calendar/vendor/ical.js/examples/example_rrule.ics’ did not match any file(s) known to git.
        error: pathspec ‘modules/default/calendar/vendor/ical.js/test/test12.ics’ did not match any file(s) known to git.
        error: pathspec ‘modules/default/calendar/vendor/ical.js/test/test13.ics’ did not match any file(s) known to git.
        error: pathspec ‘modules/default/calendar/vendor/ical.js/test/test14.ics’ did not match any file(s) known to git.
        error: pathspec ‘modules/default/weather/providers/ukmetoffice.js’ did not match any file(s) known to git.
        error: pathspec ‘modules/default/weather/providers/weathergov.js’ did not match any file(s) known to git.
        error: pathspec ‘translations/sk.json’ did not match any file(s) known to git.
        error: pathspec ‘translations/tlh.json’ did not match any file(s) known to git.
        error: pathspec ‘vendor/css/font-awesome.css’ did not match any file(s) known to git.
        Any Ideas? I dont recall messing with any of those files.
        MW
          sdetweil @MwMagicMirror
          @MwMagicMirror can u send me the mm/installers/upgrade.log
          Same userid as here at Gmail.com
          G Mykle1M 2 Replies Last reply Reply Quote 0
            Those files are in the current GitHub repo.
            • G
              Gomalley @sdetweil
              • Mykle1M
                Tried using the your upgrade script. Current MM version 2.6.
                Upgrade started - Tue Aug 20 21:51:16 EDT 2019
                doing test run = true
                downloading dumpactivemodules script
                saving custom.css
                remote name =
                fetching latest revisions
                MagicMirror git pull failed
                restoring custom.css
                Upgrade ended - Tue Aug 20 21:51:17 EDT 2019
                  sdetweil @Mykle1
                  @Mykle1 can u do a git status, and git remote -v
                  In the MagicMirror folder
                    i added a check for the git remote not being set.
                      sdetweil @Mykle1
                      @Mykle1 but at least there is a log to look at!
                      • Mykle1M
                        It’s very likely that this was a manual installation of MM (in case that matters)
                        pop@E8300:~$ cd MagicMirror/
                        pop@E8300:~/MagicMirror$ git status
                        fatal: not a git repository (or any of the parent directories): .git
                        pop@E8300:~/MagicMirror$ git remote -v
                        pop@E8300:~/MagicMirror$ ^C
                          sdetweil @Mykle1
                          @Mykle1 is it possible u might have downloaded the code as a zip file, instead of doing git clone?
                          Only way I can think of to get into this state
                          • Mykle1M
                            Yes Sam, that is what I meant by a manual installation. :-/
                              sdetweil @Mykle1
                              @Mykle1 cool. Thanks for the test. Updated script to handle
                              • Mykle1M
                                I wish I would have waited for the updated script. I went ahead and installed a new MM because I couldn’t move forward with what I am doing. Again, thanks for your scripts. I will continue to use them. They’re awesome. :thumbsup:
                                  sdetweil @Mykle1
                                  @Mykle1 I think u did the right thing. The “handle” is to bail out gracefully if there is no git repo locally (zip file install doesn’t provide any path forward, that I have found)
                                  • Mykle1M
                                    Understood, thanks. :-)
                                      Added some reporting of current version and version upgrading to.
                                      Also had path that did a live merge when u were just testing. Fixed that
                                        another update… i was reporting ALL the files that changed between versions, but who cares (things are SUPPOSED the change!)… we only care if there is a conflict… fixed that
                                          potts-mike
                                          I am getting the below errors when trying to run your installer script, thoughts?
                                          bash: line 18: $‘\r’: command not found
                                          bash: line 20: $‘\r’: command not found
                                          bash: line 27: $‘\r’: command not found
                                          bash: -c: line 28: syntax error near unexpected token $'{\r'' 'ash: -c: line 28: trim() {
                                            sdetweil @potts-mike
                                            @potts-mike thanks… try now… danged editing from windows got the wrong line end characters…
                                            • 16
                                            • 17
                                            • 1 / 17
